Parallax 4x20 LCD (test) NOT WORKING
Hi,
I got my Parallax 4x20 serial LCD in the mail today and uppon switching it to "test" mode and connecting a regulated 5V supply from the proto board I get random black squares on the display and nothing else. I have changed the contrast and all this does is change how dark the squares are.
Has anyone had this happen to them or know how I can resolve the issue.
Thank you
"powered by Propeller" domed stickers $1.50 - Find them here
Thank you
I have attached a photo of what it is doing.
Sorry for the bad quality, I used my phone.
Hmmmm.....that doesn't look good.
I would think something is definitely wrong.
You may have to wait for Parallax to answer this one.
James L
James L
Partner/Designer
Lil Brother SMT Assembly Services
Are you addicted to technology or Micro-controllers..... then checkout the forums at Savage Circuits. Learn to build your own Gizmos!
I figured this shouldn't be the case in "test" mode. But just a thought.
Now that I do not know.
I would think that with power and ground. The display would normally just show a cursor, waiting on a command, but I may be wrong.
With RX floating, it may cause problems. You could tie it to ground to see what happens. That shouldn't hurt anything (I'm guessing here.....)
James L
James L
Partner/Designer
Parallax?
I knew something was wrong. With the propeller the pins start in a state which would cause the RX pin to float. That doesn't do what you show.
So.....you are right.....it's Parallax time.
James L
James L
Partner/Designer
I didn't think to ask but did you solder any connectors to it? If you did just double check for shorts ,, just a thought I hate getting bad parts you want to believe its anything but broken so your mind tries to think up stupid stuff even though deep down you know its a bad part LOL
Using a two wire lead with socket that plugs into the LCD pin header.
I kinda figured it was DOA, just hoping that it wasn't lol.
Have sent off an email to parallax requesting a new part, will have to wait till they get back from holidays.
You're not alone, I have the same issue. (pic attached)
Reco
