How can the frequency be made vaiable
I have a Solenoid piston driven AC 110V 60Hz air pump.[noparse][[/noparse]EcoPlus Commercial air 1 #728450].These are normally used as aquarium air pumps.
I am trying to use for another application where I would like to be able to vary rate of the pumping action.When connected to AC as it is the pumps frequency is @ 3200/min.
The application I am working on require a variable frequency 30-600/min.
How can I achieve this?
Siri
P.S :
http://www.underwaterwarehouse.com/Medo-Linear-Air-Pumps-Air-Pumps-And-Accessories-sc-38.html
Please check this site for details of mechanism.
Siri
P.S :
What is your overall obejctive here? Reduced flow, or ... ?
My overall objective is to reduce the rate of the pulses to about 2400/min.
I will give SSR with zero-crossing detector.
Phil
I found this AC frequency changer for ? AC motors - can this be used to drive the Solenoid air pump.
i am attaching the specs of the frequency changer.
The site for the air pump is ----> http://www.underwaterwarehouse.com/Medo-Linear-Air-Pumps-Air-Pumps-And-Accessories-sc-38.html
The SSR only give me control of time but not the number of strokes.Changing thr stroke frquency is wgat I am after.
Siri
Siri
apparently by resonance and a diode, the waveform was mostly 30Hz with a CRO-visible 60hz bump.
And there was another way to do it with 3 donut-sized toroids.
(Rotary phones ring with usually 20 Hz 90 V, but 30 Hz 100 V worked too)
Analog frequency division is black magic, except by dynamotor.
