ZiCog a Zilog Z80 emulator in 1 Cog - Page 26 — Parallax Forums
1232426282941
    edited 2009-12-27 04:36
    Thanks Drac.
    My opinion is that we can make the V2.0 release (V1.0 will be for the DemoBoard which will only get the instruction updates as we needed to fork the code). It is a simple matter for incremental releases.
    We are implementing a number of undocumented instructions and it is only code utilising these that fail - am I correct in this assumption???
    Other thoughts???
    edited 2009-12-27 05:30
    I don't think the problem is undocumented instructions - I think these are quite common ones. EX and EXX for instance are used extensively in BBC Basic.
    The problem is we don't have a program to test them individually. At one stage I resorted to just picking random instructions and trying them. There are some IX and IY ones I'd like to test a bit more.
    I should add that you might want to add the code to print the alternate registers. That is in the 'main' program and you need a printout of the alt registers if you are going to test them!
    edited 2010-01-12 14:16
    I have posted a RamBlade version of ZiCog (v150)on the RamBlade thread at the top. You can compile ZiCog for the TriBlade with a #define change - take a look at the xtal frequency as I think the TriBlade has it set for 6MHz.
    The new *.DSK SD files are on my website www.cluso.bluemagic.biz. They are just ZICOG_dn.DSK renamed to ZICOG_d.DSK and I have included Drac's A & B drives plus Supercal and Vedit/Pascal (TurboPascal) disk files also. Do NOT copy any of the *.BIN files (PropCMD.BIN, TEST_RB.BIN, ZICOG150.BIN, BOOTPROP.BIN) as they are compiled for the RamBlade hardware!!!. The source for these are on the RamBlade thread. You can recompile with the TriBlade option selected if you wish.
    edited 2010-01-15 12:03
    Hi Heater,
    I'm deep inside coding some assembly, so giving a number of instructions a real workout. I'm still not 100% of my code here, but I don't seem to be getting any change to the registers with
    ADC HL,DE (hex opcode ED5A)
    I checked in the source code and this opcode has a * in front of it "'*ADC HL,DE ED5A"
    So do some others that I know are not coded (and probably never need to be), but I note that the ADC series eg ADC HL,BC and also the 16 bit SBC series SBC HL,DE
    Firstly, does the * mean these are not coded yet?
    Could you have a look and test if these work?
    The handful of 16 bit ADC and SBC instructions are very useful with 32 bit math routines in assembly.
    Addit: more testing - ADD HL,DE works but ADC HL,DE does not work. Ditto ADD HL,BC works but not ADC HL,BC
    There are 8 instructions in this group
    ADC HL,BC
    ADC HL,DE
    ADC HL,HL
    ADC HL,SP
    SBC HL,BC
    SBC HL,DE
    SBC HL,HL
    SBC HL,SP
    More research:
    the dispatch table jumps to 'double_add_hl_cy and double_sub_hl_cy
    decrement_word          sub     data_16, #1
                            jmp     #vect_3
    double_add_hl_cy        'FIXME for Z80
                            'FIXME Should set most flags !
    double_add_hl           rdword  alu, h_reg
    double_add              mov     aux, alu                   'Take a copy of alu before operation for AUX carry determination
                            add     alu, data_16
                            test    alu, mask_bit_16 wz
                            muxnz   flags, #carry_bit
                            andn    flags, #%00000010
                            xor     aux, data_16
                            xor     aux,alu                    'Determine the auxillary carry flag
                            test    aux, aux_bit_shifted wc
                            muxc    flags, #aux_bit
                            mov     data_16, alu
                            jmp     #vect_3
    aux_bit_shifted         long    (aux_bit << 8)
    double_add_ixy          rdword  alu, xy_reg
                            jmp     #double_add
    double_sub_hl_cy        'FIXME for Z80
    Oh No!! No code in either of those.
    Next problem, I'm out of longs and I think your code is pretty close too. So this would need to be overlay. How would such code work?
    Post Edited (Dr_Acula) : 1/15/2010 12:21:10 PM GMT
    edited 2010-01-15 13:27
    Drac: What programs are using these instructions?
  • heaterheater Posts: 3,370
    edited 2010-01-15 13:29
    Dr_A: Hope you like the FIXME comments. Many years ago I was told about some guys looking for a bug in some contract software engineers code. Eventually they homed in on the problem and found the comment "Insert correct code here".
    You have just found my version of that.
    Re: the "*", a long time ago I was putting asterisks next to ops that have passed certain criteria. Have they been implemented at all, do they do basic thing that they should, do they set the flags correctly etc.
    That * system broke down a long time ago as things were moved around, broken, unbroken etc etc. It's probably better to ignore / remove all those stars.
    I'll try and have a look at this when I get home this evening.
    edited 2010-01-15 14:03
    Re Cluso: "Drac: What programs are using these instructions?"
    A/ the ones I'm writing!
    ; 16 plus 16 bit add DE+HL=DEHL
    ADD16:
         LD BC,0
        OR A
        ADC HL,DE
        EX DE,HL
        LD HL,0
        ADC HL,BC
        EX DE,HL
        RET
    But who knows, these are pretty useful instructions, as they are ADD but add the carry bit as well, so you can use that carry bit to cascade adds and hence do 16 or 32 or even higher bit math. So they are bound to crop up in other code as well.
    Re heater. Yes, I had a chuckle when I traced through the code and found "FIXME" Thanks++ for having a look at this.
    edited 2010-01-15 14:30
    Better than a programmer I knew that put some "little red pills" as a test in a pharmaceutical companies computer and later saw a real order come out for some "little red pills". I think he was then in desperate need of some "heart attack pills" LOL
  • RaymanRayman Posts: 15,469
    edited 2010-01-15 15:16
    I'm thinking of trying your CP/M out using a RAMBLADE... Assuming I actually get it working... Where do you find CP/M software (like Wordstar and Basic) ?
    My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
    edited 2010-01-15 18:52
    Rayman: Most of the CP/M programs we have been playing with come from the huge collection that is all packaged up nicely on floppy images for the AltairZ80 simulator project here: www.schorn.ch/cpm/intro.php
    Now ZiCog does not support that floppy format any more so we have to use the AltairZ80 simulator under Windows or Linux to copy all the files to the 8MB hard disk images that ZiCog uses. They are exactly the same format as the AltairZ80 so it's quite easy.
    I keep meaning to create ZiCog HD images of all those AltairZ80 floppies and putting them on the net somewhere.
    But when you get there just ask and one of us could do it for you.
    Drac has since dug up some other things like BBC BASIC that can be copied to the HD images using cpmtools under Windows or Linux.
  • jcwrenjcwren Posts: 44
    edited 2010-01-15 19:03
    I have an IMSAI 8080 with 2 Qume Datatrak-8 1.2MB 8" floppies on it. I've had it since it was new, but haven't fired it up in YEARS. Maybe it's time to dig it out and do a magnetic coercivity test on the floppies.
    I've got FORTRAN compilers, COBOL, BASIC, Forth, C, PL/I, PL/M, assemblers, Wordmaster (much better for program editing that Wordstar), and quite a bunch of other stuff.
    --jc
    edited 2010-01-15 19:05
    My dad's going to see if he has any CP/M floppy disks in storage... But even if he finds some, it may be trick to get them onto a PC...
  • Ron SutcliffeRon Sutcliffe Posts: 420
    edited 2010-01-16 01:58
    I downloaded Forth from the www.schorn. I am not sure how to get these two files from the PC to a free CPM Hdisk on the SDcard.
    I can copy the files to the SDcard, but then CPM would not see these files. I see Drac created two disks. Is this done through the CPM BIOS ?
    Ron
    edited 2010-01-16 02:41
    re CPM disk images for SD cards (in HDisk format for ZiCog CPM)...
    On my website www.cluso.bluemagic.biz is a zip file of the images required for RamBlade. Be careful that the binary images are for RamBlade, not TriBlade/ProtoBlade/DracBlade. However, the .DSK files are identical for all the ..Blades as they are just cpm images.
    The files there are the A drive we are using (CPM2.2) plus a VEDIT & TURBOPASCAL combined DSK, a SUPERCALC DSK, and 2 of Drac's CPM disks which include wordstar and xmodem, etc. There is a writeup in the RamBlade thread.
    These should provide a great start. Just recompile with whatever DSK files you want. Copy them over using PIP if you wish. There are also blank DSK files for B,C,D,E,F,G,H drives. Note that G & H are not 8MB files (please ignore them for now). I made C 32MB but to use any more than 8MB·the hd parameter block needs changing.
    edited 2010-01-16 03:04
    Thanks Ray, I have no problem with Wordstar and the rest of the stuff, I even used the BDS C compiler to compile and link small file, works fine.
    But how do I get Forth or any CPM2.2 file (in 8Mb file format from www.schorn) from my PC to say B: drive on the CPM SDcard ??
    Ron
    Post Edited (Ron Sutcliffe) : 1/16/2010 3:18:24 AM GMT
    edited 2010-01-16 03:57
    Two ways to transfer files.
    1) via the altair simh
    Create a new directory. Put some floppy simh .dsk images in there (I pretty much downloaded the whole site)
    Create a batch file AltairAll.bat in notepad. In that file add one line
    altairz80 all
    Create the 'all' file. No extension. Use notepad. Put this text in:
    d tracks[noparse][[/noparse]0-7] 254
    attach dsk cpm2.dsk
    attach dsk1 basic.dsk
    attach dsk2 app.dsk
    attach dsk3 sbasic.dsk
    attach dsk4 bdsc160.dsk
    attach dsk5 tools.dsk
    attach dsk6 wordstar.dsk
    attach hdsk0 i.dsk
    attach hdsk1 j.dsk
    attach hdsk2 k.dsk
    attach hdsk3 l.dsk
    set cpu 64k
    set cpu noitrap
    set cpu z80
    set cpu altairrom
    set cpu nonbanked
    reset cpu
    set sio ansi
    set sio nosleep
    boot dsk
    bye
    You can modify that as needed, and leave out attached floppies if you like. It does need cpm2.dsk and i.dsk
    As an aside, this was my "super Z80 computer" that never existed in real life. I made this in 2008. Then heater and Cluso go and create it a year later!
    To run the super computer, just click the batch file. I find it very helpful for quicker compiling etc.
    There are programs called W.COM and R.COM to move files between the PC and the drives.
    Now, to get files on and off you disk image on the propeller,
    rename i.dsk as i.tmp
    copy a.dsk from the sd card to the working directory
    rename it i.dsk
    copy files from the floppy images to drive I with PIP
    rename i.dsk back to a.dsk
    put it back on the sd card
    rename i.tmp as i.dsk
    2) What a pain that is!!!
    So - do you have a copy of XMODEMF.COM
    If not, see attached.
    You need to get this program onto drive A. Maybe backup onto a few other CP/M drives. To get it onto the drive A, just once you will need to do step 1 above.
    But - once it is on drive A, you can then use any terminal program to transfer files over.
    Eg on CP/M
    XMODEMF R MYFILE.TXT
    where the command is R for receive and S for send
    Then on teraterm, File/Transfer/Xmodem (don't use File/Send, it doesn't work)
    XMODEM is great for transferring one or two files.
    Disk images are great for transferring many files.
    edited 2010-01-16 04:13
    Thanks Dr_A
    Now that makes sense.
    I will give it a go.
    Ron
    edited 2010-01-16 04:16
    Drac & Ron,
    I am not sure if I pip'ed XMODEM over to the A drive. However, As I said, I included your latest drives A & B from a week or so ago so Xmodem is on there so it can be pip'ed to the A drive easily.
    I am also working on using SphinxOS and the simple method of file xfer mpark used. The I hope to add this to ZiCog as well, but I will need your (Drac) help in getting it onto a cpm disk file. FAT16 is easy for me.
    edited 2010-01-16 04:42
    Fine Ray
    The SphinxOS sounds interesting, but for now I just want to get a few things going. ( Forth and Catalina etc) We leave Australia in couple of weeks time. I am not sure how much Internet access we will have for couple of months.
    Ron
    edited 2010-01-16 12:22
    @Drac·el al
    I did not get anywhere, with that. I have a folder with two files in it one·of which is Forth.dsk file.· I downloaded the folder from www.schorn. ·I somehow need to extract the individual files from this disk image so that I can move them down to cmp2 disk C:·· I don't have any problems using zmodemf to move files from my PC folder to cmp2 C: disk·, but I still cannot figure·how to extract the files from the disk image. I tried the batch file technique but no luck.
    I could recompile Zilog and name the C: "forth.dsk"· but don't want to do that.
    Ron
    Post Edited (Ron Sutcliffe) : 1/16/2010 12:27:50 PM GMT
    edited 2010-01-16 12:48
    Recompiling zicog and naming c as forth.dsk won't work unfortunately as the forth.dsk is a floppy image and you want a hard disk image.
    I did step 1 as above with a blank drive i, and did a PIP *.* and renamed it c.dsk. File is attached.
    (we can get away with zip files of 8mb hard images with the max forum post of 2048kb, as almost all the file is E5 and zip compresses that with 97% efficiency or more.)
    So, give this attachment a try.
    zip
    238K
    c.zip 238.4K
    edited 2010-01-16 13:06
    so you are saying just delete ZILOG_C.DSK file and load this file to SDcard and Rename iback to ZILOG_C.DSK
    Is the correct?
    Ron
    edited 2010-01-16 13:21
    I would rename the old ZICOG_C.DSK something else. It is not a good idea to delete any files on the SD card as we require all files to be contiguous and this could break a file later. I suggest you use drive F for the substituted drive. C is likely to be a larger drive later.
    edited 2010-01-16 13:53
    @cluso
    Yes, Ray don't like in either, anyway it didn't work. Its just that I am not understanding something (or long forgotten CPM) so have a bit of reading to do. It will get sorted.
    I must be able to extract the disc image file with my Altair PC simulator so that I can xmodem the files to Zilog_C.dsk. The lights are on but nobody is home ATM [noparse]:([/noparse]
    Ron
    Post Edited (Ron Sutcliffe) : 1/16/2010 11:54:25 PM GMT
    edited 2010-01-17 02:01
    @Drac
    Thanks, Forth is up on cpm2. A little reading and your post·all·makes sense.·I think we need to make PC copies of· Cobol, Fortran, Lisp. Algol etc etc and post them on the net somewhere so that others can ·just do a xmodemf transfer to their prefered·cpm Hdisk.
    Ron
  • YodaYoda Posts: 132
    edited 2010-01-17 02:32
    @Ron
    Why not use the W command in SIMH and write the files to the PC and then use cpmcp that heater posted to copy the files to a zicog hard disk - pretty trivial to do.
    edited 2010-01-17 02:42
    Sorry I left you half way through - had to sleep!
    Ok, looks like you have it working. Slight confusion re the drive names, I'm using A.DSK etc as it is the shortest name and I'm trying to save hub bytes on the dracblade. But I think others might use different names eg ZICOG_A.DSK. Just a matter of looking at the prop source code to see what it is loading up. They are the same file format (and the same as drive I.DSK and J.DSK on the Altair SIMH).
    I looked at Forth - is this a Reverse Polish Notation language? My dad had a calculator that used RPN.
    Have you got xmodemf and a terminal program yet?
    Re making new drive images and "I think we need to make PC copies of Cobol, Fortran, Lisp...."
    is that "we" as in "you"? or me? *grin*
    edited 2010-01-17 02:46
    @Yoda
    That exactly what I did in the end but I had not seen heaters post.
    Drac pointed out the W command and that pointed the way.
    Ron
    edited 2010-01-17 04:03
    This is how I·recommend you get hdsk files to the SD card... (must be in hdsk format 8MB 4x128 per 512 byte sd sector)
    Put uSD card into PC Laptop (using SD or USB converter) and use Windows Explorer to
    • Rename ZICOG_F.DSK to ZICOG_F.XXX
    • Copy the new disk file as ZICOG_F.DSK to the SD card
    Put the uSD card back in TriBlade/RamBlade and boot as normal. You should now be able to do a DIR E: and the files should be there.
    Now you can PIP them across to the A: or C: drive (rename if necessary). I would prefer to build a C: drive with all these extras, but your choice.
    Syntax···· PIP C:XYZ.COM = F:XYZ.COM
    What we are doing here is sacraficing the F: drive for a temporary transfer drive which sounds reasonable to me.
    Otherwise you can use XMODEM and TeraTerm to get them across a serial link from the PC. XMODEM is available on the DRAC_A.DSK (or B) and it may already be on the ZICOG_A.DSK anyway. Use LS instead of DIR (it pauses and puts in alphabetical order).
    Ron: You should have PropCMD on the uSD so you can also do a rename on the RamBlade.
    edited 2010-01-17 06:41
    @Cluso the problem was that the that the Forth.dsk was not a hard disk img. So I had to extract the files using the PC emulator version of Altair80 and tthen use the Command W to copy the files to a folder on the PC. From there I did a xmodemf to my cpm2 c dsk.
    @Drac (your Dad uses a HP cal ?) . I prefer to use the Forth/PASM combo in general. I used F83 for years.
    I will add some extra stuff to you bat file when I get round to it or unless you do it first ---GRIN---
    Its all working
    Ron
    Post Edited (Ron Sutcliffe) : 1/17/2010 11:37:49 PM GMT
