Debugger and FSRW not playing well :(
Hey everyone,
I'm doing a project where I need to read and write to SD, SDHC, and/or MMC cards. I'm actually writing my own FAT32 object for the project, as the latest FSRW FAT16/32 driver isn't adequate for everything I need it to do (on top of this I'd like to actually learn how FAT works [noparse]:D[/noparse] ). I have, however, been using the sdspiqasm object that FSRW uses because re-writing that would just be reinventing the wheel.
Unfortunately, I'm running into a problem where when my board is plugged into the computer and I am using a Type 2 SD card the SD driver freezes up EVERY OTHER power cycle (so flipping the power switch off and back on solves the problem, but if I do it again it freezes up). After hours of debugging, I found that sdspiqasm was reporting card timeouts.
The problem doesn't occur when I use Type 1 SD cards, SDHC cards, or MMC cards, OR when I unplug the Propeller from the computer. Simply pushing reset also doesn't induce it...the power must be cycled.
Here is what I need to know:
Is there anything that happens between the Propeller and the computer that would cause timing issues every other power cycle?
Any and all help is appreciated, as this is making development difficult!
Thanks!
Thanks!
I should note that I did modify the sdspiqasm code to not perform an abort everytime a problem is found, but rather simply return an error code to my FAT32 object. That way the program doesn't just stop if, say, no SD card was inserted. I did test to make sure that my modifications weren't causing the error by using an unmodified version of the program and found that it made no difference.
I'll poke around more and see what I find
Jonathan
lonesock
Piranha are people too.
http://forums.parallax.com/showthread.php?p=824166
Turned out that "off" wasn't really off. The USB connection was supplying just enough power to keep the SD card confused.
