Auto Detect Port
mynet43
I'm using a USB port to communicate with the Propeller from a PC.
This works fine. My only problem is, that USB picks a different COM port depending on which computer I'm using.
I'm planning to distribute the software. So I'd like it to auto-detect the COM port during start-up.
Can someone help me with the protocol used by the Propeller Tool to detect the COM port. It seems to work fine [noparse]:)[/noparse]
I assume it sends out something to each port and then checks for a return it recognizes.
Thanks for the help!
Jim
Jim
Thanks for suggesting the Propellent.
Unfortunately, I don't think this will do what I need.
I think I misstated what I'm doing.
I have an application running on the PC.
It inputs commands, sends and receives text messages to/from the Propeller, displays results and stores Propeller data to a file on the PC.
I need my application to auto-detect the USB port connected to the Propeller. That's why I'm looking for the protocol.
I'm sure it's not complicated.
Thanks for the help.
Jim
I think I'll do something similar to what you suggest.
I already reset the Prop, so that's not a problem.
I'll let you know what I figure out.
I was hoping to find Parallax' secret, to make it a little easier [noparse]:)[/noparse]
Jim
