Help needed to "shorten" time between pulses — Parallax Forums
XypherXypher Posts: 10
edited 2009-12-15 10:09 in BASIC Stamp
I am writing a program to control a 4 Channel r/c toy.
However, the time taken for each cycle of 4 channels is too slow. The receiver needs to be updated every 20ms. 50 times a second. However each full PPM output takes 75-100ms at least. Partly due to RCTIME function. Is there anyway to control it more effectively? At the current level, its impossible to control any r/c toy I think.
Would PWMPAL be the best tool for this job?
Somebody said...
' {$STAMP BS2}
' {$PBASIC 2.5}
' Control servos with accelerometer
rawx VAR Word
rawy VAR Word
x VAR Word
y VAR Word
time VAR Word
throttle VAR Word
header VAR Word
DO
PULSIN 8, 1, rawx 'data from accelerometer
PULSIN 9, 1, rawy 'data from accelerometer
y =5 * rawy / 12 - 290 'formula to convert raw data to pulse to control servos
x =5 * rawx / 12 - 290 'formula to convert raw data to pulse to control servos
HIGH 8 'receive data from potentiometer to control motor
RCTIME 8, 1, time
throttle = 10 * time + 490 'convert data to pulse
PULSOUT 7, x
PULSOUT 7, x
PULSOUT 7, throttle
PULSOUT 7, y
header = 10000 - x - x - y - throttle 'calculate the pulse require to fill up remaining 20ms
PULSOUT 7, header 'pulse to reset
LOOP
Thanks.
    edited 2009-11-18 17:19
    A Stamp can only do one thing at a time and nothing is overlapped. With 4 R/C pulses, that's maybe as much as 10ms spent just generating the pulses themselves leaving only 10ms for other things. You have two accelerometers you want to read and a potentiometer and the time to read these has to come out of the 10ms that's left. You need to reduce the width of the "leftover" pulse to compensate. Remember that the units for both PULSIN and PULSOUT are 2us on a BS2. Your "leftover" pulse should be:
    header = 10000 -x - x - throttle - y - rawx - rawy - time
    You also need to check for no time left like:
    IF header > 0 THEN PULSOUT 7, 2*header
    edited 2009-11-18 17:44
    Xypher,
    Is there any reason you need to read all three sensor outputs in every transmit cycle? Perhaps you could save time by rotating through them, reading just one per cycle.
    edited 2009-11-19 05:07
    Xypher,
    Phil's suggestion is the way to do it in a single threaded environment. Basically you have an Index counter set to count to "N" and recycle...
    Pseudo Code
    Index = Index + 1
    If Index = 1
    If Index = 2
    If Index = 3
       RCTIME 8, 1, time
    If Index = 4
       Index = 0  ' Reset Index count
       Flag = 1   ' Flag ensures that we've completed the loop at least once before sending out pulses
    If Flag = 1
       PULSOUT 7, x
       PULSOUT 7, x
       PULSOUT 7, throttle
       PULSOUT 7, y
    Beau Schwabe
    IC Layout Engineer
  • XypherXypher Posts: 10
    edited 2009-11-25 06:42
    Thanks Beau for the code.
    However, due to RC TIME, the pulse is still too long for my receiver. Is there any other way to control the motor without RC TIME?
    edited 2009-11-25 07:10
    Look at the chapter in the Stamp Manual on the RCTIME statement. You might be able to change the capacitor value to use a shorter time period for the RCTIME. You'll probably get less resolution, but it may be enough for your purpose. If not, you'll just have to use some kind of external analog to digital converter to measure the voltage at the pot wiper if it's connected between +5V and ground.
    edited 2009-12-15 08:25
    May I know why this kind of waveform appears instead of the usual pulsout waveform?
    Somebody said...
    DO
    PULSOUT 5,750
    PAUSE 12
    PULSOUT 5,700
    PAUSE 12
    PULSOUT 5,650
    PAUSE 12
    PULSOUT 5,600
    PAUSE 12
    LOOP
    I used this program to test the waveform but it still looks wrong.
    Thanks!
    It looks like you forgot to connect your scope's ground lead to Vss, or else you've got the input set for AC coupling.
