current sensing for stepper/DC motor feedback
Beau Schwabe, tossed in a stepper current sensing idea for stepper motors in http://forums.parallax.com/forums/default.aspx?f=25&m=408791 and think it includes for some very interesting design problems. Especially if you are looking for high accuracy and speed... and barley know what you are doing (like me)
I was looking at a current control scheme for two stepper motors. I want to use the motors for positioning but also force censing in a human interface application.
The principle is kind of a similar to those exoskeleton robot suits but not nearly as cool. I bought 2 precision micro stepper linear actuators at a surplus store on the cheap. They are super nice at .001"/step and about 1" travel. If the current consumed with each step is measured it should be reasonable to determine the amount of force exerted by a person on the actuator as it moves. As long as they don't exceed the stall current of the motor... The actuator uses a tiny acme screw so no force exerted by the user may spin the motor.
I am still in the research phase but to I was thinking of using some TSC101 High side current sensing amplifiers and a MCP3208 8 channel ADC
The TSC101s measure the current across a shunt resistor on each coil and outputs .3 - VCC . The shunt resistors are chosen that I may overvolt my motors while staying within my max motor specs.
The problem is that the 2 measuring inputs on the TSC101 have polarity. Each coil on the motor would need 2 shunt resistors and two current sensing amplifiers to deal with the alternating DC voltage. That leads to multiplexing the current sensing amplifiers in sync with the step frequency of the motor... and this scheme is starting to get a bit messy on the hardware side.
There must be a better way...
@beau mentioned that he had employed a current control scheme on a dc motor, does any one have any information on this?
Graham
"There must be a better way...
@beau mentioned that he had employed a current control scheme on a dc motor, does any one have any information on this?"
When doing this, I basically applied a variable voltage switch mode power supply of my own design to control the motor speed. This kept the voltage constant across the motor regardless of the load. Free-spinning the motor would settle on a specific speed, introducing a mechanical load to the motor caused the switch mode power supply to dynamically adjust to maintain a constant voltage as well as speed to the motor.
The variable voltage switch mode power supply is really nothing more than standard PWM motor control. The difference is that you add voltage feedback to the existing PWM method to create a PID control loop.
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 12/10/2009 8:13:46 PM GMT
DC servos on the other hand do not draw any current unless they have to so if they are stopped they draw no current and if you "flight them" they will draw more current to counteract that so could be used for force feedback.
Graham
From what I have learned about steppers this far is that they are ALWAYs drawing full current which is why they have the torque at low speed.· So, if at idle or·at speed it is drawing full current, then sensing current isn't possible.· Furthermore, you cannot over "current" a stepper motor without damage.· Inversely, you cannot reduce current without risk of the motor losing position if there are forces acting against it.·
I had hashed this out with Mariss at Gecko drives about a year ago as I was attempting to do something like this.· However, he did get deeper into the "magic" of electronics and suggested there could be some way of doing it but I recall it seeming to be impractical for some reason.· Anyway, just wanted to try and prevent someone from chasing a ghost that can't be caught.
Chris
Look at:
http://roko.ca/robotics/h-bridge-fundamentals/3
You just put your current sensing resistor from V- to ground and V+ to your supply.
Graham
