BS1 and Thermistor — Parallax Forums
BS1 and Thermistor
kishkumenkishkumen Posts: 3
edited 2009-12-14 21:38 in BASIC Stamp
Dear Sir:
I need some help. I want to use a Thermistor to read temperature in my smoker. I seen in the Stamp1 manual about using a Thermistor from Radio Shack to read the temperature, but this Thermistor is no longer carried by Radio shack. I can of course can get a different make.
My question is will the different type Thermistor read so far off that it will not work and can it read higher then 149 deg.
I need to read up to 170·deg
Thank You,
Kishkumen
Post Edited (kishkumen) : 12/14/2009 8:30:01 AM GMT
  • $WMc%$WMc% Posts: 1,884
    edited 2009-12-14 07:43
    kishkumen
    I'm not sure what Thermistor Your useing,·But if You post the code Your useing
    We'll help You make it work!
    The Truth is out there············___$WMc%___···························· BoogerWoods, FL. USA
    edited 2009-12-14 07:59
    kishkumen
    To help You to get the hang of the forums, You need to fill in the subject part of the POST. its not a biggy, but some others will crip about "no subject" on Your post.
    Simply click on the pencil icon on Your post and You can easily edit Your post.
  • kishkumenkishkumen Posts: 3
    edited 2009-12-14 08:01
    Hi $WMc%
    I'm using part of the code that parallax siad to use with a Thermistor, the Thermistor I want to use is a NTC-101.
    Here is the program.
    ' {$STAMP BS1}
    ' Program THERM-A.BAS
    ' This program reads a thermistor with the BASIC pot command,
    ' computes the temperature using a power-series polynomial equation,
    ' and reports the result to a host PC via the Stamp cable
    ' using the debug command.
    ' Symbol constants represent factored portions of the coefficients
    ' C0, C1, and C2. "Top" and "btm" refer to the values' positions in
    ' the fractions; on top as a multiplier or on the bottom as a divisor.
    SYMBOL co0 = 162
    SYMBOL co1top = 255
    SYMBOL co1btm = 2125
    SYMBOL co2bt1 = 25
    SYMBOL co2top = 3
    SYMBOL co2btm = 50
    Check_temp:
    PAUSE 1000 ' pause 1 sec
    POT 0,46,W0 ' 46 is the scale factor.
    LET W1 = W0*W0/co2bt1*co2top/co2btm
    LET W0 = W0*co1top/co1btm+W0
    LET W0 = co0+W1-W0
    LET PINS = 00100000 'All pins set to input except pin 2
    DEBUG W0 ' show smoker temp on main computer
    IF PIN1 = 1 THEN lowtemp 'next four pins are temp zones
    IF PIN3 = 1 THEN midtemp
    IF PIN4 = 1 THEN Hightemp
    IF PIN5 = 1 THEN steamtemp
    lowtemp: IF W0 > 130 THEN lowtemp_A
    IF W0 < 128 THEN lowtemp_B
    lowtemp_A:
    LOW 2
    GOTO Check_temp
    lowtemp_B:
    HIGH 2
    GOTO Check_temp
    midtemp: IF W0 > 145 THEN midtemp_A
    IF W0 < 143 THEN midtemp_B
    midtemp_A:
    LOW 2
    GOTO Check_temp
    midtemp_B:
    HIGH 2
    GOTO Check_temp
    Hightemp: IF W0 > 160 THEN Hightemp_A
    IF W0 < 158 THEN Hightemp_B
    Hightemp_A:
    LOW 2
    Hightemp_B:
    HIGH 2
    GOTO Check_temp
    steamtemp: IF W0 < 250 THEN steamtemp_A
    steamtemp_A:
    HIGH 2
    GOTO Check_temp
    END
    edited 2009-12-14 08:27
    kishkumen
    Dose your local RadioShack carry any other thermistor?
    edited 2009-12-14 08:33
    kishkumen
    Take a look at the Parallax web site home page.
    Surf there home site well, I think you'll find what Your after.
    edited 2009-12-14 16:04
    $WMc%
    I did as you said, I looked·at the Parallax web site good and found no Thermistor listed there.
    No, Radio Shack does not handle any Thermistors at this time.
    Thank you for your help.
    Kishkumen
    kishkumen:
    PM·me your address and I'll mail you a RadioShack thermistor, SKU # 271-110 such as seen at http://www.extremenxt.com/temp.htm . Discontinued many moons ago, I still have a couple new units.
    Merry Christmas from erco!
