Adapting QFN-20 Package to Perfboard
· I'm ordering an Si Labs FM receiver chip.· It is available only in a QFN-20 package.· Can it be adapted to a perfboard using thru-hole mounting?· I did find QFN to SMT adapters but I have yet to learn SMT techniques.· Any ideas?· Thanks.
The only practical way to use QFNs is to solder them in place. That's what the SchmartBoard is used for. Its advantage is that it fixtures the chip for you and provides troughs for the solder to make the soldering virtually goof-proof. Otherwise, you'd be learning to solder SMTs using one of the more difficult packages to work with.
One final note: You're dealing with VHF frequencies. This means short, direct connections. So do the entire project on the SchmartBoard, if you can, rather than transitioning to perfboard.
Post Edited (Phil Pilgrim (PhiPi)) : 1/4/2010 12:38:49 AM GMT
Leon
Amateur radio callsign: G1HSM
