Novel technique using one pin with shift registers
This might be useful in some situations:
www.romanblack.com/shift1.htm
Leon
Amateur radio callsign: G1HSM
Leon
Eexcellent!
Beau Schwabe
IC Layout Engineer
Leon
That's a great find! I believe his '595 circuit can be improved, however, as follows:
In this circuit, an extended low on the input will cause the RCLK pin to go high, ahead of SCLK going high, which permits the use of all eight data bits. The Schmitt inverter also creates a snap action, which could be important for an edge-triggered input like RCLK.
www.edn.com/contents/images/6598372.pdf
It's similar to your circuit.
Leon
So Roman's idea to use an RC delay with the shift register is good and practical for those I/O strapped projects and quite useful for driving non-sensitive outputs such as indicators leds.
*Peter*
'Electronics Now' Magazine history in case you are interested
On page 13 of 'New Ideas' (attached image below) there is a project called 'Frequency-Boundary Detector' which uses two RC time constants to determine if an input signal is above or below a certain frequency. Sort of like a window comparator, but instead of voltage, it's used for frequency.
Beau Schwabe
IC Layout Engineer
