To ground or not to ground...
I'm making a board with the FT232 chip.· I noticed that the Propeller Demo Board schematic (rev D/E/F) has the USB Mini B connector's pin 5 grounded.· Is that the connector's housing?· Should that pin be grounded?· How does one know when to ground it?
Thanks!
Post Edited (Lord Steve) : 12/27/2009 7:32:36 PM GMT
Thanks!
Leon
Amateur radio callsign: G1HSM
Post Edited (Leon) : 12/27/2009 9:04:42 PM GMT
Similar to any other kind of serial bus, for EMI or ESD reasons, you might have to capactively couple 0V of the cable to the shield of the USB cable to a metal case of the device. But hobbyists really don't have a need to delve into this, and there's no bulletproof way to do this across the board.
I really don't think it starts to matter one way or the other until you start putting in electric motors (rumble feature, hard-drive motors) or audio related things.
My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
I think, but do not know for sure, that the 5th pin is ground and the 4th is N/C (as shown on the DemoBoard CCT ). I would "ground" the shield, at the prop end via a 100K or 1M resistor in the hope that these touch first and would get rid of static before the delicates touch.
A good 10% of the busted, firewire conected, video stuff we get is static damage. Straight up the chip, for a warentied repair a new card, £500 thankyou very much.
Style and grace : Nil point
An empirical solution that I have used successfully: tie the Screen at the 'receiving' end to USB ground via a 1 Megohm resistor in parallel with a 4n7 capacitor.
This was in an application where my board connected to an automotive PC host, over which I had absolutely no control. The kit was installed in buses or trams by unskilled labourers to no particular specification unfortunately.
In an ideal application, there's an EMC debate to be had; but in this instance I preferred to have some control over the Screen rather than none.
T o n y
Grounded means the Connector is a type A (= Host), not connected means it is a type B (=Device).
So you should not connect it for an FT232 chip.
The attached picture comes from Wikipedia. As you see, Pin5 is Ground and Pin4 is the ID.
Andy
24 bit LCD Breakout Board now in. $21.99 has backlight driver and touch sensitive decoder.
The shield should be connected on one end only (to prevent the ground loop problem, but to remove noise off the shield).
The Master should have the shield connection. Any slaves would let if float.
I pretty much agree with mctrivia.
James L
James L
Partner/Designer
Lil Brother SMT Assembly Services
Are you addicted to technology or Micro-controllers..... then checkout the forums at Savage Circuits. Learn to build your own Gizmos!
I am a bit confused (easy ) I assumed that the fifth pin was the pin5, and so as the demo board cct shows I would conect that to ground at he prop end. The shield should be loose bonded for discharge reasons via a high value resistor and possibly a small cap. The other pin (pin4) was a mystery to me until you showed the diagram, but the demo board shows that unconected. So hopefully the question was about the shield and not the Pin4. Perhaps the shield should have been named "Pin6" to prevent this confusion.
The normal non-mini has only the four conns so that will only have 5 points of contact, the fifth being the shield, perhaps that was the question.
Post Edited (Toby Seckshund) : 12/29/2009 10:37:11 PM GMT
