New gaming platform - HybridX3
Coley
I've had this under wraps for a while but there seems to be a current proliferation of multiprop boards appearing so here is my effort.
It's a variation of my Hybrid board and is primarily aimed at gamers...
It features 3 Propellers
Prop 0 - Main CPU
Prop 1 - I/O Prop
Prop 2 - Graphics Prop (compatible with PropGFX Lite)
Peripherals
SD Card Interface
PS/2 Keyboard and Mouse Ports
2 x Playstation compatible expansion ports
VGA video
Composite Video
Stereo Audio
Hydra/Hybrid compatible expansion port
I'm sending this for PCB prototyping this week and am looking to gauge how much interest there would be in making it available for sale.
edit:
added port for uController PropNIC card
Prototypes made and currently being tested......
PropGFX - The home of the Hybrid Development System and PropGFX Lite
Post Edited (Coley) : 3/24/2009 9:04:26 PM GMT
Prop 0 - Main CPU
Prop 1 - I/O Prop
Peripherals
SD Card Interface
VGA video
Composite Video
Stereo Audio
edit:
'09 is the year of multi-propeller platforms! Tri-blade, now this!
How about a design which has a PropGFX setup onboard, another Prop for dedicated sound, and a third
for main gameplay. (I'm started to perspire just thinking about it.) [noparse]:)[/noparse]
Awesome!
OBC
New to the Propeller?
Check out: Protoboard Introduction , Propeller Cookbook 1.4 & Software Index
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card connected? - PropDOS
Post Edited (Oldbitcollector) : 3/8/2009 1:26:10 PM GMT
Yup!
That's exactly what this is in a nutshell...... lol
Coley
Robert
SL1, SL2 and SL3 are uncommitted spare I/O so you could make a header up, I'm not familair with the Hydra network port, how many I/O does it utilise?
Coley
Robert
Just think of all the cool games we could do on this setup...
Gridrunner 2009 perhaps...
Living on the planet Earth might be expensive but it includes a free trip around the sun every year...
Experience level:
[noparse][[/noparse] ] Let's connect the motor to pin 1, it's a 6V motor so it should be fine.
[noparse][[/noparse] ] OK, I got my resistors hooked up with the LEDs.
[noparse][[/noparse]X] I got the Motor hooked up with the H-bridge and the 555 is supplying the PWM.
[noparse][[/noparse] ] Now, if I can only program the BOE-BOT to interface with he Flux Capacitor.
[noparse][[/noparse] ] I dream in SX28 assembler...
/Bamse
That looks an excellent design, do you have the board size measurements easily to hand?
So PropGFX will just slot in to the Hydra Compatible expansion with the board you showed us all previously?
Is great to see that you have VGA output on prop_2
I would certainly take two PCBs if you decide to make this a commercially available product.
With Regards
Mike.
@Bamse
Baggers is really excited about this board, he has plans for an enhanced audio subsystem like the PropGFX is for enhanced graphics.
@Mike_GTN
Thanks, PropGFX will be capable of being utilised on Prop_2 we envisage using the expansion for for extra memory by using the Hydra RAM expansion card.
It will be available in PCB form or fully assembled with PropGFX API/Firmware loaded onto Prop_2
Coley
Edit:- Board size is 152x120mm
Post Edited (Coley) : 3/8/2009 7:09:19 PM GMT
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
I guess I should have been a bit more specific. I was referring to the RJ-11 network port that is standard on all the Hydra boards (not the Ethernet one). If memory serves correct I believe the Battlezone clone can use it to connect two Hydra's. Didn't see a provision for that on your board. Did I miss it? If it isn't there I thought it might be a nice feature if you added some jumpers to enable that and perhaps a small header that could be used to go to an external connector.
Robert
Digikey part number EDC395202-ND
parts.digikey.com/1/parts/158562-conn-cardedge-20pos-100-x-200-395-020-520-202.html
I must admit I do modify it slightly by trimming off the sides but it works great....
Regarding the Hydra Net port, how many people actually use it I wonder.......
Like I said earlier there is a 4 way I/O header spare that you could make a connection to, I guess it would be easy for me to add 3v3 and gnd to it to make it more useful
Coley
www.tdswieter.com
One could get a little more 'mileage' out of say, an·IR Transceiver or one of the many ethernet adapters available (The Hydra one or the one from uController.com).·
Post Edited (trodoss) : 3/10/2009 7:45:32 PM GMT
Looks great. Looking forward to it. My Hybrid 1 is working great,.
Aka: CosmicBob
I've updated the top post with new information and pictures.
Coley
Looking great! Glad to see that it's almost all through-hole components.
Any ideas for prices yet? I might be interested.
Share the knowledge: propeller.wikispaces.com
Lets make some music: www.andrewarsenault.com/hss
No idea on pricing yet, a lot depends on how well we can make it fly!
Baggers has already got the I/O subsystem for Prop_1 started and has converted the code for PropGFX Lite to run on Prop_2
I am working on a surface mount version that is expected to be around the same size as the demo board this will have the firmware preloaded to run as an SBC.
I could offer the thru hole bare PCB if people are interested in making their own.
@Ym2413a
Andrew! Long time no see, you back on the scene or still busy?
Coley
This project isn't dead but it has taken a few turns since it's initial inception.
I've made some modifications and improvements since the prototypes were made but really it needs more work doing on it.
Presently it's on the to do list but realistically won't be looked at till early next year, right now we are both too busy with our day jobs..
I could look at releasing the PCB gerbers if anyone is interested in making their own.....
Coley
Without exposing the code to your current products, could you post the protocol you've established for
inter-prop communications? I'd like to do some multi-propeller experimentation. It would make sense
to have some standards in this area.
OBC
I'll have a good think about the code too.......
Coley
I know you are pressed for time, but could you give us and update on this and the PropGFX
project? I think you have the hardware solution for a fantastic gaming platform.
Any chance you'll set some of it loose in the wild soon?
OBC
Well, HybridX3 and PropGFX stalled because both myself and Baggers have been so busy with real work this year.
I'm having a workshop built in my back garden at the moment I hoping that it will be more or less completed before Christmas so I will be able to start production of both boards in mid January. That will keep my Wife happy who was getting a bit concerned with components I had all over the study lol
Both boards have gone through some changes, HybridX3 now has a TV encoder built in and PropGFX Lite will also have a big brother in PropGFX+
PropGFX+ will stay in Dip40 format but have two Propellers, TV encoder and uSD connector, board is laid out, I just need to get Prototypes made.
Coley
