Digital servo's on USB servocontroller — Parallax Forums
SkalTuraSkalTura Posts: 14
edited 2010-02-03 15:24 in Propeller 1
Sorry if my English is not correct, but I'm from the Netherlands...
I bought the Propeller USB Servo Controller (no. 28830) recently.
I have a few digital servo's from Graupner (model: DS 8041) that don't seem te work on this controller. The servo's are working on my RC receiver, so I know they are not defective. And when I connect them to a PIC 16F628A micro-controller and use the PIC Basic "servo" command to control them, they also work.
When I try to control the digital servo's with the PSCI software, downloaded from the Parallax website, that don't do anything. My normal servo's do work with this software.
Does anyone here has experience with digital servo's and this USB servo controller ?
Many thanks !!
    edited 2009-12-05 19:45
    These look like a standard servo with digital electronics and should work just fine with the Propeller Servo Controller. That's strange.
    edited 2009-12-05 20:26
    Do you have a chance to measure the pulsefrequencies ?
    analog servos need a 1-2millisecond pulse every 20 milliseconds.
    Digital servos need a much shorter pulse every 400 microseconds
    best regards
    Stefan
  • Graham StablerGraham Stabler Posts: 2,510
    edited 2009-12-05 20:32
    I'm fairly sure they take the same input signal and he finds it works from his receiver and the PIC fine.
    www.futaba-rc.com/servos/digitalservos.pdf
    Graham
  • SkalTuraSkalTura Posts: 14
    edited 2009-12-05 20:52
    I have a scope, and I have measured the output of my RC receiver. The pulses from the receiver are between 1 and 2 milli seconds.
    I programmed a simple test program on a PIC 16F628A micro-controller to test my digital servo's. This uses the same pulse, and on this test setup the digi-servo's also work, so I don't understand why they don't work on the USB controller.
    I haven't measured the output of the USB controller on my scope, I'll try this tomorrow. (time difference, I'm going to bed now)
    Thanks!
  • T ChapT Chap Posts: 4,248
    edited 2009-12-05 21:01
    You should post your entire code (use attachment if it is a large program) so that others can more easily spot your problem.
    I have used the Prop to drive digital servos, no difference in operation. I use a variation shown below to drive digital servos. You adjust the Time ON to set the position.
    You could also just do a crude test of a basic spin loop to see if you can get a motor working:
    PUB Rotate
      dira[noparse][[/noparse]18] := 1    'set your pin here
      repeat
        outa[noparse][[/noparse]18] := 1
        waitcnt(cnt + 1_362_000)   ' TIME ON   :   vary  this to see what works
        outa[noparse][[/noparse]18] := 0
        waitcnt(cnt + 200_000)
  • hover1hover1 Posts: 1,929
    edited 2009-12-05 21:50
    Interesting..
    I have used a few digital servos on the previous USB servo controllers, (28823 - discontinued), without a problem or need to program the servos.
    That said, I just did a test, as I am using the Propeller Servo Controller in a new project.
    Propeller Servo Board and PSCI (remember it's still Beta)
    Standard Hitec HS-55, repsonds normally.
    Hitec HSR-5990TG Digital Servo, responds normally.
    JR DS8711 Digital Servo, responds very erratically, sometimes not at all, sometimes a 2-3 lag time between moves.
    Thinking it might be a problem inthe PSCI program, I made a little repeating loop in 12Blocks.
    JR DS8711 Digital Servo, responds very erratically, moves when 5 second pauses are called for (not supposed to move).
    I'm going to have to pull out my RC transmitter and test the JR in a regular RC setup to see if it operational. I have 3 more of the JR servos that I will get from work tommorrow to test them also.
    Stay tuned,
    Jim
    @ Todd
    http://www.parallax.com/Portals/0/Downloads/docs/prod/motors/28823_Setup%20PSCI.zip
    SkalTura said...
    Many thanks !!
    Post Edited (hover1) : 12/5/2009 9:55:50 PM GMT
    edited 2009-12-06 07:04
    Okay... hooked up my scope to the USB servo controller and now I'm even more confused than before.
    When I connect a normal servo, there seems to be some noise on the signal. However, this doesn't seem to be a problem for the servo. It works just fine.
    But, when I connect a digital servo, there is no signal left. Just random noise on the scope screen.
    I made 2 movies and put them on my server since I can't upload WMV files.
    Movies of the scope screen with a normal servo connected: www.hacsoftwarecompany.com/test/normal_servo.wmv
    Movies of the scope screen with a normal servo connected: www.hacsoftwarecompany.com/test/digital_servo.wmv
    Hope it makes sense to you because I don't understand what is going on.
    But like "hover1" said, it could be the program... Because when I connect the digital servo to a microcontroller or to mt RC receiver, the servo's work perfectly.
    I haven't tested the servo controller by connecting it to a microcontroller, because I only understand PIC Basic (Crownhill) and haven't figured out jet how to do this.
    Post Edited (SkalTura) : 12/6/2009 7:11:54 AM GMT
    edited 2009-12-06 07:36
    Might be a hardware problem
    Did you scope the output with the servo DISconnected ?
    There is not much to see on both videos
    Can you record again with a timebase that 2 or 3 pulses can be ssen on the screen ?
    How was the trigger of the O-scope configured ?
    adjust the trigger to channel not to auto and adjust the triggerlevel to around 1V
    best regards
    Stefan
    Post Edited (StefanL38) : 12/6/2009 7:44:43 AM GMT
    edited 2009-12-06 08:17
    Yes Stefan, I did measure the output without a servo and I see the same noise as the video with the normal servo.
    But like "hover1" said, it could be the software because he had problems with the JR servo's *** well.
    Made a picture of the scope screen without a servo connected and with the settings you suggested. Same noise, but I'm not sure if this is supposed to be there since my normal servo's work fine.
    I'll try to find a digital Futaba or HiTech servo to test with first so I can find out if my controller is defectiv, or that it's my Graupner servo's that cause the problem.
    Thanks!
    1024 x 768 - 78K
    edited 2009-12-06 09:44
    @Hanno:
    as I still haven't took time myself to explore the possabilities of ViewPort,
    is it possible to use ViewPort with the "Propeller Servo Controller USB" Parallax No #28830 ?
    I guess yes. Then it should be possible to see how the logic levels of the IO-Pins change over time.
    With this it should be possible to analyse if the noise comes from the program or from somewhere else
    @SkalTura: can you adjust your scope to a trigger-delay ?
    can you take another picture with a timebase that shows one pulse filling almost the screen
    and one picture showing the first 1/10th part of a pulse ?
    To have a better solution how the noise looks like ?
    and if you have a trigger-delay showing 1/10th of the pulse in the middle of the pulse ?
    Can you take two(three) pictures like descibed above but with the signal applied to a 10kOhm-resistor
    Servosignal
    and Probe >
    10kOhm
    Ground-of board---Ground of O-Scope
    best regards
    Stefan
    edited 2009-12-06 10:35
    Sorry... It's an old and very simple scope, no trigger delay.
    edited 2009-12-06 12:41
    Not so important. Do the rest without the trigger-delay
    best regards
    Stefan
    edited 2009-12-06 13:10
    As this is a propeller based system you could try using the servo32 object directly for testing purposes.
    It seems to me that the noise should no be there and this is a possible problem, perhaps related to your PSU or perhaps the firmware.
    Graham
    edited 2009-12-06 18:15
    I ran into a similar problem about a month ago, and shelved it due to consulting and PropellerBasic.
    I do have an idea worth testing... what if the servo's control input needs more current, or a higher voltage, than prop servo circuits normally provide?
    I usually use a 1k current limiting resistor in-line to the servo input, so maybe it needs more than ~3mA at 3.3V?
    www.mikronauts.com Please use mikronauts _at_ gmail _dot_ com to contact me off-forum, my PM is almost totally full
    Morpheusdual Prop SBC w/ 512KB kit $119.95, Mem+2MB memory IO board kit $89.95, both kits $189.95
    Propteus and Proteus for Propeller prototyping 6.250MHz custom Crystals run Propellers at 100MHz
    Las - Large model assembler for the Propeller Largos - a feature full nano operating system for the Propeller
    edited 2009-12-06 19:15
    Bill Henning said...
    Do you mean the voltage/current provided by the USB port that runs the servo controller, or the voltage/current that is used to power the servo's ? Because I have the hardware connected to the PC via USB, and a powersupply (stablized) of 5V 2.5A for servo power.
    edited 2009-12-06 19:24
    Bill means, the voltage/current on the servo-SIGNAL-input
    that one wire where the 1-2 millisecond-pulses comes into the servo
    maybe the servo needs REALLY 5V to work properly.
    What voltage does your RF-receiver deliver ?
    What voltage does your pic-testcircuit deliver ?
    I guess 5V. A propeller-io-pin DIRECTLY delivers just 3.3V.
    But I'm not sure what the servo-controller-board delivers.
    put a shunt-resistor in serial between prop-board and servo and measure the voltage-drop across a the shunt-resistor
    with your O-scope adjusted to the lowest voltage-scaling 5-20 millivolt / div
    then you can measure the current that flows while the signal-pulse is applied to the servo
    servo-board----shunt (0,1-10 Ohm)----servo
    can you measure a difference between your RF-receiver, PIC-tester and Prop-servo-board ?
    best regards
    Stefan
    edited 2009-12-06 19:41
    @ Bill and Stefan
    The new Propeller servo controller has voltage translators (TXB0108) at·each output. The servos should be getting a 5 Volt Signal. But this is based on the USB port providing enough current. I am in the consulting mode right now and have speced the new servo controllers in a new project. The same servo worked fine on the old USB servo controller. I am doing some more testing now.
    Jim
    edited 2009-12-06 19:46
    Graham,
    I tried Hanno's 12Blocks which uses Servo32V6 and overwrote the firmware, same outcome. I going to try Servo32V7 to see if there is a difference.
    Gosh..I wish my PropScope would get here. My 20 year old Phillips scope died this year.
    Jim
    Graham Stabler said...
    Graham
    edited 2009-12-06 19:48
    Just got back from work with 3 JR Digital Servos to try. Report back in a while.
    Update:
    Here's what I found with (3) JRDS8711 servos. None of them work with the Propeller USB Servo Board. The HiTec HSR-5990TG Digital Servo works just fine. I did a project about two months ago that used the JR DS8711 servo on the old USB Servo Controller (Parallax 28823) and it worked just fine. I still have one 28823 left, and I tested all the JR's and HiTec on it with PSCI software, and they all work fine.
    The following pics show P0 pin in 12Blocks, (pretty much ViewPort output).
    The JR Servo almost seems like it is injecting signals onto P0 during the time at which the Propeller is not outputting any. And during a normal 1.0ms or 2.0ms command, the trace shows trash. This may be the noise that was seen on the Grauptner servo?
    I have to drop this right now as I have another deadline for Monday, but will revisit this soon, as I have a project·based on this product.
    Chris, Josh, Dave. Have you got any Digital Servos to test this out on?
    Jim
    Post Edited (hover1) : 12/6/2009 9:19:47 PM GMT
    edited 2009-12-06 21:19
    Added new info.
  • W9GFOW9GFO Posts: 4,010
    edited 2009-12-06 21:31
    StefanL38 said...
    The vast majority of digital servos will work fine on a 1 -2 mS pulse every 20 mS. There are some specialty servos, like for use with a gyro that use shorter pulses and higher frame rates but that is not the norm.
    Rich H
    The Simple Servo Tester, a kit from Gadget Gangster.
    edited 2009-12-06 21:49
    Right Rich,
    And JR·sells this as a "drop in" replacement servo. I can't even find a JR programmer, but HiTec seems to think you need one.
    Jim
    @Stefan·(I THINK the 400 microseconds is done internally in the servo)
    W9GFO said...
    StefanL38 said...
    Rich H
    edited 2009-12-06 22:11
    SkalTura said...
    I wonder what would happen if you put a small cap across signal and ground?
    Rich H
    edited 2009-12-07 19:08
    I could try to measure with a small capacitor. But my normal servo's don't seem to be affected by the noise.
    I have over 17 years of experience with flying model airplanes and helicopters, and what I can remember from the early days is that Graupner used another signal than Robbe/Futaba and Multiplex. I'm not sure if this is still the case, because the servo's work on my Futaba RC receiver.
    So to make sure, I borrowed a digital Multiplex servo from a friend, and this one works fine with the USB servo controller using the beta software.
    Guess I'll sell the JR servo's on eBay and buy Futaba or HiTech instead ?
    Post Edited (SkalTura) : 12/7/2009 7:14:23 PM GMT
  • rough_woodrough_wood Posts: 61
    edited 2009-12-07 19:13
    Can a Parallax employee pipe in on this? I will be in the market for controlling 24+ servos before long and will go with Parallax if it can get buttoned down, otherwise I gotta grab that Lynxmotion one. I'd rather stick with Prop if possible.
    edited 2009-12-07 19:49
    I don't see any of them online, but·I did send an email to tech support asking them to look at this thread.
    Jim
    rough_wood said...
    edited 2009-12-07 20:12
    SkalTura said...
    Just reading again, this looks like the problem, it would seem as if the servo is pulling too much from the propeller pin. There should otherwise be no difference between having the servo connected and not.
    A series resistor on the signal line might be a good start.
    Graham
  • JDJD Posts: 570
    edited 2009-12-07 21:25
    Rough Wood,
    The controller that we have outputs the standard 1 to 2ms pulse that servos will operate at. There are some digital servos that will operate properly with those signal; however you would need to verify with the manual of the servo to verify or deny that. If the digital servos do not support the standard 1 to 2 ms pulse for operation; you can use the firmware we release for the PSC to support the new syntax to support the digital servos. We keep the firmware open as the PSC could be used in a number of ways other than a servo controller.
    I hope this helps,
    Respectfully,
    Joshua Donelson
    www.parallax.com
    edited 2009-12-07 21:42
    Graham,
    Not sure if you caught this information in one of my·last posts. The servo is not connected directly to the Prop,·it goes through a TI Voltage Level Translator:
    http://focus.ti.com/docs/prod/folders/print/txb0108.html
    Schematic of PSCU:
    http://www.parallax.com/Portals/0/Downloads/docs/prod/prop/PSCUsb_A%20Schematic.pdf
    I'm still stumped. The JR servo I am using is supposed to meet all standard servo specs.
    .....Waiting on PropScope.......
    Jim
    SkalTura said...
    Graham
    edited 2009-12-07 23:25
    OK so it has a buffer but he was saying he didn't see a signal to the servo just noise. If that is the case the issue it electrical not in software.
    Graham
