ColorPAL Object and ColorPAL VGA Demo — Parallax Forums
edited 2010-05-21 05:13 in Propeller 1
Attached is a demo written for the new ColorPAL RGB color sensor and the Propeller Demo Board. It displays color data and an interpretation of the color the ColorPAL sees on a VGA screen. Included with the demo program is a ColorPAL object that can be used with your own programs.
The first thing the demo program does when it starts is a white balance. This means that when the program starts, the ColorpAL needs to be looking at something white. If you save the demo in EEPROM, you can take a new white balance whenever you press the RESET button. By calibrating the ColorPAL to a known white color, each raw RGB component sensed afterward can be referenced to and corrected by the white components, as follows:
····CorrectedR,G,B = 255 * RawR,G,B / WhiteR,G,B
To keep things running smoothly, each color read is corrected to white and averaged over sixteen samples. The average RGB values are then displayed on the screen. Showing the actual RGB color on the screen is a bit more complicated. Although each sensed RGB color component can range from 0 to 255, each displayable color component can take on only one of the four values 0, 85, 170, or 255 ($00, $55, $AA, and $FF). The simplistic way to convert a sensed color to a displayed color would be to pick the value among the four displayable ones that's closest, for each RGB component. Unfortunately, this does not give the best results. Consider the color purple, as sensed by the ColorPAL: its RGB components are (76, 58, 86). Clearly, there's more red and blue than green. But the nearest VGA value to each of those is 85, and (85, 85, 85) is dark gray.
It turns out (after a lot of experimenting) that the simplest way to get a reasonable VGA color approximation to the sensed color is just to multiply the sensed components by each of $0.C0, $0.C1, ..., $1.3F, $1.40 (i.e. 0.75 to 1.25), convert each product that's no bigger than $FF by shifting right by 6 and pack the results into a 6-bit number to yield an index into the 64 VGA colors. Then the program keeps track of how many times each VGA color gets a "hit" over all the multipliers. The one that gets the most hits wins. The result is a pretty fair representation of the sensed color, to the extent that one of the available 64 colors can represent it.
Here's a photo of the ColorPAL looking at "Wasabi Green", one of my more troublesome colors:
Here's a representation of the VGA output screen:
BTW, in the spirit of full disclosure, I did photoshop this to match the color actually displayed on the VGA screen, rather than the washed-out color my camera recorded.
Anyway, if you have a ColorPAL (they're only $19.99, after all smile.gif ), get some paint chips from your local hardware store, and give this program a try!
Post Edited (Phil Pilgrim (PhiPi)) : 12/30/2009 5:16:59 AM GMT
  • TubularTubular Posts: 4,745
    edited 2009-12-17 09:58
    Once again Phil, very nice module and demo.
    Now we just need to reinstate the parallax inkjet kit, version 2 with color cartridges, and we can tint our own paint cans smile.gif
    The other vital use I see for that is settling those long running arguments with significant others about 'salmon' hues, and whether they are in fact pink, or orange...
  • heaterheater Posts: 3,370
    edited 2009-12-17 10:38
    Damn, I thought from the thread title you had come up with the ultimate PAL TV driver !
    I was wondering about determining colour using normal LEDs using the fact that they can convert light to volatge/current and presumably do it over a narrow spectrum. So, three normal LEDs, red, green, and blue used "backwards" could be used to get the colour. No colorPAL required.
    Of course that might work for determining the colour of bright ambient light but to do what the colorPAL does one would need broad spectrum white light source. Surely a white LED would not do. Or could one use another triplet of LEDs to provide the matching RGB illumination?
    Calibrating all of that might be an issue.
    edited 2009-12-17 11:11
    Phil, what revision is that demo board in the picture? It looks nothing like my rev G ...
    edited 2009-12-17 17:29
    heater,
    White LEDs are not as bad as one might imagine. Although the emissive source is blue, that's used to excite a white phosphor, which has a broad-spectrum output.
    kuroneko,
    The Demo Board pictured is the first model made. (I must remember not to use it for forum photos. I always get asked about it. smile.gif )
    edited 2009-12-17 18:17
    White LEDs may be broad spectrum but I had the impression the spectrum consisted of a lot peaks here and there. So then it depends how those peaks match up with those of the receiving LEDs. Time for some research...
    edited 2009-12-17 18:25
    The LEDs I use for the TCS230-DB (now TCS3200-DB) have a sharp blue peak from the LED itself, but the spectrum emanating from the phosphors is a very smooth Gaussian.
    edited 2009-12-17 19:30
    I'll be getting a ColorPAL simply because I've wanted a color sensor and this one is a mere fraction of the cost of the other. Nice work Phil!
    P.S. That is the most rediculous looking demo board I've ever seen! Thank goodness for revisions!!
    Computers are microcontrolled.
    Robots are microcontrolled.
    I am microcontrolled.
    But you·can·call me micro.
    Want to·experiment with the SX or just put together a cool project?
    SX Spinning light display·
    My overstock is killing me.
    PM me for absolutly FREE 8-pin Mini Din connectors.
    edited 2009-12-17 19:41
    Phil, how did you determine the white LED spectrum or is it documented somewhere?
    edited 2009-12-17 19:53
    heater,
    It's documented in the LED's datasheet: www.all-tronic.com/pdf/NSPW500BS.pdf.
    (To viewers who might just be joining, this discussion of white LEDs has nothing to do with the OT (i.e. ColorPAL), which uses an RGB LED.)
    edited 2009-12-18 16:54
    Hey, I like the looks of this thing.
    This looks like a nifty way to monitor a slow biochemical process remotely with one glance at a VGA screen.
    Thanks, Phil !
    edited 2010-01-19 18:32
    Great project and writeup, Phil. You're incredibly well-versed in all things technical. A real renaissance man. Kudos.
    Wasabi green. Hmm.
    For some reason I'm thinking "sushi" for lunch.
  • mugurmugur Posts: 105
    edited 2010-02-03 14:32
    Hi. I'm bringing this thread back with one question. Can i use the RCA Breadboard with according resistors to test this code? Or do i need a VGA monitor ?
    edited 2010-02-03 17:06
    mugur,
    You need the VGA monitor. The limited color gamut available in the Propeller's video output renders it much less useful for displaying sensed colors.
    edited 2010-02-03 18:46
    Thank you Phil. I have another question: is there a way to alter the code to just light up some LEDs based on a "rough average" reading of color?
    Meaning like 5 LED's red, green, blue, yellow, white instead of using VGA? Is it possible to alter the code in this way and simply light up the most appropriate LED color based in the color the sensor read?
    edited 2010-02-03 19:52
    Sure, it's possible. You'll have to decide how to partition the 2563 RGB color space among the LEDs and then test each result against your partition to determine which LED to light. One way might be to convert the RGB values to HSB values, then use the Hue to determine the best color LED. But if the Saturation value were too low, you'd default to the white LED; then, if the Brightness were too low, you'd default to no LEDs lit.
    As an alternative, you could use an RGB LED like the one in the ColorPAL and PWM the RGB segments to match the RGB values returned by the ColorPAL.
    edited 2010-02-03 20:04
    Ok, that is chinese already [noparse]:)[/noparse])
    Np, i will wait untill i'll get smart enough to understand what file from yours to modify and how.
  • ^Mr.Rat^^Mr.Rat^ Posts: 2
    edited 2010-02-04 20:12
    Hi all i would like to know if there is a sample of code for the arduino duemilanove 328...
  • hover1hover1 Posts: 1,929
    edited 2010-02-04 20:39
    Not here in the Propeller section, but you might want to check the Sandbox section of the forum.
    ^Mr.Rat^ said...
  • CJWCJW Posts: 77
    Hi,
    My Boe Bot have gripper and IR, I would like to modify the bot to add color sensor TCS 3200 DB, I do not know what i need to do with the programming. Can anyone assist me. Thank you
    Yours Sincerely
    James
