More machine code problems — Parallax Forums
Zap-oZap-o Posts: 452
edited 2010-01-06 05:47 in Propeller 1
I am trying to access the pub but cant seem to do it right.
VAR
        Long cog
        Long Second
PUB Start :  okay
  okay := cog := Cognew(@Main, 0) + 1
Pub Seconds
    Return Stack
Dat
        ORG             0
Main
        Mov             Stack,  #0
        Mov             time,   Cnt
:Loop   Waitcnt         time,   Delay
        Add             Stack,  time
        jmp             #:loop
Stack   res 1
time    res 1
delay   long 80_000_000
        Fit             496
I need to get the value of Stack in pub second
Any ideas?
  • BeanBean Posts: 8,129
    edited 2010-01-04 17:44
    ·You'll have to use something like this:
    VAR
            Long cog
            Long Second
            Long Stack
    PUB Start :  okay
      okay := cog := Cognew(@Main, @Stack) + 1
    Pub Seconds
        Return Stack
    Dat
            ORG             0
    Main
            Mov             StackPtr, par
            Mov             StackVal, #0
            WRLong          StackVal, StackPtr
            Mov             time,   Cnt
            Add             StackVal,  time
            jmp             #:loop
    StackPtr  res 1  ' Pointer to "Stack" hub ram location
    StackVal  res 1  ' Value to put into "Stack"
    time      res 1
    Fit             496
    Bean
    Use BASIC on the Propeller with the speed of assembly language.
    PropBASIC thread http://forums.parallax.com/showthread.php?p=867134
    Post Edited (Bean (Hitt Consulting)) : 1/4/2010 7:26:56 PM GMT
  • Zap-oZap-o Posts: 452
    edited 2010-01-04 17:55
    Thanks for the quick reply Bean I was wondering if this
    Dat
            ORG             0
    Needed to be
    Dat
            ORG
    Since I am using the following line of code.
    and not
    edited 2010-01-04 17:57
    "ORG" or "ORG 0"...Does the same thing. It doesn't matter.
    Bean.
    PropBASIC thread http://forums.parallax.com/showthread.php?p=867134·
    edited 2010-01-04 18:05
    In your example how do you know that stack is the correct address? Is it because
    @stack is address $00 ?
    edited 2010-01-04 18:08
    Don't forget: reses must always come after longs. They're used for cog variables only and not for anything accessible from the hub, since they don't really exist in hub RAM.
    edited 2010-01-04 18:16
    Is COG Ram considered a register?
    edited 2010-01-04 18:20
    You can think of each cog RAM as 512 registers, if it suits you. When the cog starts, these "registers", up to location 495, get loaded from hub RAM. 496 is mapped to cnt, and the rest (497 - 511) are zeroed to start.
    Post Edited (Phil Pilgrim (PhiPi)) : 1/4/2010 6:25:49 PM GMT
    edited 2010-01-04 18:36
    Bean I appreciate your code example but honestly its more confusing to me. Lets stick to my new posted below code broke or not and go over each line.
    VAR
            Long cog
            Long Second
    PUB Start :  okay
      okay := cog := Cognew(@Main, @Second) + 1
    Pub Seconds
        Return Second
    Dat
            ORG             0
    Main
            Mov             Stack, Par
            Mov             time, Cnt
            WrLong          Stack,Stack++
            jmp             #:loop
    Stack   res 1
    time    res 1
            Fit             496
    Here is what I think is going on.
    This is starting a new cog with the memory located at Second
    Mov Stack, Par
    This moves the contents of the PAR (address $00) into Stack that I have defined below using Stack Res 1
    Mov time, Cnt
    This moves the counter register in to the register time that I also defined below using Time Res 1
    This waits here until delay register (defined below as 80_000_000) is equal to time
    This increment stack and writes to the register Stack
    Is this working as I think it should? It sure is not working in real life
    Edited :By the way all the code should do is add 1 every second
    Post Edited (Zap-o) : 1/4/2010 6:42:16 PM GMT
    edited 2010-01-04 18:53
    You've still got a long after the reses. That will not work. Also, your first waitcnt will have to wait almost a minute, since you haven't provided a cushion for the first value of time.
    Post Edited (Phil Pilgrim (PhiPi)) : 1/4/2010 6:58:16 PM GMT
    edited 2010-01-04 19:08
    ERGH this is so frustrating. I have a 1,000 questions and can only ask them one at a time. I am so lost seems the more I dig into the assembly language.
    Phil I have done this and it still is not working. Thanks for the help I will keep reading the manual - not much help in that book in my opinion until the lights come on.
    edited 2010-01-04 19:14
    "mov stack,par" moves the contents of par to the variable/register stack. The contents of par is the value passed to cognew, @second in this case (not the contents of second).
    ":Loop waitcnt time,delay" won't work the way you expect. You've set time to the contents of cnt. When the waitcnt executes, that time has passed by and the waitcnt will wait about 50 seconds until cnt wraps around 32 bits and is equal to the value in time.
    "wrlong stack,stack++" won't do what you expect. "stack++" doesn't increment "stack" in assembly, only in Spin. The assembler will probably assume you meant "wrlong stack,stack".
    A simple assembly routine to increment a memory location once a second would look like:
    ' you'd start this with "cognew(@main,@secondCounter)"
    DAT
            org   0
    main rdlong sec1,#$0   ' hub location $0 contains the CLKFREQ value
            mov   time,sec1
            add    time,cnt    ' set the initial time to one second in the future
    :loop waitcnt time,sec1 ' wait 1 second and increment the wait time
            rdlong temp,par   ' read the location in hub memory
            add     temp,#1   ' increment it
            wrlong temp,par  ' write it back
            jmp     #:loop
    sec1  res      1
    time  res      1
    temp res      1
    edited 2010-01-04 19:23
    Mike so the "#" means something as in the first line of code you submitted above?
    edited 2010-01-04 19:27
    Without the "#" it means use whatever is in that address. With the "#" is means use this literal number.
    MOV temp,0 ' Move the value that is in address zero into temp
    MOV temp,#0 ' Move the value zero into temp
    Bean
    edited 2010-01-04 19:30
    Thanks Bean that makes since but, and sorry if I am asking stupid questions, Mikes comments he says
    main    rdlong          sec1, #$0   ' hub location $0 contains the CLKFREQ value
    I don't see how this has anything to do with hub 0 and clkfreq?
    Please understand -should be obvious- I am new and trying to understand the "machine code".
    edited 2010-01-04 19:36
    It just so happens that Spin stores the CLKFREQ value in hub memory location zero when the Spin program is loaded (since this value is known when the program is compiled ... by defining either _CLKFREQ or _XINFREQ and _CLKMODE). The value in hub location zero (CLKFREQ) is the number of system clock ticks in one second.
    That first instruction just makes use of a Spin convention to get the number of clock ticks in one second by reading the long stored in hub location zero.
    edited 2010-01-04 19:40
    Mike you are full of tricks. I think I am beginning to understand. My main problem is now that I am getting the Hub mixed up with the cog.
    When you wrote this line of code
    :loop   waitcnt         time, sec1  ' wait 1 second and increment the wait time
    How did you know it only takes 1 sec. Seems that your code (works great by the way) would run faster than a second.
    edited 2010-01-04 19:49
    It takes one second because I computed the time one second in the future, then waited for that time to occur. The WAITCNT instruction then increments "time" by the number of clock ticks in one second to produce a next wait time one second further in the future. The actual increment of the memory location takes place after the WAITCNT has taken place, while the system clock is running towards the next computed second mark. There's a description of this technique in the Propeller Manual in the section on the WAITCNT statement.
    I like to think of hub memory as an I/O device. You need to use special instructions to access it and it has its own rules (like it's byte, word, and long accessible and works on its own time schedule).
  • SamMishalSamMishal Posts: 468
    edited 2010-01-04 23:43
    Zap,
    I looked at your code and I may be too late and all the other GREAT people have helped enough already.
    But here is my two bits worth......In your original code I saw·Four problems.
    VAR
            Long cog
            Long Second
    PUB Start :  okay
      okay := cog := Cognew(@Main, [b][color=red]0[/color][/b]) + 1
    Pub Seconds
        [b][color=red]Return Stack[/color][/b]
    Dat
            ORG             0
    Main
            Mov             Stack,  #0
            [b][color=red]Mov             time,   Cnt[/color][/b]
    :Loop   [b][color=red]Waitcnt         time,   Delay[/color][/b]
            Add             Stack,  [b][color=red]time
    [/color][/b]        jmp             #:loop
    [b][color=red]Stack   res 1
    [/color][/b]time    res 1
    [b][color=red]delay   long 80_000_000[/color][/b]
            Fit             496
    1- You were confusing Hub and Cog Ram.....especially in the DAT section
    Even though you have a DAT variable that within the SPIN code is a valid variable and is accessible to the SPIN methods
    it is NOT the same variable when the DAT section is copied to the COG as part of the PASM code.
    So when you had the Stack Res 1 variable there were three problems with it... It is a RES so it never got created in the HUB ram
    in the first place..... Even if it were, when it gets copied to the Cog as part of the PASM code it becomes a COG ram variable
    and that is NOT the same as the Hub ram one.....So when you update that variable in the PASM code it is not going to update
    the one in the DAT area in the HUB ram.
    This is all confusing due to the DAT variables being of the same name as the Cog and Hub.....that is why it is not a good idea to share
    DAT variables of the same names as the Hub and Cog....use different stuff like VARs.
    2- You were putting LONGs AFTER RESs
    all LONGs in the DAT section that will be copied to the PASM code should be BEFORE any RESs....always put RESs as the last thing.
    3- Instead of Counting Seconds you are counting the Clock Ticks
    When you Add Stack, time.... you are adding the clock ticks count not incrementing the seconds count. It should be
    Add Stack, #1 .....but any way see later for a working program.
    4- Wrong use of the WaitCnt command.
    When you moved the Cnt to the time variable and then WaiteCnt time,Delay you will be waiting for a long long time before the waitcnt will
    actually time out....this is because the value in time is already LESS than the new Cnt value and WaitCnt will have to wait until Cnt
    rolls over again and become less than the original Cnt value you stored in time.
    So what you need is to INCREMENT the time value BEFORE you use it in the WaitCnt command.....but only the first time since in the
    PASM version once WaitCnt times out it also increments the time variable by the delay (nice feature should have been also in SPIN).
    Anyway..... I have "corrected" your code and PRESERVED as much as possible your original code. This way you can compare the
    working program to the original one and can observe the corrections and how they apply.
    Here it is.. I added some DEBUGGING code to see what is happenning........pay attention to bolded stuff
    CON
      _clkmode = xtal1 + pll16x
      _xinfreq = 5_000_000
    Var
            Long cog
            Long Seconds
    OBJ
      Debug    : "FullDuplexSerialPlus"    '....added this to do sum debugging
    PUB Start :  okay
      Debug.Start(31,30,0,115200)  ' start the debugger
      waitcnt(ClkFreq+cnt)  'wait a bit to give time to activate the Serial terminal
      okay := cog := Cognew(@Main, [b]@Seconds[/b]) + 1  'changed here to pass the address of Seconds to the cog
      repeat                     '...this is just some debugging code to print out the results
        Debug.Dec(GetSeconds)
        Debug.Tx(2)
        Debug.Tx(0)
        Debug.Tx(0)
    Pub GetSeconds 'renamed your original method to make more sense
        [b]Return Seconds[/b]   'changed here to return the Seconds value
    Dat
            ORG             0
    Main
            [b]Mov             SecondsPtr, Par          'save the address of the Seconds variable
    [/b]        Mov             time,       Cnt
            [b]Add             time,       Delay        'make sure that time is Delay ahead as a start[/b]
            [b]Add             SecondsValue, #1         'increment the seconds by 1
    [/b]        [b]WrLong          SecondsValue, SecondsPtr ' copy the value to the Hub Ram variable[/b]
            jmp             #:loop
    [b]delay          long 80_000_000    'moved this here since all LONGs have to be before RESs[/b]
    SecondsValue   Long 0             'renamed the variables to make more sense
                                      'also made the SecondValue as a Long to be able to initialize it
                                      'here instead of in the PASM code...it needs to be a zero to start with.
    SecondsPtr     res 1
    time           res 1
            Fit             496
    Samuel
    www.RobotBASIC.com
    Post Edited (SamMishal) : 1/4/2010 11:48:36 PM GMT
    edited 2010-01-05 11:55
    SamMishal and everyone that is helping me, thank you.
    So I cant seem to grasp the memory mapping of the hub. for example
    okay := cog := Cognew(@Main, @Seconds) + 1
    This starts a cog at the label @Main with memory @seconds
    Then in the Assembly code how does it know? Nowhere is it mentioned again / Also what if I want to use more memory how can I be sure to read / write the correct one? I feel like there should be an addressing mechanism or stack pointer or something.
    edited 2010-01-05 12:13
    Okay, the @Main is NOT where the cog starts. That is where the cog is LOADED from. 496 longs are loaded from @Main to address zero in the COG.
    The @Seconds value gets put into the "par" register (read-only, must be LONG alined). This is the address (in HUB ram) of your parameters.
    I think you are getting confused between HUB ram addresses and COG ram addresses. It might help to think of HUB ram as like a hard drive, and COG ram as RAM. You need to "load" a program from the hard drive (HUB ram) into ram (COG ram) to run it. @Main is where the program is located on the hard drive, and @Seconds is where some data is located on the hard drive.
    Bean.
    edited 2010-01-05 13:05
    Zap-o said...
    Zap-O,
    You are welcome.....
    I think you are confusing the CogNew() when it is used to start a SPIN code and when it is used to start a PASM code.
    When CogNew() is used to start a SPIN code you give it the name of the METHOD and (you are right) an address for an area
    in the HUB ram to use as a STACK for doing pushing and popping for when other methods are called with parameters and for
    doing MATH (adding multiplying etc).
    HOWEVER......when you use CogNew() to LOAD a PASM code you give it two things
    1- The area in the DAT section where the PASM code is.
    Nothing to do with the Org 0 or anything....the compiler knows where to get the PASM code from the name you
    gave for the·area in the DAT section. And it does not matter what you give it in the next parameter it ALWAYS
    loads 496 Longs into the Cog and then starts the cog running from the 0th address.
    The Org 0 is a directive that tells the compiler to start loading the code at the 0th ram or a different place
    in the very rare situation you might want to do so (ie other than 0).....but just forget about Org 0 now.....
    just put it there and one day you will see why you might want to put a number other than 0....by the way
    Org without the 0 will do the same thing as if there is a zero there.
    2- An ADDRESS of an area in HUB ram.
    The address in the hub ram is not a STACK address. It is just that.... an address. How you use it in the PASM code
    is up to you. If you do not want to pass an address then you just put a 0.
    In this case we used it to POINT to the Seconds variable. We then used that address to COPY a long from COG
    RAM to that address in the HUB RAM but which also happened to be WHERE the Variable Seconds is and thus the
    SPIN program which OWNS the variable can see the variable and its new value.
    Of course this address could also be used to be a POINTER to the start of a CHUNK of Hub RAM or to the
    HEAD ELEMENT of and ARRAY or to the first character of a string and so on and so forth............
    So do not confuse how the Cognew() is used to start a SPIN METHOD and to start a PASM CODE.
    The two are·related actions but DIFFERENT.
    By the way....the line
    ········ Mov· SecondsPtr, Par
    is there to copy the address passed in the 2nd parameter of Cognew() to the register SecondsPtr.
    When you say CogNew(@Main,@Seconds) the·2nd parameter is saved in the PAR register of the cog.
    We really do not STRICTLY NEED to save that value in another register if all we do is use it and never want
    to INDEX into it, since it is already saved in the Par register.
    HOWEVER....it is a good practice to do so and it becomes a necessity when you need to INDEX into it
    .....but this is another complexity you do not need to worry about (for now).
    Just remember.....when we called the CogNew() we give it the address of the area in the Dat section where
    the PASM code is and the compiler will load 496 longs to the Cog. The second thing we give it is an
    ADDRESS to some place in Hub ram again and that is given to the Cog by putting it in the PAR register for the
    cog.
    Now how·you use this value in the PAR register DEPENDS on what you want to do....in your case you wanted
    to copy a value from the Cog RAM to that place in the HUB ram and since it just happened to also be where
    the Seconds variable is then you effectively managed to pass a value from the cog to the SPIN code
    which is actually running in another cog.
    I hope·I explained this clearly.....·
    Samuel
    www.RobotBASIC.com
    Post Edited (SamMishal) : 1/5/2010 1:19:41 PM GMT
  • ericballericball Posts: 774
    edited 2010-01-05 14:39
    Just to expand on Samuel's explanation - the second COGNEW parameter is a LONG address. It may also be a 14 bit value (left shifted 2 bits), but a pointer to a LONG variable or the first element in an array of longs, or the first entry in a block of LONGs are more common.
    Note: PAR is a read only register. Thus if you want to RDLONG the second element you need to copy PAR to another register.
    Composite NTSC sprite driver: Forum
    NTSC & PAL driver templates: ObEx Forum
    OnePinTVText driver: ObEx Forum
    edited 2010-01-06 02:18
    SamMishal said...
    The Org 0 is a directive that tells the compiler to start loading the code at the 0th ram or a different place in the very rare situation you might want to do so (ie other than 0).....but just forget about Org 0 now..... just put it there and one day you will see why you might want to put a number other than 0....by the way Org without the 0 will do the same thing as if there is a zero there.
    That's a rather ambiguous statement (emphasis mine). I do hope you mean what the manual has to say about this [noparse]:)[/noparse]
    Propeller Manual (pg 328) said...
    ORG only affects symbol references; it does not affect the position of assembly code in the cog itself. When assembly code is launched via a COGNEW or COGINIT command, the destination cog always loads the code into its RAM starting at address 0.
  • OctahedronOctahedron Posts: 18
    Thanks for the above.· I was working with pasm for the first time and I was having some trouble passing values back and forth between cogs.· I used SamMishal’s code above and put some reads and moved around in memory a bit.· If it helps, the modified code is below to help someone else in my predicament.· Thanks again for the great input from all of you above.
    CON
    · _clkmode = xtal1 + pll16x
    · _xinfreq = 5_000_000
    Var
    ······· Long cog
    ······· Long Seconds······
    ······· Long SecondsUp
    ······· Long SecondsDown
    OBJ
    · Debug··· : "FullDuplexSerialPlus"······· '....added this to do sum debugging
    PUB Start :· okay·
    · Debug.Start(31,30,0,115200)·········· ' start the debugger
    · waitcnt(ClkFreq * 5 + cnt)··············'wait a bit to give time to activate the Serial terminal···········································
    · Seconds···· := 1234567890············· ' Set some obvious values
    · SecondsUp := 0
    · SecondsDown := 0
    · okay := cog := Cognew(@Main, @Seconds) + 1·· 'changed here to pass the address of Seconds to the cog
    · repeat··························································'...this is just some debugging code to print out the results
    ··· Debug.Dec(SecondsUp)
    ··· Debug.tx(13)
    ··· Debug.Dec(SecondsDown)
    ··· Debug.Tx(13)
    ··· waitcnt(ClkFreq/10 + cnt)····························· 'wait a bit to display the values in Serial terminal···········································
    ··· Debug.tx(16)
    Dat
    ······· ORG············ 0
    Main·······
    ······· Mov············ SecondsPtr, Par··················· 'save the address of the Seconds variable
    ······· Rdlong········· SecondsValue, SecondsPtr····· 'Read Seconds in Cog 0 into SecondsValue in this cog
    ······· Add············ SecondsPtr, #4···················· 'Move the pointer 4 byte (1 long) to point to SecondsUp in cog 0
    ······· Mov············ time,······ Cnt······················ 'Make time equal to current counter value
    ······· Add············ time,······ Delay·····················'Add the delay to the counter value
    :loop
    ······· Add············ Delta, #1····························· 'Adding one to temp
    ······· Add············ SecondsValue, Delta·············· 'Adding temp to the SecondsValue
    ······· WrLong········· SecondsValue, SecondsPtr·····'Copy the value to the Hub Ram variable and thus to SecondsUp
    ······· Sub············ SecondsValue, Delta·············· 'Set value to the Seconds value copied from cog 0
    ······· Sub············ SecondsValue, Delta·············· 'Substract temp to the SecondsValue
    ······· Add············ SecondsPtr, #4····················· 'Move the pointer 4 byte (1 long) to point to SecondsDown in cog 0
    ······· WrLong········· SecondsValue, SecondsPtr····· 'Copy the value to the Hub Ram variable and thus to SecondsDown
    ······· Add············ SecondsValue, Delta··············· 'Set value to the Seconds value copied from cog 0
    ······· Sub············ SecondsPtr, #4····················· 'Move the pointer 4 byte (1 long) to point to SecondsUp in cog 0 again
    ······· Waitcnt········ time,········ Delay··················'Wait a second (note time is added to delay at the end of waitcnt so it is on auto)
    ······· jmp············ #:loop································· 'Start over.
    delay········· long 80_000_000······ '1 second of counts at this clock mode and x-stal
    SecondsValue·· long 0················· 'Time valiable
    Delta·········· long 0···················· 'Difference from start time in seconds
    SecondsPtr···· res 1··················· 'Memory location
    time·········· res 1······················· 'Counts of time
    ······· Fit············ 496
