Pings per Scan Quesiton
All--
I am working with Ping and the Parrallax Standard Servo. I would like for the servo to turn 90* left and right, continuously. How many pings should I generate per left or right scan?
I am thinking that the optimum value depends on the distance. Since I only care about anything within three feet, I GUESS that determines the optimal number of pings I should produce. ("Optimal" is such a precise word. All I want to do is reduce processor overhead to some common sense level.)
Thanks!
--Bill
You are what you write.
Thanks!
--Bill
That is invaluable information for me! I think it will go a long way to solving not only the issue I mentioned, but some obvious timing problems I am having in the SX environment when using PING)) and the servo and an LCD.
Thank you very much.
--Bill
