PASM Coding Challenge - 4 wire Prop to Prop communication.
The aim here is to implement bidirectional Prop to Prop communication using the following scheme:
1) Two pairs of signal wires connects the Props, one pair for each direction.
2) Within a pair let the signals be called "zero_bit" and "one_bit"
3) The initial and resting state of both wires is low.
4) A transition, low to high or vice versa, on the zero_bit wire indicates a 0 is transmitted. The actual signal level is unimportant.
5) A transition, low to high or vice versa on the one_bit wire indicates a 1 is transmitted. The actual signal level is unimportant.
6) Assume data is transmitted in 8 bit bytes.
7) At the end of transmitting the 8 bits the wires are set back low, the rest state.
8) The byte is transmitted high bits first.
So the code to transmit using this scheme might look something like this:
Now that code is a bit jittery in its timing as the transition times depend on if the data is zero or one. Not to worry for now.
The Tx loop is 4 instructions, so about 5M bits/second on a normal prop set up. The loop could be unrolled giving 6.6M bits/second maybe.
Now the challenge, if you have not guessed, is the hard part. Create the receiving side of this communication link. As fast as possible. Using whatever pins are most convenient/helpful. Changing the Tx code is allowed to fix the jitter or slow it down if necessary.
tx_byte 'Assume wires are low, resting, before we start
mov data_byte, some_byte_to_send 'Get a byte to send
shl data_byte, #24 'Move it to the top of the long
mov count, #8 'Count 8 bits
:loop
shl data_byte, #1 wc 'Get the value of the top most bit
if_c xor outa, one_bit 'It's a 1 so transition the "one" wire
if_nc xor outa, zero_bit 'It's a 0 so transition the "zero" wire
djnz count, #:loop 'Round again if need be
mov outa, #0 'Done, set the wires back to resting state.
tx_byte_ret ret
Instead of using one line for zero and the other for one, I use one line as the bit and the other as a the bit ready indicator (state change).
txbyte mov txwork, bytetosend mov count, #8 :loop shr txwork, #1 wc muxc outa, txmask xor outa, readymask ' indicate bit ready djnz count, #:loop andn outa, txmask txbyte_ret retrxbyte mov count, #4 :loop waitpeq ina, readymask ' wait for (odd) bit test rxmask, ina wc rcr rxwork, #1 waitpne ina, readymask ' wait for (even) bit test rxmask, ina wc rcr rxwork, #1 djnz count, #:loop shr rxwork, #24 ' clean-up rxbyte_ret retJeepers... its 5:40A on a Saturday and I'm up and writing code (I hope it's intelligible).
Post Edited (JonnyMac) : 10/3/2009 12:47:40 PM GMT
Kuroneko. Let's see....
Post Edited (JonnyMac) : 10/3/2009 3:33:07 PM GMT
"The aim here is to implement bidirectional Prop to Prop communication" - can this be simultaneous bi-directional data transfer? and is there a COG restriction or limit?
Beau Schwabe
IC Layout Engineer
There is no COG restriction limit. I was only thinking as far as one for Tx and one for Rx.
If it can be done with a single COG performing both tx and rx that would be cool even with a huge speed hit.
The phrase "Changing the Tx code is allowed..." was intended to mean that it could rewritten in any way, to speed it up or slow it down or fix the jittery bit edge timing, whatever, BUT that it should implement the 4 wire scheme/protocol as specified. Sorry if that was not so clear.
Yes, I am looking at this as a Propeller to Propeller scheme but also looking toward a particular external hardware.
So now, more explanation: There is a certain multi-core embedded processor chip design that implements communication channels between devices using this protocol. So my thinking here is motivated by a few things:
1) Academic - Why did they settle on that particular method? I'm something of an ignoramus here so I'm curious. What benefits does it have over other methods?
2) Practical - Would it be beneficial in any way for Prop to Prop comms? Is it implementable in a way to be able make use of the benefits?
2) Optimistic - The very unlikely and distant possibility of getting a Prop to interoperate with said devices using this protocol. Not that it sure that this is a desirable way to get interoperation at this stage.
I dare not name said devices here as they can be seen as a competing product to the Parallax Propeller (which I don't necessarily agree with). Those who follow such things know it already. That's why my initial challenge post may be a bit more mysterious than I intended.
Is it okay to assume that the receiving pins are A1 and A0, say, or does it have to be pin-independent?
There was an earlier thread that talked about using 4-wires (unidirectional) where each wire represented a symbol...
Wire1 = 00
Wire2 = 01
Wire3 = 10
Wire4 = 11
...In this implementation the wire would transition based on the bit pattern (symbol) of data that needed to be sent.
for example.... sending 10001011 would require a transition on W3,followed by W1,W3 again, and W4. So in total 4 'output cycles' on the transmission line. Using the same 4-wires if you simply output the 'nibble' at a time, the number 'output cycles' would be reduced to 2 instead of 4. .... '1000' followed by '1011'
What I'm getting at, is that you 'see' the same sort of thing with your two wire symbolic method. Basically your 'symbols' are 1 and 0 and split among two wires.
Wire1 = 0
Wire2 = 1
It would take 8 'output cycles' to transmit 10001011, where as if you sent the data in half nibbles you could reduce the number of 'output cycles' down to 4 ... 10, 00, 10, 11
If you are going for over all speed then this probably isn't the best method to use.
Beau Schwabe
IC Layout Engineer
For more than 2 props an extra pin could be added, so that each prop had its own tx pin and multiple rx pins if speed is such an issue.
However, when things settle, I am going to use Beau's method, together with some other methods suggested using the counters, to just continually shift data in and out. I see this as being fast and optimal.
I see optimal designs using multiple props. My RamBlade (release soon now) will be a single prop with ram & sd and use a 2 in ultra high speed serial interface based on Beau's method. It is a cheap and minimal system which is an easy module to add. Another module with prop needs to be the display(s) and inputs (keyboard, mouse, etc). The third module is a totally flexible uncommitted I/O board. Sound familiar??? It is the TriBlade on seperate pcbs
Note that the prop is now cheap enough, and maybe we can look forward to another (smaller) price drop now another batch of chips has been produced. IMHO the only thing we are missing is pins. If we had the pins, memory is NOT an issue. Every day we see another piece of brilliant code being added. We are now doing things that I am sure were not even thought of 1 year ago, and there is plenty more that can be done.
· Home of the MultiBladeProps: TriBlade,·RamBlade, RetroBlade,·TwinBlade,·SixBlade, website
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80) , MoCog (6809)
rcv [b]waitpeq[/b] p00,pins w00_0 [b]waitpne[/b] p00,pins [b]test[/b] pin1,[b]ina[/b] [b]wc[/b] [b]rcl[/b] data,#1 [b]if_c[/b] [b]jmp[/b] #w10_1 w01_1 [b]waitpne[/b] p01,pins [b]test[/b] pin1,[b]ina[/b] [b]wc[/b] [b]rcl[/b] data,#1 [b]if_c[/b] [b]jmp[/b] #w11_2 w00_2 [b]waitpne[/b] p00,pins [b]test[/b] pin1,[b]ina[/b] [b]wc[/b] [b]rcl[/b] data,#1 [b]if_c[/b] [b]jmp[/b] #w10_3 w01_3 [b]waitpne[/b] p01,pins [b]test[/b] pin1,[b]ina[/b] [b]wc[/b] [b]rcl[/b] data,#1 [b]if_c[/b] [b]jmp[/b] #w11_4 w00_4 [b]waitpne[/b] p00,pins [b]test[/b] pin1,[b]ina[/b] [b]wc[/b] [b]rcl[/b] data,#1 [b]if_c[/b] [b]jmp[/b] #w10_5 w01_5 [b]waitpne[/b] p01,pins [b]test[/b] pin1,[b]ina[/b] [b]wc[/b] [b]rcl[/b] data,#1 [b]if_c[/b] [b]jmp[/b] #w11_6 w00_6 [b]waitpne[/b] p00,pins [b]test[/b] pin1,[b]ina[/b] [b]wc[/b] [b]rcl[/b] data,#1 [b]if_c[/b] [b]jmp[/b] #w10_7 w01_7 [b]waitpne[/b] p01,pins [b]test[/b] pin1,[b]ina[/b] [b]wc[/b] [b]rcl[/b] data,#1 [b]jmp[/b] rcv_ret w10_1 [b]waitpne[/b] p10,pins [b]andn[/b] pin1,[b]ina[/b] [b]wc[/b],[b]nr[/b] [b]rcl[/b] data,#1 [b]if_c[/b] [b]jmp[/b] #w00_2 w11_2 [b]waitpne[/b] p11,pins [b]andn[/b] pin1,[b]ina[/b] [b]wc[/b],[b]nr[/b] [b]rcl[/b] data,#1 [b]if_c[/b] [b]jmp[/b] #w01_3 w10_3 [b]waitpne[/b] p10,pins [b]andn[/b] pin1,[b]ina[/b] [b]wc[/b],[b]nr[/b] [b]rcl[/b] data,#1 [b]if_c[/b] [b]jmp[/b] #w00_4 w11_4 [b]waitpne[/b] p11,pins [b]andn[/b] pin1,[b]ina[/b] [b]wc[/b],[b]nr[/b] [b]rcl[/b] data,#1 [b]if_c[/b] [b]jmp[/b] #w01_5 w10_5 [b]waitpne[/b] p10,pins [b]andn[/b] pin1,[b]ina[/b] [b]wc[/b],[b]nr[/b] [b]rcl[/b] data,#1 [b]if_c[/b] [b]jmp[/b] #w00_6 w11_6 [b]waitpne[/b] p11,pins [b]andn[/b] pin1,[b]ina[/b] [b]wc[/b],[b]nr[/b] [b]rcl[/b] data,#1 [b]if_c[/b] [b]jmp[/b] #w01_7 w10_7 [b]waitpne[/b] p10,pins [b]andn[/b] pin1,[b]ina[/b] [b]wc[/b],[b]nr[/b] [b]rcl[/b] data,#1 rcv_ret [b]ret[/b] pins p11 [b]long[/b] 1<<one_pin|1<<zero_pin p00 [b]long[/b] 0 p01 [b]long[/b] 1<<zero_pin pin1 p10 [b]long[/b] 1<<one_pin data [b]res[/b] 1zero_pin and one_pin are constants that represent the pin numbers of the "0" and "1" pins, respectively. rcv is the subroutine that gets the next byte. Basically, this is an unrolled state machine whose transition diagram is a lattice. The current state is like a ball in a two-column Pachinko machine, dropping straight down on an incoming zero, and pinging to the adjacent row on a "1". The bits are collected in data.
Timing-wise, this will not quite hit the 5MHz mark, due to the extra clock states in the waitpne instructions. But it comes close!
Edit: ROLs changed to RCLs.
Post Edited (Phil Pilgrim (PhiPi)) : 10/4/2009 6:45:53 AM GMT
Post Edited (kuroneko) : 10/4/2009 6:53:16 AM GMT
Very nice!
Since the Transmitter ends with 'both' pins LOW, couldn't you assume that it would also start with both pins LOW so that the Receiver would look for this condition to be false as a SYNC?
This way you wouldn't need to use the waitpne for every bit... True the Transmitter creates some jitter in the way that the data is sent, but it would be 'predictable' on the receiver end depending on if the bit sent from the transmitter was detected as a "1" or a "0" on the receiver.
Edit:
After the first waitpne detecting that the pins have changed, "another" redundant waitpne should place any further pin reads during the time frame that the Transmitter is still in the djnz count, #:loop loop or the shl data_byte, #1 wc which should be a stable position to read the data.
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 10/4/2009 7:06:51 AM GMT
Yes, indeed that's what I meant. Amazing how one bad gene can spoil the whole family tree when replicated!
Beau,
You're right, assuming both Props are running at the same clock speed. I could add a nop or two after the first transition to make sure every sample comes after the pin change, then replace all the remaining waitpnes with nops. Moreover, if the transmit loop were unrolled, I could just eliminate the nops altogether, resulting in a 6.6MHz bit rate.
Post Edited (Phil Pilgrim (PhiPi)) : 10/4/2009 7:05:28 AM GMT
bump! - see my Edit just above your post
Beau Schwabe
IC Layout Engineer
xmt [b]shl[/b] data,#24 [b]shl[/b] data,#1 [b]wc[/b] [b]if_c[/b] [b]xor[/b] [b]outa[/b],xpin1 [b]if_nc[/b] [b]xor[/b] [b]outa[/b],xpin0 [b]shl[/b] data,#1 [b]wc[/b] [b]if_c[/b] [b]xor[/b] [b]outa[/b],xpin1 [b]if_nc[/b] [b]xor[/b] [b]outa[/b],xpin0 [b]shl[/b] data,#1 [b]wc[/b] [b]if_c[/b] [b]xor[/b] [b]outa[/b],xpin1 [b]if_nc[/b] [b]xor[/b] [b]outa[/b],xpin0 [b]shl[/b] data,#1 [b]wc[/b] [b]if_c[/b] [b]xor[/b] [b]outa[/b],xpin1 [b]if_nc[/b] [b]xor[/b] [b]outa[/b],xpin0 [b]shl[/b] data,#1 [b]wc[/b] [b]if_c[/b] [b]xor[/b] [b]outa[/b],xpin1 [b]if_nc[/b] [b]xor[/b] [b]outa[/b],xpin0 [b]shl[/b] data,#1 [b]wc[/b] [b]if_c[/b] [b]xor[/b] [b]outa[/b],xpin1 [b]if_nc[/b] [b]xor[/b] [b]outa[/b],xpin0 [b]shl[/b] data,#1 [b]wc[/b] [b]if_c[/b] [b]xor[/b] [b]outa[/b],xpin1 [b]if_nc[/b] [b]xor[/b] [b]outa[/b],xpin0 [b]shl[/b] data,#1 [b]wc[/b] [b]if_c[/b] [b]xor[/b] [b]outa[/b],xpin1 [b]if_nc[/b] [b]xor[/b] [b]outa[/b],xpin0 xmt_ret rcv [b]waitpeq[/b] zero,rpins [b]waitpne[/b] zero,rpins [b]nop[/b] 'Necessary? w00_0 [b]test[/b] rpin1,[b]ina[/b] [b]wc[/b] [b]rcl[/b] data,#1 [b]if_c[/b] [b]jmp[/b] #w10_1 w01_1 [b]test[/b] rpin1,[b]ina[/b] [b]wc[/b] [b]rcl[/b] data,#1 [b]if_c[/b] [b]jmp[/b] #w11_2 w00_2 [b]test[/b] rpin1,[b]ina[/b] [b]wc[/b] [b]rcl[/b] data,#1 [b]if_c[/b] [b]jmp[/b] #w10_3 w01_3 [b]test[/b] rpin1,[b]ina[/b] [b]wc[/b] [b]rcl[/b] data,#1 [b]if_c[/b] [b]jmp[/b] #w11_4 w00_4 [b]test[/b] rpin1,[b]ina[/b] [b]wc[/b] [b]rcl[/b] data,#1 [b]if_c[/b] [b]jmp[/b] #w10_5 w01_5 [b]test[/b] rpin1,[b]ina[/b] [b]wc[/b] [b]rcl[/b] data,#1 [b]if_c[/b] [b]jmp[/b] #w11_6 w00_6 [b]test[/b] rpin1,[b]ina[/b] [b]wc[/b] [b]rcl[/b] data,#1 [b]if_c[/b] [b]jmp[/b] #w10_7 w01_7 [b]test[/b] rpin1,[b]ina[/b] [b]wc[/b] [b]rcl[/b] data,#1 [b]jmp[/b] rcv_ret w10_1 [b]andn[/b] rpin1,[b]ina[/b] [b]wc[/b],[b]nr[/b] [b]rcl[/b] data,#1 [b]if_c[/b] [b]jmp[/b] #w00_2 w11_2 [b]andn[/b] rpin1,[b]ina[/b] [b]wc[/b],[b]nr[/b] [b]rcl[/b] data,#1 [b]if_c[/b] [b]jmp[/b] #w01_3 w10_3 [b]andn[/b] rpin1,[b]ina[/b] [b]wc[/b],[b]nr[/b] [b]rcl[/b] data,#1 [b]if_c[/b] [b]jmp[/b] #w00_4 w11_4 [b]andn[/b] rpin1,[b]ina[/b] [b]wc[/b],[b]nr[/b] [b]rcl[/b] data,#1 [b]if_c[/b] [b]jmp[/b] #w01_5 w10_5 [b]andn[/b] rpin1,[b]ina[/b] [b]wc[/b],[b]nr[/b] [b]rcl[/b] data,#1 [b]if_c[/b] [b]jmp[/b] #w00_6 w11_6 [b]andn[/b] rpin1,[b]ina[/b] [b]wc[/b],[b]nr[/b] [b]rcl[/b] data,#1 [b]if_c[/b] [b]jmp[/b] #w01_7 w10_7 [b]andn[/b] rpin1,[b]ina[/b] [b]wc[/b],[b]nr[/b] [b]rcl[/b] data,#1 rcv_ret [b]ret[/b] zero [b]long[/b] 0 rpins [b]long[/b] 1<<r_one_pin|1<<r_zero_pin rpin1 [b]long[/b] 1<<r_one_pin xpin0 [b]long[/b] 1<<x_zero_pin xpin1 [b]long[/b] 1<<x_one_pin data [b]res[/b] 1The nop may or may not be necessary, depending on how soon after the pin change the waitpne resumes. has this timing ever been established?
All of this begs the question, though: if the transmitter and receiver are this well synchronized, why use two pins? Simple NRZ with start and stop bits would work with one pin at 10MHz.
I'm just off to work again, hope to have time to study this later.
Beau: As stated in the first post "The initial and resting state of both wires is low". We can also assume this rest state lasts for a couple of bit times or a few if needed.
We should assume the Tx and Rx clocks are not actually synchronized, just derived from separate, normally accurate, crystal sources.
1. End w01_7 with "JMP rcv_ret" (no immediate flag)
2. The code works great if the sender & receiver are running from the same clock. But the whole reason for this weird protocol is it's used by some external device which may not share the same clock rate. Therefore, heater may want to use the waitpne version. Lower maximum bit rate, but it will handle slower bit rates without tweaking. (Although the transmitter would need to be tweaked.)
3. One thing which hasn't been defined is the minimum "rest" time. It will need to be at least 27 cycles (WRBYTE + WAITPEQ).
Composite NTSC sprite driver: Forum
NTSC & PAL driver templates: ObEx Forum
OnePinTVText driver: ObEx Forum
Phils original receiver with a waitne for each bit would probably work in ideal circumstances but suffers form one problem: If the rx and tx are not "in scync" then it can never get back into synch. i.e. if transmission is interrupted half way through a byte the you can't get the receiver back to looking for the beginning of the next byte. Well, not the easy way by just resting the line long enough.
Beau is right that the rest state of the link is both lines low so it's good to wait for pins not zero to get the first bit of a byte transmission and the just sample the rest of the bits at the right moment, like a regular UART after a start bit.
This brings us to Phils second solution which does exactly wait for "non-rest" and then sample the rest of the bits without waiting. It's neat but has one problem: The transmitter has very jittery timing on the edges. This may or may not matter when connected to something on a different clock with hardware tx and rx of this protocol.
By the way Phil asked: "if the transmitter and receiver are this well synchronized, why use two pins? Simple NRZ with start and stop bits would work with one pin at 10MHz"
If you have not guessed from my previous comments this is for connecting the Prop to chips that implement this protocol in hardware. I and others want to use them as co-processors for the Prop for say Ethernet and/or USB etc. This is the "native" way to connect to them that saves resources at the other end.
ericball: Yes the minimum rest time is not defined. Turns out we have some flexibility there. It can be configured to be very long.
With further research I find I need to send 9 bits not 8, the 9th bit is a data/control flag. There is a tenth bit transition to get both lines back to the rest state. When receiving, having the lines not at rest at the end indicates a parity error.
So my jitter free transmitter at only 5Mb/s looks like:
token_tx test ttoken, #%0_10000000 wz 'Get data bit 7 into carry if_nz mov out_1, wire_1 'To toggle wire 1... if_z mov out_1, wire_0 '...or wire 0. xor outa, out_1 'Toggle selected wire test ttoken, #%0_01000000 wz 'Get data bit 6 into carry if_nz mov out_1, wire_1 'To toggle wire 1... if_z mov out_1, wire_0 '...or wire 0 xor outa, out_1 'Toggle selected wire test ttoken, #%0_00100000 wz 'Get data bit 5 into carry if_nz mov out_1, wire_1 'To toggle wire 1... if_z mov out_1, wire_0 '...or wire 0 xor outa, out_1 'Toggle selected wire test ttoken, #%0_00010000 wz 'Get data bit 4 into carry if_nz mov out_1, wire_1 'To toggle wire 1... if_z mov out_1, wire_0 '...or wire 0 xor outa, out_1 'Toggle selected wire test ttoken, #%0_00001000 wz 'Get data bit 3 into carry if_nz mov out_1, wire_1 'To toggle wire 1... if_z mov out_1, wire_0 '...or wire 0 xor outa, out_1 'Toggle selected wire test ttoken, #%0_00000100 wz 'Get data bit 2 into carry if_nz mov out_1, wire_1 'To toggle wire 1... if_z mov out_1, wire_0 '...or wire 0 xor outa, out_1 'Toggle selected wire test ttoken, #%0_00000010 wz 'Get data bit 1 into carry if_nz mov out_1, wire_1 'To toggle wire 1... if_z mov out_1, wire_0 '...or wire 0 xor outa, out_1 'Toggle selected wire test ttoken, #%0_00000001 wz 'Get data bit 0 into carry if_nz mov out_1, wire_1 'To toggle wire 1... if_z mov out_1, wire_0 '...or wire 0 xor outa, out_1 'Toggle selected wire test ttoken, #%1_00000000 wz 'Get "control" indicator into carry if_nz mov out_1, wire_1 'To toggle wire 1... if_z mov out_1, wire_0 '...or wire 0 xor outa, out_1 'Toggle selected wire nop 'Bit time delay before comming to rest. nop nop mov outa, #%00 'Set wires to rest (0,0) state. token_tx_ret retThe 5Mb/s code to receive looks like:
token_rx mov rtoken, #0 waitpne rest_state, pins_rx 'Wait for wires to leave the rest state mov in_0, ina 'Get wires from P0 and P1 test in_0, #%1000 wz 'Test for wire 1 change if_nz or rtoken, #%0_10000000 'Wire 1 set so set data bit 7 nop 'Delay to get subsequent samples nearer the nop 'middle of bit periods. mov in_1, ina 'Get wires from P0 and P1 xor in_0, in_1 'Get wire changes test in_0, #%1000 wz 'Test for wire 1 change if_nz or rtoken, #%0_01000000 'Wire 1 change so set data bit 6 mov in_0, ina 'Get wires from P0 and P1 xor in_1, in_0 'Get wire changes test in_1, #%1000 wz 'Test for wire 1 change if_nz or rtoken, #%0_00100000 'Wire 1 change so set data bit 5 mov in_1, ina 'Get wires from P0 and P1 xor in_0, in_1 'Get wire changes test in_0, #%1000 wz 'Test for wire 1 change if_nz or rtoken, #%0_00010000 'Wire 1 change so set data bit 4 mov in_0, ina 'Get wires from P0 and P1 xor in_1, in_0 'Get wire changes test in_1, #%1000 wz 'Test for wire 1 change if_nz or rtoken, #%0_00001000 'Wire 1 change so set data bit 3 mov in_1, ina 'Get wires from P0 and P1 xor in_0, in_1 'Get wire changes test in_0, #%1000 wz 'Test for wire 1 change if_nz or rtoken, #%0_00000100 'Wire 1 change so set data bit 2 mov in_0, ina 'Get wires from P0 and P1 xor in_1, in_0 'Get wire changes test in_1, #%1000 wz 'Test for wire 1 change if_nz or rtoken, #%0_00000010 'Wire 1 change so set data bit 1 mov in_1, ina 'Get wires from P0 and P1 xor in_0, in_1 'Get wire changes test in_0, #%1000 wz 'Test for wire 1 change if_nz or rtoken, #%0_00000001 'Wire 1 change so set data bit 0 mov in_0, ina 'Get wires from P0 and P1 xor in_1, in_0 'Get wire changes test in_1, #%1000 wz, wc 'Test for wire 1 change, C = Parity if_nz or rtoken, #%1_00000000 'Wire 1 change so set "control" bit mov in_1, ina test in_1, pins_rx wz 'Check wires for rest state (0,0) at end of token if_nz mov rtoken, minus_one 'Indicate parity error if need be.Sorry about the hard wired pin immediates.
This does work Prop to Prop, no alien hardware to test against yet.
Kuroneko: Thanks, I'll take a look when I have a mo.
Any chance you could stretch it to the 9 bits + "rest" I mentioned above[noparse]:)[/noparse]
I'd like to try it against real target hardware one day.
The actual 4 wire protocol is described in "XS1-L System Specification" here:
www.xmos.com/support/documentation
send and data, #$FF add data, #bit_table movs pattern, data nop pattern mov ptn, bit_table + 0 xor OUTA, ptn ror ptn, #2 xor OUTA, ptn ror ptn, #2 xor OUTA, ptn ror ptn, #2 xor OUTA, ptn ror ptn, #2 xor OUTA, ptn ror ptn, #2 xor OUTA, ptn ror ptn, #2 xor OUTA, ptn ror ptn, #2 xor OUTA, ptn nop ' just in case, andn OUTA, bit_pattern ' if bus should be set to IDLE state send_ret ret bit_pattern long %0011 bit_table long %1010101010101010 long %0110101010101010 long %1001101010101010 ' cut here - total 256 entries long %1001100101010101 long %0101100101010101 long %1010010101010101 long %0110010101010101 long %1001010101010101 long %0101010101010101 ptn res 1It's a nice mirror image of kuroneko's also elegantly brilliant Rx solution at 10Mbs.
kuroneko, in your solution you mention the overheads of the table lookup after a byte reception. It does not look like too much though. There are a few other things that need doing at that point to satisfy the higher level protocol requirements. When talking to the target hardware it is possible to configure it put quite large delays between bytes.
Thing is, I was very keen on not using more than two COGs to do this duplex link. COGS are precious.
Looks like I have my work cut out now to test this Prop to Prop.
So Andrey and kuroneko looks like you are both sharing the prize in this challenge. Two instructions per bit must be the limit. What prize you ask? ..err..um..I'll think of something.
Is it OK with you two if I use those codes in my final object for this protocol?
Can be MIT license or whatever if you like.
I get a bit nervous when the pre/post processing takes up nearly as much time as the actual transfer [noparse]:)[/noparse] Just thought I mention it in a comment.
No problems from my side. Thanks.
A big thank you for your contribution.
The "tokens" exchanged with the target hardware or actually 9 bits long. That means the table used in Andrey Demenev's 10Mbit/s Tx solution is not going to fit in COG.
May be the same with 10Mbit/s receiver, I'll have to check.
Could put the tables in HUB at risk of slowing things a bit. Still that's a lot of HUB space to chew up. Must be able to squish them into 256 LONGs.
Post Edited (kuroneko) : 12/16/2009 9:01:40 AM GMT
