How do I get the HUB address of a DAT label that is located in an object ?
Bean
I has PASM code in the main file that needs to use COGINIT to start a PASM routine that is in an object.
I tried using mov __temp1,@MyObject.Labelname but that doesn't work. So I tried @@MyObject.Labelname (no dice), then I tried #MyObject.Labelname (no go).
The label is in the DAT section (PASM code).
Help...
Bean.
1st rule of finance...Don't lose money.
Never be ashamed of making an honest·profit.
Live within your means...Make do, or do without.
Help...
Bean.
With the Prop Tool, anyway. Maybe BradC's one is more flexible?
My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
If I have a PASM label in the same file I know that "mov __temp1,label" will get the cog address of the label, but will "mov __temp1,@label" give me the HUB address of that label ? This is because coginit requires the HUB address of the label.
Bean
test.spin is the main code and dosomething.spin is the object.
It should blink the LED on pin 16 for 10 seconds then stop. But it does nothing ???
Bean.
I think this would work:
[s] mov __temp1,par ' par is the same as this cogs par rdlong __temp2,__temp1 ' get address from hub variable "HubAddr" [/s] [s] coginit __temp2 WR ' Start cog and return new cogid mov cog1,__temp1 ' save cogid [/s]Ooops, I see the assembly coginit doesn't work like I thought...· I see why you need the shifts now...
Post Edited (Rayman) : 12/1/2009 8:34:50 PM GMT
Got it working. Thanks...
Bean.
For my own future reference I would like to see what you did. I have come across a similar situation in the past and had figured out some convoluted way to manage it.
Beau Schwabe
IC Layout Engineer
Bean.
[noparse]:)[/noparse]
But I'm sure you knew that...
Bean
DAT
something long 0
address_of_something long @@@something
