Unipolar Stepper
My Propscope works well with the Stamp applications but not for measuring a unipolar stepper motor (6V, 200mA) which is controlled by an unknown controller (no Stamp involved); see attachment.
When I want to measure the voltage pattern of a stepper motor the Propscope shows some results but the motor stops turning or turns extremely slowly.·Therefore, I do not know whether the measured signals are right (I·connect the ground probe to the ground of the motor and positive probe to one of non-ground wires). When I disconnect the probes the motor start turning again.
Any help for the right measurement set-up is welcome.
Can you read without the ground?
I have the same problem with a PCF8575. I can read the SCL line, but not the SDA line. This is probably due to the signal attenuation which probably happens when the probe is connected.
James L
James L
Partner/Designer
Lil Brother SMT Assembly Services
Are you addicted to technology or Micro-controllers..... then checkout the forums at Savage Circuits. Learn to build your own Gizmos!
For better results, should the ground of my oscilloscope be connected to the ground of the motor's power supply? Or, are the data equally good?
Well....if the motors are slowing down, with the ground, you may not have a choice.
The probes always work better with a ground, but sometimes grounding them will cause problems like with your motors.
If the ground doesn't cause a major problem (shouldn't) I try to ground when ever I can.
James L
James L
Partner/Designer
