stamp BSX avec Matrix orbital LK 204-25-wb-c74
Hello
i am french, sorry for my bad english, i have need information for connect the matrix orbital LK 204-25-WB whis keyboard in serial whis BASIC STAMP BSX or BS2
Thank you verry mutch
"Merci beaucoup"
Denis France
"Merci beaucoup"
Denis France
Obviously, you must have a source of power and ground for the display. Page 10 of the documentation shows where to connect power and ground.
You can connect the Tx and Rx signals to the Stamp using either the connections on page 10 or the DB-9 connector shown on page 9. The BASIC Stamp Syntax and Reference Manual (www.parallax.com/Portals/0/Downloads/docs/prod/stamps/web-BSM-v2.2.pdf) shows how to connect a DB-9 connector to Stamp I/O pins (pages 395 and 417).
There's nothing special about using the keyboard with the LK204-25. The documentation explains how the keyboard works and describes the commands to the LK204-25 to change how the keyboard and LK204-25 behaves.
I believe the default is for the LK204-25 to send the code for each keypress to the Stamp.
Denis
www.parallax.com/Portals/0/Downloads/docs/cols/nv/vol3/col/nv85.pdf
The BS2 and BS2sx operate at different speeds and some statements (like SERIN and SEROUT) use numbers to specify timing (like Baud) that are different from one Stamp model to another. The Stamp Manual and the Stamp Editor's help files give the different values needed for the different Stamp models. Look at the sections on the SERIN and SEROUT statements.
Denis
SEROUT <pin>,16504,[noparse][[/noparse]"Hello there",CR]
The "16504" specifies 19,200 Baud and inverted mode which is used with the connections shown on page 417 of the Stamp Manual.
To use the DB-9 connector (RS232) you need to use a line driver chip such as·a Maxim Max233a or Max232 to handle the 12v vs 5v serial signal.
From page 17 of the manual:· http://www.matrixorbital.ca/manuals/LK_series/LK204-25/LK204-25.pdf
The display module communicates at standard voltage levels of ±12V to ±12V or at TTL levels of 0 to +5V by setting the Protocol Select Jumpers to TTL."
There is more information at:· http://www.matrixorbital.ca/appnotes/basic_stamp/
' {$STAMP BS2} ' {$PBASIC 2.5} 'TrueBaud mode for non-inverted 9600-N81 (MAX233a line driver) 'InvBaud mode for inverted, 9600-N81 (direct connect e.g. w/22k ohm) #SELECT $STAMP #CASE BS2, BS2E, BS2PE TrueBaud CON 84 InvBaud CON 16468 #CASE BS2SX, BS2P TrueBaud CON 240 InvBaud CON 16624 #CASE BS2PX TrueBaud CON 396 InvBaud CON 16780 #ENDSELECT LCD CON 14 'LCD constants & variables I2C_addr CON 51 '[noparse][[/noparse]addr] 0x00-0xFF default 0x50 BaudRate CON 57 '[noparse][[/noparse]speed] 53(1200) 29(2400) CF(4800) 67(9600) 33(19200) 22(28800) 19(38400) 10(57600) default 19200 nonstdBaudRate CON 164 '[noparse][[/noparse]speed] displayOn CON 66 '[noparse][[/noparse]min] delay on for 0-100 minutes 0-stays on displayOff CON 70 brightness CON 153 '[noparse][[/noparse]brightness] 0-255 SaveBrightness CON 152 '[noparse][[/noparse]'brightness] Contrast CON 80 '[noparse][[/noparse]contrast] 0-255 SaveContrast CON 145 '[noparse][[/noparse]contrast] remember CON 147 'switch 0=no 1=yes remembers Scroll, LineWrap, cursor type & state, etc version CON 54 'return version number e.g. 0x10 (ver 1.0) 0x42 (version 4.2) model CON 55 '0x09 LK204-25 clearSCR CON 88 goHome CON 72 ScrollOn CON 81 ScrollOff CON 82 curPos CON 71 '[noparse][[/noparse]col] [noparse][[/noparse]row] LineWrapOn CON 67 LineWrapOff CON 68 ChgStartUpScr CON 64 '[noparse][[/noparse]chars] note: will autowrap curBack CON 76 curFwd CON 77 ulCursOn CON 74 ulCursOff CON 75 blkCursOn CON 83 blkCursOff CON 84 'Once you have defined a custom character you may display it by sending the display module the [noparse][[/noparse]refID]. For example if a custom character was 'saved in position one, the command to display the custom character, at the current cursor position, would be simply to send the number one to 'the display module without quotes. CustChar CON 78 '[noparse][[/noparse]refid] [noparse][[/noparse]data] refid=0-7 data is 8 bytes (bits patterns) SaveCustChar CON 193 '[noparse][[/noparse]bank] [noparse][[/noparse]refid] [noparse][[/noparse]data] bank=0-4 refid=0-7 data is 8 bytes (bits patterns) LoadCustChars CON 192 '[noparse][[/noparse]bank] bank=0-4 SaveStartScr CON 194 '[noparse][[/noparse]refid] [noparse][[/noparse]DATa] InitMedNum CON 109 placeMedNum CON 111 '[noparse][[/noparse]row] [noparse][[/noparse]col] [noparse][[/noparse]digit] InitLgNum CON 110 placeLgNum CON 35 '[noparse][[/noparse]col] [noparse][[/noparse]digit] InitHorzBar CON 104 placeHorzBar CON 124 '[noparse][[/noparse]col] [noparse][[/noparse]row] [noparse][[/noparse]dir] [noparse][[/noparse]length] direction=0(right) or 1(left) length in pixels InitNarVertBar CON 115 InitWidVertBar CON 118 placeVertBar CON 61 '[noparse][[/noparse]col] [noparse][[/noparse]length] length in pixels gpoOff CON 86 'General Purpose Output off [noparse][[/noparse]num] (ground) gpoOn CON 87 'General Purpose Output on [noparse][[/noparse]num] (5v 20mA) gpoStartState CON 195 '[noparse][[/noparse]num] [noparse][[/noparse]state] 0=0ff 1=on Prefix CON 254 'LCD command prefix i VAR Byte DEBUG DEC truebaud SEROUT LCD,truebaud,[noparse][[/noparse]254,"X"] 'SEROUT LCD, 16416,[noparse][[/noparse]254,"G",$03,$02] 'Set cursor position to column 3, row 2 SEROUT LCD, truebaud,[noparse][[/noparse]"Test message"]·
en francais: Merci a tous pour votre aide vous etes tr
