ZiCog a Zilog Z80 emulator in 1 Cog - Page 25 — Parallax Forums
1222325272841
    edited 2009-12-15 23:59
    It is a 32 bit counter incremented at the clock frequency - so the lowest byte of the register would look pretty random to Z80 code, more so than the slower-incrementing Z80 refresh register [noparse]:)[/noparse]
    And you are correct, it does not need to be declared.
    Dr_Acula said...
    That sounds intriguing. Just to check, cnt is an internal variable that is incremented somwhere, and it is a byte? This could be used for random numbers, right? I haven't got the pasm instruction set in front of me right now, but cnt doesn't need declaring anywhere, it is internal?
    www.mikronauts.com Please use mikronauts _at_ gmail _dot_ com to contact me off-forum, my PM is almost totally full
    Morpheusdual Prop SBC w/ 512KB kit $119.95, Mem+2MB memory IO board kit $89.95, both kits $189.95
    Propteus and Proteus for Propeller prototyping 6.250MHz custom Crystals run Propellers at 100MHz
    Las - Large model assembler for the Propeller Largos - a feature full nano operating system for the Propeller
    edited 2009-12-16 00:04
    Thanks Bill, that looks just the ticket. I'll put that in when I get home.
  • heaterheater Posts: 3,370
    edited 2009-12-16 06:49
    Dr_A - "BBCBasic is now at the point of running but giving an internal checksum error (but not crashing out to the Break register dump)."
    This sounds like excellent progress.
    At this point its probably a good idea to run EXZ80DOC again and see if anything has gone broken. There were four tests with CRC errors anyway.
    I think you have that zipm2.dsk I put out that has a modified EXZ80ALL on it. If you look in the EX.MAC on that disk you will see I put all the tests into order of execution time but with the tests that failed with a crash at the end. I also added some comments against the failed tests.
    Well, at the end of that test list you will find this:
           dw      rotxy           ;(416 cycles)     ; Not implemented
            dw      rotxy1          ;(416 cycles)     ; Not implemented
            dw      rld             ;(7168 cycles)    ; Not implemented
            dw      inout           ;(65,536 cycles)  ; Not implemented
            dw      rotz80          ;(6,784 cycles)   ; Crash
            dw      ld8rrx          ;(6,912 cycles)   ; Not implemented
            dw      ld8ixy          ;(32 cycles)      ; Undocumented, not implemented
            dw      incxh           ;(3,072 cycles)   ; Undocumented, not implemented
            dw      incxl           ;(3,072 cycles)   ; Undocumented, not implemented
            dw      incyh           ;(3,072 cycles)   ; Undocumented, not implemented
            dw      incyl           ;(3,072 cycles)   ; Undocumented, not implemented
            dw      alu8rx          ;(376,832 cycles) ; Undocumented, not implemented
    You can find out what instructions these are testing by looking for the test name in the code and the comments there.
    For example: test "ld8rrx" has the comment "ld <b,c,d,e,ixy,a>,<b,c,d,e,ixy,a> (6,912 cycles)"
    Those tests I marked up as "Undocumented, not implemented" are all using the high or low bytes of IX and IY. Now I'm not 100% sure but I don't think these were documented in the original Z80 all though they do turn up in a lot of opcode lists I've seen.
    Now I hate to mention it but the dreaded DAA still does not work. I coded it as per the original Intel 8085 documentation, tested it as best I could manually and it is good enough to get SURVEY to display it's results correctly.
    However Z80 DAA is a lot more complicated. I think Zilog fixed it to also work for subtraction. It relies on knowing if the last operation was an add or subtract.
    Now the code to implement this extra DAA stuff was never going to fit in COG. DAA is already the biggest overlay so it has no room to grow.
    I wonder if BBCBasic is using DAA in that checksum calculation ?
    edited 2009-12-16 06:52
    We might need to split DAA into 2 parts in 2 overlays. One overlay could "chain" out to another". I think that is doable.
    edited 2009-12-16 07:01
    Bill Henning said...
    I'd suggest
    WRBYTE cnt,a_reg
    as a good implementation of LD A,R
    That does not do what you think it does [noparse]:)[/noparse] Even if it did work, as this is a hub operation (and therefore locked to 16n) at least the lower 4 bits would be constant.
    Post Edited (kuroneko) : 12/16/2009 7:24:52 AM GMT
    edited 2009-12-16 07:16
    The context that BBC Basic uses this is to seed the random number generator. Whilst the 0-255 R reg would allow for better seeding than 0-15, the randomness of the choice of seed was the human time taken to wait from switch on to starting the random sequence. Sticking a constant in there, until the R reg is implimented properly wouldn't threaten the fabric of time.
    Style and grace : Nil point
    edited 2009-12-16 07:39
    What kuroneko means...
    1. you cannot use wrbyte cnt, a_reg as "cnt" may not be used as the destination (even though it is in fact the source)
    2. cnt will always have the lower 4 bit combinations identical (i.e. not random). This is because it is a hub operation and you only get a slot every 16 clock cycles. We know the source (if a register) is sampled in the "e" cycle which is where no doubt were the wrbyte instruction is "cycling" while waiting for a hub access.
    What you will need to do is this ...
    mov tmp, cnt
    shr tmp, #4 '#2 or #4 (2 is because each instruction will be mainly synchronised - we don't have wait instructions in ZiCog)
    wrbyte cnt, a_reg
    edited 2009-12-16 09:14
    Getting there with unimplemented instructions but I'm still struggling with more fundamental things.
    LD A,I
    LD A,R
    LD I,A
    LD R,A
    'ireg overlay LD A,I  LD I,A   LD A,R   LD R,A =ED then 57,47,5F,4F
    ' for the moment do nothing for all 4 of these as not used by the zicog
    ' down the track, cnt could be used for LD A,R to create a random number
                            org     OVERLAY_START
    ireg_ovl
                            add     pc,#1           ' do nothing, skip this byte (2 byte commands)
                            jmp     #fetch
                            long    $0[noparse][[/noparse]($ - OVERLAY_START) // 2]    'fill to even number of longs (REQUIRED)
    ireg_ovl_end
                            fit     $1F0
    Added the jumps in the ED jump table at 57,47,5F,4F
    These are two byte instructions and all this does is skip the second byte by incrementing the PC. No actual code as yet.
    Tested with this little .MAC program compiled on the dracblade.
    File IREG.MAC
    ; changing from tasm mnemonics - replace all $nn with nnH
    ; remove . in front of equ
    ; remove : in equ lines
    ; must have a CR/LF after END
    ; use zasm.sub with supersub
    ; eg supersub zasm myfile    (where myfile is called myfile.mac but do not put the
    ;                             mac in the instruction - m80 knows it is implied)
    ; zasm.sub is the following two lines
    ;M80 =$1 /Z/C/L/M
    ;L80 $1,$1/N/E
    ; LD A,R
    ; LD R,A
    ; LD I,A
    ; LD A,I   all these do nothing but at least dont crash the zicog
    MAIN:    LD    A,1            ; setup a few registers to prove it works
        LD    B,2
        LD    C,3
        HALT
        LD A,R                ; these should do nothing
        LD R,A
        LD I,A
        LD A,I
        HALT
        LD     D,4            ; do a few more instructions
        LD     E,5
        HALT                ; dumps registers
        RET                ; back to CP/M
        END
    I'm dumping out the hex values in memory 5 before and 5 after the current PC ie 10 bytes so it is possible to see the hex of what instruction just happened and what is about to happen.
    The program runs to completion (with 3 breaks) and goes back to CP/M as expected.
    I can now get DDTZ to run. But it is not working and while it returns to CP/M, nothing in CP/M works after running DDTZ. So somewhere in that program is a corrupted instruction.
    So - I guess it is back to the exerciser for now...
    I had an idea of going to the .MAC source of DDTZ but it appears the source I have is corrupted. It won't compile on the dracblade nor on the N8VEM. One thing - it is writting in 8080 pnemonics, but has special overlays for a handful of Z80 commands. But not all and I think this version might be incomplete in some way.
    @heater, I've gone back to a post on the 15th March in this thread when we were running the exerciser. I think you had a way of creating a source file so it ran the quick tests at the beginning.
    I've just run the Z80 exerciser on the SIMH and it passes everything. So I guess that means it is possible to build a perfect emulator.
    I then ran it on a N8VEM with a real Z80 and got a few crc checks. Some we mentioned back in March were the same as the crc numbers on the zicog which was good news.
    Do you still have the sources for those programs? Could you maybe post one with the quick bits listed first, and then I can do a comparison with a real Z80? Cheers, James
    Post Edited (Dr_Acula) : 12/16/2009 10:18:02 AM GMT
    edited 2009-12-16 15:20
    Dr_A, That version of EXZ80DOC.COM with quick tests done first and the source code for it are in the last zipm2.dsk I posted. I'd post it again but I'm away from my machine today.
    In theory you don't have to compare running EX against a real Z80 as it already contains CRCs of test results when run on a MOSTEK Z80.
    edited 2009-12-16 15:48
    <insert image of Homer slapping his forehead and saying "DUH!">
    Ofcourse, it would read the shadow register.
    I was bitten by this a couple of years ago when I was trying to do
    WRLONG ina, hubptr
    Bill
    kuroneko said... That does not do what you think it does [noparse]:)[/noparse] Even if it did work, as this is a hub operation (and therefore locked to 16n) at least the lower 4 bits would be constant.
    edited 2009-12-16 21:58
    Thanks heater. I'll see if I can find it.
    Time to get this to pass the tests. I'm not greatly concerned about crc errors yet, as I know these came up on a real Z80 too. Just need the crc to be the same (which I can test easily but it does take all night to run a test)
    But first test is to get the exerciser to get to the end
    A>exz80doc
    Z80 instruction exerciser
    Undefined status bits NOT taken into account
    <adc,sbc> hl,<bc,de,hl,sp>....( 71,680) cycles   ERROR **** crc expected:f39089a0 found:70201f28
    add hl,<bc,de,hl,sp>..........( 35,840) cycles   OK
    add ix,<bc,de,ix,sp>..........( 35,840) cycles   OK
    add iy,<bc,de,iy,sp>..........( 35,840) cycles   OK
    aluop a,nn....................( 45,056) cycles   OK
    aluop a,<b,c,d,e,h,l,(hl),a>..(753,664) cycles   OK
    aluop a,<ixh,ixl,iyh,iyl>.....(376,832) cycles
    AF =38C5 BC =C035 DE =22DD HL =2847 SP =234B PC =253D
    AF'=0000 BC'=0000 DE'=0000 HL'=0000 IX =ACCF IY =C76E
    Unimplemented instruction one before location PC, any key to continue
    And copied off the screen as I can't copy and paste it yet the bytes near this error are (SP is 253D and I think it errors the one before)
    2538 7B
    2539 11
    253A 01
    253B DD
    253C 84
    253D 00
    253E 00
    253F ED
    2540 73
    Addit: Found a list of opcodes including undocumented ones. Posting it here as I was able to work out the above is DD84 which is an undocumented one. There are a huge number of opcodes in the DD set that are undocumented. Do we use them? (I never have). But at least we need to not fail the emulation on them - ie increment the PC properly.
    Post Edited (Dr_Acula) : 12/17/2009 12:33:19 AM GMT
    edited 2009-12-17 07:08
    Dr_A, I'm not sure where we are going with this now. Normally I would want any ops the we don't implement to cause a break and a reg. dump rather than just silently fail and continue. Having them break is more useful when trying to get something like BBCBasic to work as we can see immediately where it trips up.
    All those ops that operate on high and low halves of IX and IY are not implemented. As far as I know they were not documented as for the original Z80. Can we check that some how?
    If you look at the DD and FD ops you soon realize that what actually happens is that the DD and FD prefixes throw a big switch in the Z80 somewhere that cause it to operate on IX and IY instead of HL.
    Most (not sure if all) ops have the same function as the opcode without the prefix byte except using index regs instead of HL. That is why there are actually ops to operate on IXH, IXL, IYH and IYL as bytes. Thesy are the same operations as on H and L bytes.
    So this leads me to think:
    If we were really smart we would not have that dispatch table for DD and FD ops separately rather the DD and FD prefix would arrange that whatever happens next hapens to IX an IY instead of HL. Bit like moving the register pointer for EX.
    edited 2009-12-17 07:37
    Yes I can see your argument for leaving it as it is, and also for changing it. How hard would it be to add these non implemented codes (simh has them)? Or how about we change the source code for the exerciser program and delete these opcodes?
    edited 2009-12-17 07:43
    What I'd really like is for someone to come up with an original Zilog Z80 manual/data sheet so that we can find out if those ops were originally advertised as working or not. If not they should be removed from EXZ80DOC and tested in EXZ80ALL instead.
    Anyway, never mind the exerciser, we want BBCBasic to run. So we need to implement whatever it uses, documented or not. So we should break on unimplemented stuff.
    edited 2009-12-17 09:12
    I had the official Mostec Z80 book, as standard with the Nascon kit. I have a link, somewhere, to a pdf of it, and as far as I can remember the "undocumented" ops were only a "happen chance" and were never officially supported. As you say, Heater, they unleash a raft of obscure features. I will search for that link (it was a grey A4 paperback, about 300 pages, if I recall)
    http://numba-tu.com/nascomhomepage.com/pdf/z80-mostek.pdf·but isnt the full version _ I have a print off of it back at home (in the garage,somewhere)
    Post Edited (Toby Seckshund) : 12/17/2009 9:24:29 AM GMT
  • AleAle Posts: 2,363
    edited 2009-12-17 12:23
    Using cnt as a source for the R register is ok I think.
    Why: the 16 cycle window is not an issue because you are not synchronized to the HUB and inside the 16 cycle window from previous reads/z80 instructions, you have an arbitrary number of instructions between reads of cnt, i.e. R. btw, R is only a 7 bit counter!
    I do not know how the BBC Basic uses R but I'd guess it is only 1 read to R... so no issue at all...
    Visit some of my articles at Propeller Wiki:
    MATH on the propeller propeller.wikispaces.com/MATH
    pPropQL: propeller.wikispaces.com/pPropQL
    pPropQL020: propeller.wikispaces.com/pPropQL020
    OMU for the pPropQL/020 propeller.wikispaces.com/OMU
    edited 2009-12-17 13:37
    re heater "What I'd really like is for someone to come up with an original Zilog Z80 manual/data sheet so that we can find out if those ops were originally advertised as working or not."
    Oh, ok (swivels chair, pulls the Zilog Data Book (1979) off the shelf and turns to page 6). I can't see any of those split IX/IY instructions anywhere. So I reckon they ought to come out of the exerciser. If we just remove those ones, then I can do a checksum and compare with a real Z80.
    heater, where did you say the source was again for the exerciser? Somewhere in a zip posted a while back?
    edited 2009-12-17 13:51
    Down in the dark depths of Dr Acula's crypt, obscured by dust, cobwebs and the bones of young virgins there lurks....A Zilog Z80 manual !
    Brilliant. I'm going to fix up the EXZ80DOC.COM to only does what it says it does. Still that does not mean that BBC Basic does not use some of those undocumented ops or undocumented flag bit settings.
    I'll try and post you my EX source when I get home tonight.
    edited 2009-12-17 19:43
    http://vt100.net/mirror/harte/Zilog/Zilog_Z-80_Assembly_Language_Programming_Manua.PDF
    edited 2009-12-18 00:01
    See attached. Hi res photos of the two pages - zoom in and they should be legible.
    Fixing the exz80 program would be *very* much appreciated!
    1536 x 2048 - 508K
    1536 x 2048 - 482K
    1280 x 960 - 305K
    edited 2009-12-18 08:03
    The book I linked to takes each instruction with 1-2 pages as an example, with flag info. But at 90+ MB is a bit of a download.
    This is the book that I wrote all my MC by, I never got to run ZEAP assembler.
    The previous link points to a book given with the Nascom kit, but is far less detailed.
    edited 2009-12-18 09:24
    Ale said...
    How do you know that you're not synchronised? The code path after returning from the hub access (to read the LD A, R instruction) up to querying cnt is constant (assumption on my part, but why wouldn't it be). Which means you are locked to the hub window (16n + const). What am I missing here? Or is it possible that instructions are fetched either from hub or cog (cache) memory?
    edited 2009-12-18 09:34
    Ale: You would at least be locked into a 4 cycle window because ZiCog does not do waitxxx instructions.
    edited 2009-12-18 13:49
    Just managed to squeeze in a run of EX on my TriBlade again having lost the results from last time. Here is the result:
    [noparse][[/noparse]code]
    A>exz80doc
    ld hl,(nnnn)..................( 16) cycles OK
    ld sp,(nnnn)..................( 16) cycles OK
    ld (nnnn),hl..................( 16) cycles OK
    ld (nnnn),sp..................( 16) cycles OK
    ld (<ix,iy>+1),nn.............( 32) cycles OK
    ld (<ix,iy>-1),nn.............( 32) cycles OK
    ld <bc,de>,(nnnn).............( 32) cycles OK
    ld <ix,iy>,(nnnn).............( 32) cycles OK
    ld <ix,iy>,nnnn...............( 32) cycles OK
    ld a,<(bc),(de)>..............( 44) cycles OK
    ld a,(nnnn) / ld (nnnn),a.....( 44) cycles OK
    ldd<r> (1)....................( 44) cycles OK
    ldd<r> (2)....................( 44) cycles OK
    ldi<r> (1)....................( 44) cycles OK
    ldi<r> (2)....................( 44) cycles OK
    ld <b,c,d,e,h,l,(hl),a>,nn....( 64) cycles OK
    ld (nnnn),<bc,de>.............( 64) cycles OK
    ld (nnnn),<ix,iy>.............( 64) cycles OK
    ld <bc,de,hl,sp>,nnnn.........( 64) cycles OK
    ld (<ix,iy>+1),a..............( 64) cycles OK
    ld (<ix,iy>-1),a..............( 64) cycles OK
    ld (<bc,de>),a................( 96) cycles OK
    ld a,(<ix,iy>+1)..............( 128) cycles OK
    ld a,(<ix,iy>-1)..............( 128) cycles OK
    ld (<ix,iy>+1),<h,l>..........( 256) cycles OK
    ld (<ix,iy>-1),<h,l>..........( 256) cycles OK
    ld <h,l>,(<ix,iy>+1)..........( 256) cycles OK
    ld <h,l>,(<ix,iy>-1)..........( 256) cycles OK
    <set,res> n,(<ix,iy>+1).......( 448) cycles ERROR **** crc expected:cc63f98a found:3d695930
    <set,res> n,(<ix,iy>-1).......( 448) cycles ERROR **** crc expected:b2cdd674 found:43c776ce
    ld <b,c,d,e>,(<ix,iy>+1)......( 512) cycles OK
    ld <b,c,d,e>,(<ix,iy>-1)......( 512) cycles OK
    ld (<ix,iy>+1),<b,c,d,e>......( 1,024) cycles OK
    ld (<ix,iy>-1),<b,c,d,e>......( 1,024) cycles OK
    <inc,dec> bc..................( 1,536) cycles OK
    <inc,dec> de..................( 1,536) cycles OK
    <inc,dec> hl..................( 1,536) cycles OK
    <inc,dec> ix..................( 1,536) cycles OK
    <inc,dec> iy..................( 1,536) cycles OK
    <inc,dec> sp..................( 1,536) cycles OK
    bit n,(<ix,iy>+1).............( 2,048) cycles ERROR **** crc expected:a8ee0867 found:216e7b00
    bit n,(<ix,iy>-1).............( 2,048) cycles ERROR **** crc expected:29c170d8 found:a04103bf
    <inc,dec> a...................( 3,072) cycles OK
    <inc,dec> b...................( 3,072) cycles OK
    <inc,dec> c...................( 3,072) cycles OK
    <inc,dec> d...................( 3,072) cycles OK
    <inc,dec> e...................( 3,072) cycles OK
    <inc,dec> h...................( 3,072) cycles OK
    <inc,dec> l...................( 3,072) cycles OK
    <inc,dec> (hl)................( 3,072) cycles OK
    ld <bcdehla>,<bcdehla>........( 3,456) cycles OK
    cpd<r>........................( 6,144) cycles ERROR **** crc expected:c8439345 found:e3bc468c
    cpi<r>........................( 6,144) cycles ERROR **** crc expected:e66fa7d2 found:d6607fd7
    <rlca,rrca,rla,rra>...........( 6,144) cycles OK
    <inc,dec> (<ix,iy>+1).........( 6,144) cycles OK
    <inc,dec> (<ix,iy>-1).........( 6,144) cycles OK
    <set,res> n,<bcdehl(hl)a>.....( 6,912) cycles OK
    neg...........................( 16,384) cycles OK
    bit n,<b,c,d,e,h,l,(hl),a>....( 49,152) cycles OK
    <daa,cpl,scf,ccf>.............( 65,536) cycles ERROR **** crc expected:9b4ba675 found:c2e033f4
    aluop a,(<ix,iy>+1)...........(229,376) cycles OK
    aluop a,(<ix,iy>-1)...........(229,376) cycles OK
    shf/rot (<ix,iy>+1)...........( 416) cycles PC=253F AF=8082 BC=94F4 DE=DBF6 HL=FF3C IX=0102 IY=0102 SP=61D9
    [noparse][[/noparse]url]
    After that last test which "breaks" because the ops are not implemented there are more missing/failing ops.
    No chance to play with changing the EX program itself but I have attached the source for it with comments in the "tests" list indicating what fails on ZiCog, what is not implemented yet, and what is not a documented instruction of the original Z80.
    To build this copy EXZ80DOC.LIB to EXCONFIG.LIB and assemble with "do mc ex" on ZiCog or SIMH.
    For some reason EX has no tests for EX and such that have been tripping us up recently.
    edited 2009-12-19 06:16
    Same errors on my zicog.
    Running it now on a real Z80. Not finished yet, but intriguing I got a crc error on an instruction set that yours passed. Yours is *better* than a real Z80 on that one!
    A>ex
    <set,res> n,(<ix,iy>+1).......(    448) cycles   OK
    <set,res> n,(<ix,iy>-1).......(    448) cycles   OK
    bit n,(<ix,iy>+1).............(  2,048) cycles   OK
    bit n,(<ix,iy>-1).............(  2,048) cycles   OK
    cpd<r>........................(  6,144) cycles   OK
    cpi<r>........................(  6,144) cycles   OK
    add iy,<bc,de,iy,sp>..........( 35,840) cycles   ERROR **** crc expected:5fc828e9 found:f9c36ff1
    <daa,cpl,scf,ccf>.............( 65,536) cycles   OK
    <adc,sbc> hl,<bc,de,hl,sp>....( 71,680) cycles   OK
    Will repost when that big set finishes (any way of splitting it up??)
    edited 2009-12-19 09:54
    Interesting result.
    In the source of the EX test we find "At the end of the sequence the crc is compared to an expected value that was found empirically on a real Z80" and "Documented flags are as per Mostek Z80"
    So we can conclude that a Mostek Z80 is not the same as a ZilogZ80.
    So actually we should create a another version of EX that has the correct checksums in it for a real Z80. EZ80REAL.COM ?
    What brand of Z80 are you running that test on?
    I have to dig up that mini-n8vem you sent me I think that is a Zilog.
    edited 2009-12-19 11:35
    and the last bit:
    shf/rot (<ix,iy>+1)...........( 416) cycles OK
    shf/rot (<ix,iy>-1)...........( 416) cycles OK
    <rrd,rld>.....................( 7,168) cycles OK
    <ini,outi,ind,outd><,r>.......( 65,536) cycles ERROR **** crc expected:aafb6d5c found:498ee92f
    shf/rot <b,c,d,e,h,l,(hl),a>..( 6,784) cycles OK
    ld <bcdexya>,<bcdexya>........( 6,912) cycles OK
    ld <ixh,ixl,iyh,iyl>,nn.......( 32) cycles OK
    <inc,dec> ixh.................( 3,072) cycles OK
    <inc,dec> ixl.................( 3,072) cycles OK
    <inc,dec> iyh.................( 3,072) cycles OK
    <inc,dec> iyl.................( 3,072) cycles OK
    aluop a,<ixh,ixl,iyh,iyl>.....(376,832) cycles OK
    Some failure detected.
    CP/M V2.2C
    A>
    Chip is a Zilog Z84C00
    edited 2009-12-27 02:50
    Drac & heater,
    My RamBlade is running ZiCog jumpin.gif· (I have been busy with other things and RamBlade)
    Drac: Could you post the latest ZiCog code (with the extra instruction fixes) so that I can integrate with TriBlade, RamBlade & Demo Board code? How much more to go before it is ready for a release?
    I note all the testing with the exorciser? Could you post the compiled file? I presume I can then Xmodem it across?
    I am thinking of modifying (#ifdef) the spin code (serial out function) to check if ">" is written and insert the CNT value before the ">". This would give us some timing info at each A> prompt.
    Are there any files we want to include in the CPM2.2 A drive for a release version? I noticed that the version I am currently using does not have MBasic but I can copy that from the B drive.
    Post Edited (Cluso99) : 12/27/2009 2:55:19 AM GMT
    676 x 491 - 86K
    edited 2009-12-27 04:00
    Some more random thoughts...
    • Make the C drive a larger drive·(because the C drive is often the hard disk). Would 32MB be big enough?
    • Use the "HALT" program/instruction to interrupt ZiCog and run spin code to...
      • Allow changing drive G disk file (on the fly) to..
        • select filename
        • select parameters as floppy (1MB) or hard drive (8MB) depending on SD file size
        • if floppy drive, allow spin remapping so that a standard SIMH floppy file can be used
        • This allows swapping of a drive without compiling and files can then be copied onto C or wherever
      • Suspend·ZiCog and launch a new cog spin routine(s)
        • Could allow a spin editor to run, compiler or whatever
        • then return to ZiCog
      • Stop ZiCog and launch another prop binary
      • Change the standard CPM I/O routine for redirection
    • Make the H drive the RamDrive and write-through as previously stated
    edited 2009-12-27 04:18
    Good news Cluso.
    Re my latest code - see the dracblade thread which I think is on page 2 on the forum - latest post has attachment from the 26th Dec. Lots in there is not needed for ramblade, but the zicog code is there.
    EX and EXX are working. LD A,I are not coded properly - I just skip them but ideally R could be the cnt register from pasm. There are other instructions that don't work but I don't know what they are. BBC Basic will no run but it gives a Basic error message (which at least is one step better than crashing out to a register dump).
    I'm in two minds about a 1.0 release when instructions are known to not work. Thoughts from others would be appreciated.
    Post Edited (Dr_Acula) : 12/27/2009 4:26:15 AM GMT
