Question about Constants / Variables in Spin
Hi all,
If I define a constant as the sum of two variables:
As I change the values of VAROne and VARTwo, will the value of VARSUM change automatically?
Or would I have to make VARSUM a variable and update its value as VAROne and VARTwo change?
I would test this but am not near a setup right now, and am making some outlines for a program.
Rick
NYC Area Prop Club
Prop Forum Search (Via Google)
CON
VARSUM = VAROne + VARTwo
VAR
Byte VAROne, VARTwo
Rick
NYC Area Prop Club
OBC
New to the Propeller?
CON
It is simply a reference, something easy to remember.
If you calculate something with a constant, then use that constant in your program, the value result of the calculation will be put into the program just as if you had typed it in.
Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
Ok, I see, at compile time it replaces chunks of my program with the appropriate values for the constants, its merely a human aid in writing the software.
Thanks!
Rick
NYC Area Prop Club
