X-Band Motion Sensor and Plastic
Hi Everyone,
I am looking at purchasing an X-Band Motion Sensor and the manual says it works through walls, I am looking at mounting it in an ABS case and am wanting to make sure that it will work through this.
Can anyone please tell me if this is the case.
Thank you
"powered by Propeller" domed stickers $1.50 - Find them here
Thank you
I am going to go ahead and order one. Will let you know how I go.
That module will have no problem seeing through ABS plastic. We actually ran a test here to see if it could sense through sheet metal, and it surprised us all when it did. Now you have to take into account that the modules range was diminished by almost 100%; but it was the fact that it could see through it that was impressive. Good and easy unit.
Hope this helps,
Respectfully,
Joshua Donelson
www.parallax.com
