Boe-Bot --> Does Voltage Input Change Servo Motor Speed?
I changed my batteries (again) in my Boe-Bot but this time, I put in 1.5 volt batteries, instead of the 1.2 v rechargeable batteries.
I thought I observed my Boe-Bot running around faster - is this true, does a variance in input voltage change the servo performance?
If so, why? I thought the input voltage was "fixed" with some sort of voltage regulator of some sort.
Scope
[noparse]:)[/noparse]
Scope
"A complex design is the sign of an inferior designer."
Powered by enthusiasm
