Can you use FT232RL LDO reg to power RS485 driver?
Would you guys conclude from the info below that the FT343RL would be OK powering a MAX3430 RS485 line driver?
The FT232RL states that 50mA can be drawn from it's LDO 3v3 out. The MAX3430 Supply current states 10 mA.
Seriously, it looks like it should work, barring any overloads. Besides, the alternative is a lot more complicated. I'm not sure where they get the 10mA, BTW. The driver provides at least 1.5V into a 54-ohm differential load. That's 27mA. As a consequence, I would recommend using AC termination at the far ends of your network, rather than DC. Each would consist of a 120-ohm resistor in series with a 10nF cap. That will be enough to suppress echoes without excessive DC current draw.
I think I may have the real world thing backwards.
