RMS Power Meter
I have a need to measure RMS and Instant Voltage, Current and Power in a single cog. This cog will be used among different subsystems to measure at the chip level.
Things like power consumption at the Prop(s), aux processors such as SD, sound, XMOS and ARM co-processors, etc.
At the moment it is ill-defined, such as LCD or not, RS232, shared global memory.
Any ideas? Is anything lurking in the OBEX that is mislabeled? Maybe just an analog power meter used in conjunction with a Flash data logging scheme?
JMH
JMH
Regards, David
· Propeller Object Exchange (last Publications / Updates);·· Vaati's custom search
