AiGeneric question - resolved
Bill Henning
I was trying a new 7" NTSC display, and ran into a weird problem:
- it displays a nice color picture when fed video from a cable box
- it displays B&W with a "herringbone" pattern from the AiGeneric text demo
Same AiGeneric demo works fine on my 3.5" NTSC displays.
Any ideas?
I'll try some other NTSC drivers tomorrow.
www.mikronauts.com Please use mikronauts _at_ gmail _dot_ com to contact me off-forum, my PM is almost totally full
Morpheusdual Prop SBC w/ 512KB kit $119.95, Mem+2MB memory IO board kit $89.95, both kits $189.95
Propteus and Proteus for Propeller prototyping 6.250MHz custom Crystals run Propellers at 100MHz
Las - Large model assembler for the Propeller Largos - a feature full nano operating system for the Propeller
Post Edited (Bill Henning) : 12/1/2009 4:08:41 AM GMT
Any ideas?
Try the Parallax Driver, and my 80 column text driver. Both of these do interlaced color.
Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
Do the same for the 80 column text driver, and the Parallax reference driver.
If both of those display properly in both vertically interlaced and non-interlaced modes, and or the other drivers mentioned display properly, then it's down to the color signal, and or line timing in AiGeneric.
To factor out line timing and such, go track down Cardboard Guru's simple NTSC demo. That one has fixed color timing also, but slightly different scan line timing from the AiGeneric. AiGeneric was built off of those drivers, and my original 8x8 NTSC drivers. Hippy converted my original ones and there might be some minor league difference that resulted from that.
I tried TV_Text and Graphics_demo today - both showed up in glorious shades of herringboned gray.
Does anyone have a simple PAL demo? This display is supposedly also PAL compatible.
I tried the second of the two displays, and what do you know, it works fine!
This one has a different firmware rev., the OSD is different.
