QTI with BS2 - height recommendation?
We are using a QTI to count black and white stripes on a wheel as the servo turns. The code is very simple (at least conceptually), but the height requirement is annoying!!!!
We used QTI before to follow a black line, but we kept having trouble finding the correct height to measure the color (a simple bump affected its capabilities
What height do you recommend for the wheel (each stripe is about 2mm in width)? It's paper taped to a wheel, so it is not flat, unfortunately
Post Edited (abcd) : 1/10/2010 5:44:28 PM GMT
Dave
Dave Andreae
Parallax Tech Support·
