QFN SMD Question
Is the central square under the QFN Propeller a ground plane?
Should I solder it to the board?
If so I would have to connect it to ground by extending the Vss traces under the chip.
Is that the right thing to do?
Happy Thanksgiving!
I wonder if this wire is hot...
Happy Thanksgiving!
It should be grounded.
Leon
Amateur radio callsign: G1HSM
Post Edited (Leon) : 11/26/2009 7:40:17 PM GMT
I have never soldered a QFN before, but I have a plan.
What I intend is to etch a solder mask of the lands in a sheet of 5 mil copper, then squeegee in solder paste, place the components, and pan fry it on an electric hot plate.
The pan fry method works well for SX28/SS and 1206 SMD components, but this is really going to be pushing it.
Since I was feeling outlandishly optimistic I bought EEPOM in 8MSOP and voltage regulators in 6MLP as well.
The fallback plan is to reconfigure the whole thing for the TQFP package, but I bought 5 QFN propellers and I am going to give this a try.
How do you solder QFN or other no-lead packages?
Leon
I will report back if there is any progress.
Leon
I use a 10X jeweler's loupe or 3.5 diopter lens.
Good microscopes are not cheap.
The one I use at work costs about $100,000.
I'm pertty sure they would frown upon turning it into a soldering station.
Leon
Can I use a beautician's lens? The one with a circular fluorescent lamp?
The lens seems to restrict the movement of my iron, making soldering difficult.
www.fd.com.my
www.mercedes.com.my
Whether that magnifier works depends on your eyesight. I can't manage without the microscope.
Leon
Does your iron accidentally touch the lens or other parts of the microscope?
www.fd.com.my
www.mercedes.com.my
Can I use this microscope for PCB work?
my.farnell.com/duratool/59-020-040/microscope-stereo/dp/7222294
Is the lens too close to the board?
www.fd.com.my
www.mercedes.com.my
Here is Metcal:
www.metcal.com/
They aren't expensive if bought second-hand. Mine cost me £125 (GBP) with a new handpiece and some new cartridges.
Leon
I do use a Weller soldering station, a PU81 with a WSP80 pencil. It's not very cheap, but it will last for decades. I do have a second station, a WECP20 that is almost 30 years old (still getting parts, no problem).
For magnification, I do use lenses like these: <http://www.conrad.de/goto.php?artikel=814160> but without LED.
I'm not using solder paste, but 0.5 mm wire.
HTH,
Nick
Never use force, just go for a bigger hammer!
The DIY Digital-Readout for mills, lathes etc.:
YADRO
