Can I connect LED and SSR to one PIN?
I am wondering whether I can drive an LED(2.1v- 25mA) and a SSR(Crydom - DMO063 - specs - attached).
I do not have an extra prop pin and I like to know when the relay was activated so as far I can see if I do not exceed the permissible
current capability but at the same time I wan't to be sure before I damage the DIP Prop (which are in shortage at present).
Siri
Siri
However if you use a high efficiency led it typically needs less than 5mA so the total would be 25mA max, and the answer would be YES.
Post Edited (kwinn) : 11/29/2009 3:36:01 PM GMT
Thanks for explaniing that.
Siri
Leon
Amateur radio callsign: G1HSM
The prop drives the base of the transistors and the transistors sink the voltage/current for both the LED and the SSR.·· The transistors are just some Radio Shack small signal·NPNs I had on hand.
Post Edited (photomankc) : 11/29/2009 5:19:44 PM GMT
