How many transistors does the Prop have?
W9GFO
The Penryn chip has 820,000,000 transistors. That's a lot!
How many are in the Propeller chip?
How many will be in the Prop II?
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
Rich H
I'm not at my desk right now to check, but I know the average transistor density for the Propeller II is about 1 transistor for every·2 square microns, so at 7mm square that works out to about 12,250,000 transistors.· Now, that's a little biased, since the last time I looked at the transistor density I was looking at the Propeller memories.
It really depends on the die size of the IC that you are refering to and what the average transistor density is.
Beau Schwabe
IC Layout Engineer
Chip Gracey
Memories: ---------------------- MEM_COG: Transistors = 344266 Area = 619008 um^2 MEM_DUALPORT: Transistors = 44724 Area = 113005 um^2 MEM_RAM: Transistors = 1673104 Area = 1736650 um^2 MEM_ROM: Transistors = 303876 Area = 572428 um^2 Digital: ---------------------- FUNC_MUL_16x16: Transistors = 11424 Area = 45260 um^2 FUNC_CORDIC: Transistors = 16764 Area = 52650 um^2 Analog: ---------------------- FUSE_BIT: Transistors = 49 Area = 953 um^2 PLL_MUL: Transistors = 489 Area = 6988 um^2 OSC_SHELL: Transistors = 158 Area = 32076 um^2 BOD_SHELL: Transistors = 200 Area = 71703 um^2 PUD_SHELL: Transistors = 152 Area = 106372 um^2▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Beau Schwabe
IC Layout Engineer
Chip Gracey
as having a certain number, some of which had no active role in performance gain. And hypothetically,
if a subsection of the circuit could be made with less transistors, then the power consumed by more is a loss.
Imagine using 8 MPUs, 9 SRAMs, a PROM, and 2 PIO/PIA ... 20 chips as 1 Propeller.
You'd need more voltage and current, and run slow and Hot, and have a lot more transistors.
