Help with human interfacing on the BS2p24
Hello all,
I have a problem. In a project I am doing I need to communicate to the BS2p24 micro. I need the micro to change a variable in the program when I turn a pot or any other mechanism that allows the variable to change. More importantly I need it to change from 0-250.
My original plan was to use a pulse width modulator and have the pulses change from 5ms-250ms. With this pulse variability I would be able to have the micro-controller change the variable I need it to by using the pulsin function that all stamps have. The thing is the max pulse the micro can read is 52ms. I need another way to interface with the micro, I just don’t know what. Please tell me you know another way.
Thank you
Thank you
10 minutes of experimenting and you'll be on your way.
Cheers,
Tom Sisk
http://www.siskconsult.com
