Power Supply for a ICL7135 +/- 5 volt power supply vs 5 power supply what is th
In the three Panel Meter that I have they all are power with only a 5 volt power supply
Help me understand what the difference would be in easy to understand laymen term
Thanks for your help in this matter
This is the Project that I am working which power supply would better to use and why
Please explain in detail if you would
5 volt supply
or a
±5V supplies
Power Supplies
The ICL7135 is designed to work from ±5V supplies.
However, in selected applications no negative supply is
required. The conditions to use a single +5V supply are:
1. The input signal can be referenced to the center of the
common mode range of the converter.
2. The signal is less than ±1.5V.
See "differential input" for a discussion of the effects this will
have on the integrator swing without loss of linearity.
Differential Input
The input can accept differential voltages anywhere within the
common mode range of the input amplifier; or specifically from
0.5V below the positive supply to 1V above the negative
supply. In this range the system has a CMRR of 86dB typical.
However, since the integrator also swings with the common
mode voltage, care must be exercised to assure the integrator
output does not saturate. A worst case condition would be a
large positive common-mode voltage with a near full scale
negative differential input voltage. The negative input signal
drives the integrator positive when most of its swing has been
used up by the positive common mode voltage. For these
critical applications the integrator swing can be reduced to
less than the recommended 4V full scale swing with some
loss of accuracy. The integrator output can swing within 0.3V
of either supply without loss of linearity.
Differential Input
··Thanks for any·
·that you may have and all of your time finding them
Sam
Post Edited (sam_sam_sam) : 11/23/2009 1:21:07 AM GMT
5 volt supply
or a
±5V supplies
Power Supplies
Differential Input
Differential Input
··Thanks for any·
Sam
ICL7135 To a Prop Chip Feed back on board design Need Please Project in the works (Re-Named)
·I having hard time understanding what they are talking about
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 11/23/2009 2:29:13 AM GMT
