Prop And USB joystick
I'm verry new to the propeller and i don't really know how USB works either.
So my question is, can you connect a Prop and a USB joystick (like a logitech attack3) if so, How?
Kind regards,
Miles. K
Post Edited (Miles. k) : 1/9/2010 11:59:14 PM GMT
Kind regards,
Miles. K
Is there one?
If not, there are drivers for the Nintendo joysticks and the Hydra Propeller Game Development board,
and you can use a half-dollar shift register chip with old Atari/C64/Coleco or arcade machine joysticks,
or hacked (rewired) USB joysticks.
(In my opinion, USB is very very complicated for absolutely no good reason whatsoever,
and the chips for decoding USB always seem to cost more than the Propeller, unless perhaps it is HID USB.)
VIRAND, If you spent as much time SPINNING as you do Trolling the Forums,
you'd have tons of awesome code to post! (Note to self)
If you were positive your joystick _only_ uses low speed usb, then it's possible at 96Mhz that you could write a basic USB host for it, but otherwise it's not gonna happen.
Life may be "too short", but it's the longest thing we ever do.
If you don't use a superspecial designed, forcefeedback USB-joystick which is a MUST to use that one.
Buy a simple joystick with simple switches inside and use that one.
If you post a detailed description about your project the forum can give further advice
best regards
Stefan
