MSR1 Controller powering multiple servos at the same time.
I'm trying to power up to six servos at the same time off of an MSR1. Whenever I try to power a few I get the low power signal led on the board and the board reboots. I'm trying to port over an application from a BS2 Homework board which ran off of one power supply and worked really well. I tried the same power supply, I tried a 12 volt wall jack but the MSR1 always signals low power and reboots. I tried changing the VIN - 5V jumper to directly move the servos from the power supply and same result. Can someone direct me to how to make this work?
Below is the code (I'm still to o lazy to figure out how to post it although someone has already messaged me to tell me how I apologize for this.)
Init works ok the servo goes to the right positions, but init3 doesn't.
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
tx_pin = 30
rx_pin = 31
s0 = 0
s1 = 1
s2 = 2
s3 = 3
s4 = 4
s5 = 5
s6 = 8
led = 9
ping_pin = 7
mbend = 100
s0_centre = 750
s1_centre = 750
s2_centre = 770
s3_centre = 760
s4_centre = 750
s5_centre = 750
var
byte x
long pos, i, i2, range, cmDistance, inDistance, time, j, k, mramp
obj
bs2 : "bs2_functions_1_3_5"
ping : "ping.spin"
pub main
bs2.start (rx_pin,tx_pin)
init
init3
pub init
bs2.pause(5000)
j := 0
repeat until j == 21
bs2.pulsout(s6,250)
bs2.pause(20)
j++
bs2.pause(1000)
j := 0
bs2.pulsout(s6,1250)
bs2.pause(20)
j++
bs2.pause(1000)
j := 0
bs2.pulsout(s6,750)
bs2.pause(20)
j++
pub init3
i := 0
repeat until i == 10
j := 0
bs2.pulsout(s0,750)
bs2.pulsout(s1,s1_centre)
bs2.pulsout(s4,s4_centre)
bs2.pulsout(s5,s5_centre)
bs2.pause(20)
j++
i ++
CON
tx_pin = 30
rx_pin = 31
s0 = 0
s1 = 1
s2 = 2
s3 = 3
s4 = 4
s5 = 5
s6 = 8
led = 9
ping_pin = 7
mbend = 100
s0_centre = 750
s1_centre = 750
s2_centre = 770
s3_centre = 760
s4_centre = 750
s5_centre = 750
var
byte x
obj
ping : "ping.spin"
pub main
init
init3
pub init
bs2.pause(5000)
j := 0
bs2.pulsout(s6,250)
bs2.pause(20)
j++
bs2.pause(1000)
j := 0
bs2.pause(20)
j++
bs2.pause(1000)
j := 0
bs2.pulsout(s6,750)
bs2.pause(20)
j++
pub init3
i := 0
j := 0
bs2.pulsout(s0,750)
bs2.pause(20)
j++
i ++
Servos draw a lot of current when under load, up to 1A each. You're pushing the supply if you try to run more than 2 or 3 servos from the regulated supply. The regulator requires a supply voltage of at least 6V or the "power low" LED will come on. You didn't say what kind of battery pack you're using. You may need a higher voltage battery, something more like a rechargable R/C vehicle battery that puts out 7.2V (with 6 NiMH cells).
Also, you might want to move some servos to different pins farther apart, so 2 servoes at pins 0 and 1, 2 servos at pins 8 and 9, and 2 servos at pins 16 and 17. Each of the 8pin groups run off a different translator chip, so it'll spread the power load between them evenly.
Check out the Propeller Wiki·and contribute if you can.
I just down want to have to use a servo controller board as then I will need two or three power supplies which adds to the bulk and weight. As of now the bot is quite light.
