Unique ID
Using SPIN, it is possible to to CHIPVER to get the Propeller's version number.
However, is there a unique ID from chip to chip, and a method for recall?
(like a serial number)
V := chipver
That is a useful question........I too would like to know this.
James L
James L
Partner/Designer
Lil Brother SMT Assembly Services
Are you addicted to technology or Micro-controllers..... then checkout the forums at Savage Circuits. Learn to build your own Gizmos!
*Peter*
I can't have everything in a Propeller that I want, but it definitely has enough..
I guess I'll serialize the EEprom.
James L
James L
Partner/Designer
Now I wish the Prop chip had a tiny flash memory inside somewhere... Just think of the possibilities!
Post Edited (humanoido) : 12/29/2009 7:01:45 AM GMT
Nope,
The propeller memory (volatile) is emptied when powered off. You would need to have the ID stored in the propeller eeprom itself. The problem with that, is the normal security issue. It could be read with a savvy person with a I2C logging system.
If your not using an eeprom, how is the propeller loaded for operation?
James L
James L
Partner/Designer
I see....this prop must be being feed it's program from another prop (you being the super computer type of guy).
I'm not sure how you could do that, unless you use some of the I/O to give it an ID like an eeprom would (or something else on an I2C bus).
Would that work? Like using P0-P3 to address the propellers? Then the program could let each chip decide where it is in the matrix.
James L
James L
Partner/Designer
Post Edited (James Long) : 12/29/2009 7:44:23 AM GMT
My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
Leon
Amateur radio callsign: G1HSM
Ok, so far we have some basic ideas.
* load a unique ID into EEPROM
* Use prop pins to read an external device
* Wire an external serial ID chip to the circuit
* Read a unique USB circuit for each chip
* Another idea, a self incrementing serializing code that changes each time it loads into a chip on the array. The loading sequence maintains the chip position in the array while the increment determines the serial number ID.
So... we think there is absolutely nothing inside the propeller chip that can be prodded to become unique and serve as a serializing derived number with repeatability...
And *take 4 pins with resistors to provide a 4 bit address for the propeller using I/O.
James L
James L
Partner/Designer
Ways to Develop a Unique ID for the Propeller Chip
* take 4 pins with resistors to provide a 4 bit address for the propeller using I/O
* Self incrementing serializing code that changes each time it loads into a chip on the array. The loading sequence maintains the chip position in the array while the increment determines the serial number ID.
So... we think there is absolutely nothing inside the propeller chip that can be prodded to become unique and serve as a serializing derived number with repeatability...??????????
I still have hope that there remains some method to access an internal feature towards the goal of uniqueness. I still think there is some process inside the Propeller chip that has some degree of uniqueness, even if it's a randomness, signal orientation, rc uniqueness, or a result from a variation in substrate.
There are always variations in manufacturing processes. If not, then there would be no need to test chips. Even the internal RC circuit should vary. If it did not, then Parallax would not post a range of possible clock frequencies when engaging the internal circuit.
I think this may be one key to solving this chip's "internal" challenge. It's internal and it can vary from chip to chip based on the resistor capacitance combination. I think this is covered in the two Propeller books as I recall. I am sure this effect can be measured from chip to chip.
Thinking something is fine but it is of no use unless it is based upon something factual and can be applied. Thinking that there is some process inside the Prop is quite different from knowing if there might be but variations in tolerances is hardly a way of trying to classify a degree of uniqueness. The RC oscillator is never a measure of "uniqueness", it's just something that varies with temperature, voltage, and process but is never constant. There is no unique process, it is just a sliver of silicon, that's all and silicon can have unique IDs embedded in them but this is usually a special (expensive) process. Sure, pay Parallax enough (I don't mind if you do) and they will even embed Flash in there for you too. I love reading Sci-Fi novels where they can wish and want and somehow come up with something impossible but unfortunately we have to live and breathe in the real world where things don't happen that way.
For networks I have software that generate a random number on each node during the enumeration process (a bit like a MAC address) and the "master" successively approximates addresses until it gets a single response after which it assigns a sequential ID (bit like a IP address). As there is always a remote chance that two or more devices have the same random address there is also a resolution process where those conflicting nodes generate new random addresses. I have also used DALLAS single-wire ID chips as well and even used a similar approach to assigning local addresses with them. Failing that there is always the DIP switch approach, sure n certain.
So, please separate fact from fairy-tale and research it yourself so that you have some basis for your "beliefs".
*Peter*
Propeller Forums RSS Feed!
Gadget Gangster - Share your Electronic Projects
Nick,
That is a great idea.......didn't think of that one. Saves 3 pins from my scenario.
James L
James L
Partner/Designer
Consider a linear array of Props linked via some serial connection, Prop to Prop to Prop...horizontally.
1) Each Prop sends a "who am I" ID request to the neighbour on its right and then waits for a reply.
2) Each Prop gets a reply from its right hand neighbour which it uses as its own ID in future communications.
3) Each Prop increments it's own ID number and uses the result to return as an ID in reply to the "who am I" request from it's left neighbour.
4) The most right hand Prop has no neighbour to the right. So it times out the "who am I" request and uses zero as it's own ID.
This can be extended to a 2 dimensional grid easily. Three dimensions and hyper cubes get progressively more tricky.
Problem comes with rings, spheres, toroids etc where there are no "edges" and everyone has neighbours in all directions. Looks like you have to create some artificial "edges" as reference, points, lines, planes etc in that case.
Well....I would say the first prop with a program would constitute an edge. So all edges would align there. Considering one of the props has to start the cascade.
I have a problem with some of this. How are the props going to power up. Since they must receive a program from somewhere.......where will they receive it?
You can not use one eeprom.......too many talking at once (no program internally to tell them not too). They can't ask their neighbor.....it may not have a program yet.
I would think this will need a cascade power up sequence as well. Each prop would turn on it's neighbor then give him/her the program.
I come up with the worst problems.......... I wouldn't want to have to manually power up the system every time it was shut down, or needed a new program.
(sorry....didn't mean to ask an slightly off topic question.......but I would like to know).
James L
James L
Partner/Designer
1) A master Prop that can reset and program all the others or
2) Chaining Props so they can reset and program their neighbours.
Given the chain loading it would be possible to put a unique ID into the binary images prior to booting your neighbour with it. Sort of combine the ID generation process with the booting.
That is what I was getting at.
If it is a cascade power up (which I think would be needed), each Propeller could be programmed with a unique ID. I wouldn't think you could program all of them at once from one. This is due to the capacitance of the traces(single bus...all RESn tied together). The closest will ack before the others do (if they ack...I really don't know....never read into it).
I guess you could have a master tied to each other prop reset using an I/O pin for each one (RESn), but that would use a bunch of I/O. I would think the chain would be better to prevent a lot of I/O wasted.
Just rambling on the whole idea.
James L
James L
Partner/Designer
Research this yourself if you want to know. I don't care about this particular RC oscillator's characteristics, it's an RC oscillator, the datasheet says what it says.
@Nick: For a smaller number of nodes it is possible to use an RC network (yes, I've done that too). But caps vary widely with temperature and age so you need a good margin and different values of resistors, not a good thing for production though. There is even the I2C SAA1064 which using one address pin selects 4 devices.
*Peter*
Way way back I posted an idea for a chain loader that as each Prop loaded up it would use a location in eeprom for it's address and then increment that for the next prop. The last prop on the line would have a pullup resistor on it's control line and know to zero that location instead of incrementing it. Each control normally has a pulldown on it to prevent the next prop from booting until enabled. The prop's all share the same eeprom.
RESET IN
>[noparse][[/noparse]reset PROP #1 control]
>[noparse][[/noparse]reset PROP #2 control]
>[noparse][[/noparse]reset PROP #3 control]
>[noparse][[/noparse]reset PROP #4 control]
pullup resistor
*Peter*
Basically what I said, just a different way to implement it. All the props couldn't load at the same time.
You could basically do the same thing prop to prop, but would take more code.
James L
James L
Partner/Designer
The PropTool doesn't provide such hooks, but you can jump through hoops to achieve it, or maybe use one of the third-party compilers and loaders and insert a step in the middle.
Ask nicely and one of the third-party developers may include a named 'constant' which gives a different value every time it runs.
Post Edited (hippy) : 12/30/2009 1:18:29 PM GMT
It would automatically increment·all files·for each save or archive.
Signature space for rent!
Send $1 to CannibalRobotics.com.
24 bit LCD Breakout Board now in. $21.99 has backlight driver and touch sensitive decoder.
