Question about Constants / Variables in Spin — Parallax Forums
CassLanCassLan Posts: 586
edited 2009-12-11 22:17 in Propeller 1
Hi all,
If I define a constant as the sum of two variables:
CON
     VARSUM = VAROne + VARTwo
VAR
     Byte VAROne, VARTwo
As I change the values of VAROne and VARTwo, will the value of VARSUM change automatically?
Or would I have to make VARSUM a variable and update its value as VAROne and VARTwo change?
I would test this but am not near a setup right now, and am making some outlines for a program.
Rick
NYC Area Prop Club
Prop Forum Search (Via Google)
    edited 2009-12-11 21:34
    I don't have my prop hooked up, but it doesn't compile...
    OBC
    New to the Propeller?
    1152 x 864 - 104K
  • jazzedjazzed Posts: 11,803
    edited 2009-12-11 21:44
    CassLan said...
    A constant can only change at compile time. Be thankful that the example does not compile [noparse]:)[/noparse]
  • Luis DigitalLuis Digital Posts: 371
    edited 2009-12-11 21:54
    The operations in the "CON" section are performed by the Propeller IDE (compile time) no Propeller Chip (run time).
    CON
    It is simply a reference, something easy to remember.
    edited 2009-12-11 21:56
    Constants are computed at compile time.
    If you calculate something with a constant, then use that constant in your program, the value result of the calculation will be put into the program just as if you had typed it in.
    Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
  • CassLanCassLan Posts: 586
    WOW, talk about fast responses!
    Ok, I see, at compile time it replaces chunks of my program with the appropriate values for the constants, its merely a human aid in writing the software.
    Thanks!
    Rick
    NYC Area Prop Club
