measureing time of travel
I am working on a project and I am using Boe Bot robot and basic stamp Micrcntroller
I·want to use ·Whiskers to measure the time the robot has travelled without hitting an obsticle·.
And I am ·thinking·how to write the code·...
I want to avoid relying on a for lop counter to measure the time.
So I thought of using the methode COUNT
I appreciate any help or suggessions
Thanx
Post Edited (Jeena99) : 11/22/2009 8:13:57 AM GMT
Thanx
If/when the BoE-bot encounters an obstacle it could then read the time and then compare to that of the·previous obstacle/event.
Post Edit -- You could (??) increment a variable (Word)·each time you pass through a servo refresh routine, but that would have a top-end limitation (appx 20 min.)· Still, not real exacting.
Post Edited (PJ Allen) : 11/25/2009 10:04:49 PM GMT
Hook the output of the 555 circuit up to an input pin, then:
DO ' do some stuff ' output to motors PULSOUT, x,y,z PULSOUT, x,y,z 'update time IF whiskerL = 1 AND whiskerR = 1 THEN ' both off IF timeCount.BIT0 <> clock555pin THEN timeCount = timeCount + 1 ENDIF ELSE timeCount = 0 ENDIF IF timeCount > 120 THEN ' approx 30 seconds DEBUG "whoa, 30 seconds without an obstacle" ENDIF LOOP▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
What you`ve said is really helpful
Jeena
