BalancingRobot
I also made up BalancingRobot to read it for stamp.
I used MX2125 instead of Ping-sensor and I used single motor.
Rewrited program to Prop it for stamp.
But it don't operate at all. Soon fall out.
I changed Kp/Ki/Kd much , but no good.
Why not operate?
Please give me any hint.
Why not operate?
CON _clkmode = xtal1 + pll16x ' System clock → 80 MHz _xinfreq = 5_000_000 scale = 80 Kp = 4 Ki = 3 Kd = 5 DriveEnablePin = 3 DriveForwardPin = 4 DriveReversePin = 5 VAR long stack1[noparse][[/noparse]20] long xmG OBJ debug : "FullDuplexSerialPlus" ' Debugger PUB main | setPoint, pTime, cur_error, sum_error, last_error, secondlast_error, delta_error, p, i, d, drive ' Initialize debug.Start(31, 30, 0, 57600) ' Start FullDuplexSerialPlus waitcnt(clkfreq+cnt) ' Wait for PST to get connected debug.tx(Debug#CLS) setPoint := 500 dira[noparse][[/noparse]driveEnablePin]~~ ' make output pin *output* dira[noparse][[/noparse]driveForwardPin]~~ ' Make drive forward pin output dira[noparse][[/noparse]driveReversePin]~~ ' Make drive Reverse pin output outa[noparse][[/noparse]driveEnablePin]~~ outa[noparse][[/noparse]driveForwardPin]~~ outa[noparse][[/noparse]driveReversePin]~~ cognew(mx2125, @stack1) repeat debug.Str(String("xmG:")) debug.Dec(xmG) debug.tx(13) pTime := xmG + 500 cur_error := setPoint - pTime p := cur_error * Kp sum_error := cur_error + last_error + secondlast_error i := Ki * sum_error delta_error := cur_error - last_error d := Kd * delta_error drive := p + i + d debug.Str(String("p")) debug.Dec(p) debug.tx(13) debug.Str(String("i")) debug.Dec(i) debug.tx(13) debug.Str(String("d")) debug.Dec(d) debug.tx(13) debug.Str(String("drive:")) debug.Dec(drive) Motor(drive) secondlast_error := last_error last_error := cur_error debug.tx(13) waitcnt(clkfreq/50 + cnt) PUB mx2125 | xRaw, _xRaw repeat xRaw := PULSIN_Clk(0,1) _xRaw := xRaw/scale xmG := ((_xRaw /10) - 500) * 8 PRI PULSIN_Clk(Pin, State) : Duration DIRA[noparse][[/noparse]Pin]~ ctra := 0 ctra := (%11010 << 26 ) | (%001 << 23) | (0 << 9) | (PIN) ' set up counter, A level count frqa := 1 waitpne(State << pin, |< Pin, 0) ' Wait for opposite state ready phsa:=0 ' Clear count waitpeq(State << pin, |< Pin, 0) ' wait for pulse waitpne(State << pin, |< Pin, 0) ' Wait for pulse to end Duration := phsa ' Return duration as counts ctra :=0 ' stop counter PUB Motor(drive) if drive > 0 outa[noparse][[/noparse]DriveForwardPin]:= 0 ' L-active outa[noparse][[/noparse]DriveReversePin]:= 1 ' L-active debug.Str(String("forward:")) Pulsout(driveEnablePin, drive+500) debug.Dec(drive+500) debug.tx(13) elseif drive < 0 outa[noparse][[/noparse]DriveForwardPin]:= 1 ' L-active outa[noparse][[/noparse]DriveReversePin]:= 0 ' L-active debug.Str(String("reverse:")) Pulsout(driveEnablePin, ||drive+500) debug.Dec(||drive+500) debug.tx(13) else outa[noparse][[/noparse]DriveForwardPin]:= 1 ' L-active outa[noparse][[/noparse]DriveReversePin]:= 1 ' L-active debug.Str(String("stop:")) debug.tx(13) PRI Pulsout(Pin, Duration) debug.Str(String("pulse:")) !outa[noparse][[/noparse]Pin] waitcnt(clkfreq/100000*Duration + cnt) !outa[noparse][[/noparse]Pin]
diydrones.com/profiles/blog/show?id=705844:BlogPost:41145
There is how to measure of InclinationSensing in application-note(www.memsic.com/data/pdfs/an-00mx-007.pdf) of MEMSIC.
But InclinationSensing for BalancingRobot cannot measure?
In short, if your robot isn't moving then you can use the accelerometer to measure angle. You may be able to pull some fancy tricks that take a sample at a stationary moment, but that would probably be very difficult to implement.
There is document of Pallax.
http://forums.parallax.com/attachment.php?attachmentid=40342
Above, there is application for monitoring angle for moving object.
I found out this pdf.
www.parallax.com/Portals/0/Downloads/docs/article/ROBOT-Fall06-BalancingBot.pdf
MX2125 use as sensor of BalancingRobot.
Maybe, I have mistake program or hardware or both.
Post Edited (caskaz) : 11/22/2009 7:07:58 AM GMT
the angle do to centripital force would be 90 degrees out of phase with its actual angle and the percentage of effect would be greater the farther down it is. Not the simplest math but doable.
24 bit LCD Breakout Board coming soon. $21.99 has backlight driver and touch sensitive decoder.
also can you describe your setup some? i think you want the accelerometer as close to the center of rotation as possible.
Post Edited (Alsowolfman) : 11/22/2009 9:10:44 AM GMT
1.Kp=1 Ki=Kd=0
2.When robot lean to left, it move to left to fall down. When robot lean to right, it move to right to fall down. Increasing Kp step by one,
But Same result
3.When I place hands at both side of robot not to fall down, robot repeat to lean from left to right and from right to left.
I tried various Ki and Kd. But Same result
I cut off motor-power, and I checked value of xmG on Serial Terminal.
Kp=2 Ki=Kd=0
0degree xmG = 0 drive = 0
30degree xmG = 500 drive = -1000
-30dgree xmg = -500 drive = 1000
Because rotation speed of wheel is max at passing 0degree, signal from sensor is not enough to move it to reverse maybe.
I go to purchase rotary-encoder tomorrow. and try it.
Thanks.
