Switching a P-channel Mosfet
Hello, I'm quite new here and am hoping to find some help with a circuit I plan to build.
I have a P-type Mosfet (IRF4905) that I would like to use to switch 12v going to a small pump. I've confirmed that using the mosfet works when I use a 1M ohm pull up resistor to 12v and ground the gate. The pump turns on and runs fine.
My question is will it be ok to hook up a pin of a BS1 to the gate of the mosfet? I will leave the 1Mohm pull up resistor on 12v. Can the stamp handle grounding the 12v pull up resistor? Will the stamp's pins be ok with being pulled high with 12v?
If it won't be ok, would someone suggest a way that I could make it work?
I would lower the 1Meg to something like 10K, and use a reverse biased diode across the S-D MOSFET terminals.
Additionally, to prevent the 12V from interfering with the 5V I/O I would use a small NPN transistor configured as an Emitter follower.
Beau Schwabe
IC Layout Engineer
www.datasheetcatalog.org/datasheet/irf/irf4905.pdf
Beau Schwabe
IC Layout Engineer
Thank you!
