Making an Electromagnet
If I were to make a high powered electromagnet, what wire and what core for the spool would I need? Could I power it with a car battery charger(for the high amps)? Does anyone know enough about one to give advice on making one? Thanks in advance,
Micro
Computers are microcontrolled.
Robots are microcontrolled.
I am microcontrolled.
SX Spinning light display·
Micro
A simple solenoid style or alternating N/S poles (<-- in-line or concentric rings), there are several possibilities where one may be functionally better than the other depending on the application.
Beau Schwabe
IC Layout Engineer
200 lbs.· What do you reckon the current will be?
····www.electromechanicsonline.com/product.asp?pid=579
At least this will give you some idea of typical size and power requirements for a magnet in this "weight class". Unless you're dead set on building one from scratch, you might want to haunt the surplus dealers, as they sometimes have used or overstock electromagnets for sale.
Iron is the best material for a core though steel(not sergical) will work also since it has iron in it.
The electrical code of canada states:
14awg: 15A
12awg: 20A
10awg: 30A
8awg: 45A
I don't have my code book with me at the time so this will have to do. These are safe values ment to keep your house from burning down even if you use these loads 24/7. From experience you can easily multiply the current by 5 without causing problems to the wire for short periods of time assuming they are in an open area and not enclosed in a wall.
24 bit LCD Breakout Board now in. $24.99 has backlight driver and touch sensitive decoder.
A good iron-iron contact wastes almost no magnetic flux whereas a small air gap wastes almost all of it. An abilty to hold 200 lbs would not be a very large magnet. A magnet that can lift 200 lbs over several inches would be comparitively huge.
The resistance per foot of wire is available and that will let you limit your current to a reasonable level for your source. Then have to have a soft iron core big enough to hold that length of wire. You know the amps and the number of turns (you counted the turns, right?) so you know the flux strength. I'm sure some manufacturer of commercial magnets has a table of lifting sizes based on flux produced.
Tom Sisk
http://www.siskconsult.com
Alex Burke
"Beware of computer programmers that carry screwdrivers." -Leonard Brandwein
The wire is 4mmx0.2mm make 1000 coils one after the next and we would have an orbital launch platfor.
Alex Burke
I wonder how much power that thing would require? Is that the reason why we technically don't have one now?
Alex Burke
Hate to disagree with you but if you are going to accelerate a real mass to any velocity it will take real power. Assuming 100% efficiency and no friction or other losses E = 1/2M * V^2.
Post Edited (mctrivia) : 1/14/2010 5:12:04 AM GMT
Technically, don't you want them both to face "up"? If they were opposed, then the upper would have to be WAY bigger than the lower, cause they'd be fighting one another.
Either way, with 4 feet separating them, it's probably going to be more current than you could feasibly supply.
Visit some of my articles at Propeller Wiki:
MATH on the propeller propeller.wikispaces.com/MATH
pPropQL: propeller.wikispaces.com/pPropQL
pPropQL020: propeller.wikispaces.com/pPropQL020
OMU for the pPropQL/020 propeller.wikispaces.com/OMU
Come see my new blog!
BTW, magnetite can be found by just going to some open dirt driveway, sandy beach, etc, and just dragging a large magnet around. Goldbugs dispose of the stuff all of the time as it
collects on their slooth boxes.
