Bs2SX microcontroller, servo motoring not rotating properly
I need help, i used the examples in the manual for activity 6 that is to check the wheel rotation by inserting the duration 650 and 850
i realised even when i insert both wheels with 650, the wheels are still rotating in the opposite direction.
Do
pulsout 13, 650
pulsout 12, 650
Loop
I had done manual calibration on the servo to stop spinning at 750 already. But why is it still behaving weirdly?
Do
pulsout 13, 650
pulsout 12, 650
Loop
Shawn Lowe
When all else fails.....procrastinate!
You need to have a 20ms pause between each pass through the loop.
- Stephen
