boe bot help.
I'm new to· robotics and im working on ch 4. I just finished pg 145 "Movement with variables and one subroutine. Well, Im not understanding the next project on p 146 which is titled Your turn "dead Reconing".
· Basically, the book is saying to modify the Movement with variables and one subroutine program with the
values from activity 2 pg 132.· I have my pulsout values from pg 132.
·My question is on my navigate for/next loop. Im not understanding the pulsout 13, pulseleft and pulsout 12, pulseRight.. Shouldnt i be able to declare my values in the GOSUB routines above the for/next loop and state in my for next loop (for example)·:
Navigate:
· for counter = 1 to pulseCount
···· pulsout 13, pulseforward····················· ' Move Forward
···· pulsout 12, pulseforward
· next
· pause 200
· for counter = 1 to pulseCount·················· ' Turn left
····· pulsout 13, pulseleft
····· pulsout 12, pulseleft
and so on. I guess im not understanding this "your turn" exercise,,any help for me would be very much appreciated.· thank you
Navigate:
· next
· pause 200
A couple of comments when looking at the code you posted (I haven't looked the exercises up in the book though):
1) When working with servos, you need a delay between pulses. Usually this delay is about 20ms. Don't forget to add one into your loops.
2) If you send the same pulse value to both servos, the boe-bot will just spin. Since the servos are mounted opposite each other, a high value on one side will make that side go forward, while a high value on the other side will make that side go backwards. Hence, your constants (or variables, I can't tell) pulseforward and pulseleft will simply make the boe bot spin
You can try this with a simple program. Something like this might work (untested, uncompiled so there may be errors)
Redownloading this program multiple times with different values on the pulsouts will allow you to experiment.
Powered by enthusiasm
