Thousands of XBee Modules at Parallax (and now USB XBee boards!)
Hey all!
We've just taken delivery of our first thousand XBee modules. You will be able to buy the 2 mW versions for $19.00 and the 60 mW at $32.00. These prices are similar to Digi-Key and Mouser, maybe even cheaper. We're only able to offer these prices because of high anticipated volume. Without the volume our prices will unfortunately increase. We will also offer four (4) adapter boards: a breakout, 3.3V adapter, 5.0V adapter, and a USB board. All of these are in production right now.
We've chosen to stock the most popular modules: 802.15.4 series with chip and wire antennas.
This is the beginning of a significant commitment to the Digi line. Thank you to our customers who have patiently waited for us to get these products in stock, as well as those who've written the Propeller code objects and BASIC Stamp examples.
These are not available yet for on-line sales, but Lauren is working towards that right now.
Sincerely,
Parallax Inc.
Post Edited (Ken Gracey (Parallax)) : 1/12/2010 5:23:41 PM GMT
Sincerely,
Parallax Inc.
Why can't you guys be like so many other companies and just get new products but not tell the customers unless they ask?
With your reckless "lets keep the end users informed" attitude, I now have more possibilities for communication and more potential projects I can work on.
The future is in our hands.
Which way to the future?
On another note, if anybody in the office sees that I'm letting the cat outta the bag they're going to hang me from a servo extension cable in the CNC shop. . . they so easily mistake my style of EXPEDITE as a RUSH effort!
Check out the Propeller Wiki·and contribute if you can.
[noparse][[/noparse]My next Facebook/Twitter/Blog posting: "Wahoo!!! Ken, over at #ParallaxInc, just said they're getting ready to ship XBees!!!!"]
BTW... Mike, I absolutely love your avatar picture!!!
Bill
First "Sharks With Lasers"... now Stingrays with XBees???
Bill
How about a little XBee board with a battery so our stingrays can drop nodes as signal fades. A Breadcrumb mesh if you will.
Let us know when they are on sale.
Jim-
PS: In a seminar years ago I posed the question "How do you know if your a successful business?".
An AT&T guy in the back said "When you don't care about our customers anymore." Parallax at this rate, your doomed.
Signature space for rent!
Send $1 to CannibalRobotics.com.
Dave E
Any info on the antenna?
Will it be all on teh module, or allow for an external separate antenna!?
<FONT>Steve
What's the best thing to do in a lightning storm? "take a one iron out the bag and hold it straight up above your head, even God cant hit a one iron!"
Lee Travino after the second time being hit by lightning!
Bill
Powered by enthusiasm
All versions sold by Parallax have antennas mounted on the module. Digi basically offers four (4) antenna styles. The models we're selling cover 90% of customer purchasing habits - wire or chip antenna. The next version we'd add would be the long-range variety (900 mHz I think).
The chip antennas have the same distance rating as the wire, but Digi has told me that the wire actually works 20% better in the same conditions.
Parallax Inc.
The white paper concludes:
After reviewing Table 1, we can make several important observations.
• The whip antenna has a range advantage over the chip antenna, but only outdoors.
• The XBee-PRO can achieve more range than the XBee.
• The XBee-PRO and XBee both achieve more range outdoors than they do indoors.
Nice summary My limited experience shows those statements to be entirely true.
I'd put emphasis on the part about XBee PRO - 60 mW is a lot more power than 2 mW.
I down loaded "a" Manuel for the X-Bee but I'm still not sure here. Can the X-Bee take an IP address and a sub net mask to work in a WiFi work group? In other words,Act as a node?
TCP/IP 100.0.1.xxx were xxx is the node address from 0-255 and 100.0.1 is the work group.
I've waited along time for a good WiFi setup.Please tell Me some good news.
The Truth is out there············___$WMc%___···························· BoogerWoods, FL. USA
I don't think so, but I'm not certain. OTOH, they use the same 802.15.4 communication scheme, so maybe they do. They have some other devices which are web-ready (and we can stock them, too).
I'll look into this for you, or some other forum member can answer the Q. Good to see you on the forums again - seems like we haven't crossed paths in at least 40 days.
- Ken
Sorry, but I'm pretty certain that the XBees won't do what you're looking for here. I think that you might be confusing 802.11 (WiFi) with 802.15.4 (XBee). There are WiFi modules out there - I know nothing about those, though.
I've attached a comparison table of the various XBee modules. Found this somewhere on the Digi site a while back.
The bottom of the chart shows "WiFi" as an adapter for the XBee modules. Wonder what that's all about.
http://www.digi.com/products/wirelessdropinnetworking/connectportxgateways.jsp#overview
http://www.digi.com/pdf/ds_connectportx.pdf
It's a gateway between XBee 802.15.4 networks and "cellular, ethernet, WiFi". I imagine it'll set you back a couple of hundred dollars.
Thanks for the links.
What I'm after is control within a LAN and not so much a web base setup.To Me PC anywhere is way easier to use than setting up a web page.
I'll check out the links and report back.
Thanks again
Back from the links.
It looks like the X-Bee Pro 60mW and larger will do FHSS all day long @ 2.4GHz.But digi wants one to purchase a high dollar BS converter to make it happen.
Setting up the TCP/IP doesn't seem that hard to do.
I could be wrong here. But I'll take a couple X-Bee's to find out.
P.S.2010 If the Aztec's and Mayans are right.We only have 2 more years to get WiFi to our Stamps!
TCP/IP requires more CPU / memory than is available on the Xbee's onboard Freescale / Atmel processor. Not to mention the PHY chipset for Zigbee doesn't even come close to supporting the 802.11 standard that 'Wifi' uses.
There are many 802.11 wireless (commonly referred to as Wifi) modules out there that could easily interface to a BS2 or any other processor. Search for 'Matchport b/g', 'WiFly', 'WiPort', 'Nano Socket iWifi', or just 'serial to 802.11'. It's not going to be cheap (lowest cost solutions are around $59 USD in single quantities). 802.11 was never designed to be inexpensive or low power.
The cheapest way to get 802.11 support is to buy a wireless router capable of running linux. You can usually get them for under $40. These routers are really the most inexpensive way to get a wide range of connectivity options (Ethernet and Wifi in one inexpensive package). It will be much harder to get up and running (you have to have pretty deep knowledge of linux command line).
I was pointing out the fact that the X-Bee will Freq.Hop(FHSS).I wasn't sure about the TCP/IP and memory space.
Thanks for the info.
I'd still like to try out the X-Bee's
Micro
Computers are microcontrolled.
Robots are microcontrolled.
I am microcontrolled.
SX Spinning light display·
On the Obex you have plenty of objects working with the GPS in Raw mode, or almost any other OEM GPS. Some are giving you back strings, others floats, and they are generally well commented.
Massimo
I will definitely be picking up quite a few more of these nice little devices. Not sure if Parallax can work a deal with SparkFun for their boards the provide a USB break out board or just a regulated breakout board, but they make the use much more easy.
Here are the links to the Breakout boards by Sparkfun...
http://www.sparkfun.com/commerce/product_info.php?products_id=8687
http://www.sparkfun.com/commerce/product_info.php?products_id=9132
Jim Fouch
FOUCH SOFTWARE
