Has anyone interfaced a display from a portable DVD player?
I just inherited a Toshiba portable DVD player with a 9" screen (MN: SD-P1900SN). The disc drive portion doesn't work but the screen is fine and could make a cool display for a project. It has A/V Out, A/V In, and a Bitstream/PCM jack. I have no Prop or PIC experience as yet, just BS2.
Any insight?
Any insight?
The AV-in should be able to work with a tv-signal created by the propeller.
Which board are you using? Some of the boards have a RJ-jack inluded with the resistors that build the DAC to create the TV-composite signal
best regards
Stefan
Not quite the same but I used the screen from an in car DVD player where the screens attach to the back of the seat head rests. With a little snooping it was easy enough to find out which wire was which on the LCD module and this let me use it stand alone, have a look at my little development set up:
http://forums.parallax.com/showthread.php?p=621981
9" Diagonal Wide Panel TFT
480 x 234 Resolution
Wide Aspect Ratio
Brightness 350 cd/m2
Now Graham has going on exactly what I pictured for myself.....but I have a lot to learn to get there! Your automotive DVD screen is likely quite similar at least in it's original intended usage, so my portable player version shouldn't be too far off. I'm just wondering though how practical (outside of educational gain) this might be to integrate to a point that it's useful.
Andrew Williams
WBA Consulting
Special Olympics Polar Bear Plunge, Mar 20, 2010
In any case, welcome to the world of Prop.
www.parallax.com/StoreSearchResults/tabid/768/txtSearch/Backpack/List/0/SortField/4/ProductID/602/Default.aspx
Signature space for rent!
Send $1 to CannibalRobotics.com.
if you don't have a AV-IN-connector it might be pretty complicated. It depends on if one of the two connectors you mentioned is for feeding in a video-composite signal.
If the conversion-circuit from video-composite to pixeldriver-circuit is not included you would have to deal with the pixeldriver-circuit hwich has a complete different specification
than the video-composite-signal.
best regards
Stefan
I also tried an old composite out B&W CCTV camera and it works fine thru the player. So it seems that I have something usable here, much less complicated than I first anticipated as I was first thinking I had to interface the 35 wires from the display to a controller.
I'll check out the backpack options for BS2 usage as well, thanks!
(more questions likely to follow...)
See - http://forums.parallax.com/showthread.php?p=743936
Whit+
This year I could not find any more of them with input to the screen.
Other options...
Surplus game screens for automotive use of gamecube and playstation, under $50.
CCTV, but usually costs over $100.
Ebay
Old TVs and NTSC/CCTV Monitors.
Sometimes: Automotive screens for electronic rear view, dashboard displays, rear seat DVD players.
Small flatscreens (TV) with DVI, VGA, Composite, made a year or more ago; haven't seen them new anymore.
In case HDTV has made NTSC extinct,
do we have a VGA emulation of the TV driver that works with GRAPHICS?
