DS2760 and Omega Pipe Plug Probe?
Bill Chennault
All--
I am thinking about building a microcontroller operated model boiler for a model steam engine driven electrical generating plant. It would be a great project combining three of my hobbies; robotics, machining, and steam engines. To do it the way I want, I need to measure the water/steam temperature in a few places; boiler, boiler fire tube, and boiler exhaust.
I am wondering if the DS2760 can be interfaced to an Omega "Pipe Plug Probe" Type T·(TC-T-1/8NPT-G-72)? I think I need the grounded version of the Type T probe. The DS2760 kit specs on the Parallax site mention the inclusion of a Type T thermocouple. I would experiment with the kit's Type T thermocouple and then use the Omega part which I can screw into the side of my boiler. It will also handle the exhaust temperature. I will have to experiment a bit to determine if it will handle the fire tube temperature but I am fairly confident it will as long as I don't put it too close to the flame. I was thinking of placing it after the first two Galloway tubes. (Galloway tubes are merely water tubes that criss-cross in the fire tube. If I place the thermocouple behind the first set, they will be positioned to measure the temperature I really would like to measure, which is far lower than the actual flame temperature.)
I don't have a clue! If you do, I would love to hear it!
Thanks!
--Bill
You are what you write.
Thanks!
--Bill
Post Edited (kf4ixm) : 1/15/2010 6:05:16 PM GMT
Wow! Great info! Thanks a ton!
I'll proceed with some confidence, now.
--Bill
Post Edited (kf4ixm) : 1/15/2010 6:36:10 PM GMT
Thanks for the link.
After reading that article, I know almost enough to be dangerous.
--Bill
