Question about the H-Bridge in the MSR-1 Controller
I do not seem to be getting power out of the socket of the motor A or motor B plug of my MSR-1 Robot Controller board. I am running it on two NiMH batteries (at 14.4 v 1600mAh) connected into the power plug. The board seems to be operating fine on this power, I have run it with two Ping Sensors and two continuous rotation servos and it works great. But when I tried to run a motor off the H-Bridge, no response.
Here is the code I was using:
I have been using this motor servocity.com/html/303_rpm_gear_motor.html plugged into the motor A socket. No motion from the code above or the stingray sample code.
I tried unplugging the motor and connecting a volt meter to the motor A and motor B socket pins, testing each one in case their was a problem with the motor or the plug. The volt meter registers nothing positive or negative when the code above is started or finishes.
Any suggestions? Could I have burned out the H bridge? Are those batteries too much? Does it matter that I am using one motor socket and have nothing plugged into the second one?
George
My Robots
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
PUB Init
dira[noparse][[/noparse]27..24] := %1111 ' Set P24 Through P27 To Output
outa[noparse][[/noparse]24] := 0
outa[noparse][[/noparse]25] := 1
outa[noparse][[/noparse]26]:=0
outa[noparse][[/noparse]27]:=1
waitcnt(clkfreq * 30 + cnt) '30 Second Pause
George
My Robots
Jax
update:
Try removing the outa[noparse][[/noparse]24] and the outa[noparse][[/noparse]26] from your list if you are just trying to move the motors.
If a robot has a screw then it must be romoved and hacked into..
Post Edited (GWJax) : 12/21/2009 6:06:28 PM GMT
I doubled checked and yes I have the switch in the power on/ motor on position. I put a picture of the board layout and a video of testing with a motor and a VOM at the bottom of www.trailofdestruction.com/combot.htm.
I tried this with the code for outa[noparse][[/noparse]24] & outa[noparse][[/noparse]26] in and out. It did not seem to matter. I am not sure what you mean by the frequency, do you mean the interval at which you change pin states? In the video I set the pin states as above, wait 15 seconds, and then run the servo forward (so I know when 15 seconds are up.) It also shows that the power is working.
Thank you very much for your help. Any ideas?
George
My Robots
It's unlikely there's an issue with the H-Bridge, but being we're so close to being closed until January, it might be a good idea to call Tech Support as soon as possible.
Chris Savage
Parallax Engineering
Check out the new Savage Circuits TV!
Thanks, I will probably call after the holiday. Just wanted to check first in case their was something simple.
G
My Robots
Rest assured, if something is wrong with it we will take care of it. I apologize it took us so long to get this far. It may just be one of those weird things.
Chris Savage
Here is a shorten version of your program that works great..
CON
PUB Init
dira[noparse][[/noparse]25..24] := %11 ' Set P24 Through P25 To Output
outa[noparse][[/noparse]25] :=1 'Start motor A forward
outa[noparse][[/noparse]25] :=0 'Stop motor A
repeat
