Modifying OBEX objects
I downloaded the TLV2543 driver object from the OBEX, and was having an insane time trying to get it to work. Long story short, I found a pretty serious bug in it(although it works GREAT without the bug). This is a very simple fix, but I'm not sure if the person who made it is still around to correct it in the obex. I've used this same driver before, but my files got erased and I forgot about the bug - until now.
So, is there any sort of way to modify existing obex objects, or at least comment on them so that other users may side-step these perils? I'd hate for someone else to spend half a day of troubleshooting, only to find out the code has two lines in error...
Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
· Propeller Object Exchange (last Publications / Updates);·· Vaati's custom search
Powered by enthusiasm
