Have you seen this switch?
The supplier ran out and I really don't want to redesign. I have looked everywhere with no luck. I am hoping one of you guys may have run across these somewhere.
I heard that it is often referred to as a pin switch, but not sure about that.
Todd,
That looks like a plunger momentary switch. I figure you should be able to look around and find one. Not sure about the tab connection on the back though. Look for a plunger limit switch. If you don't find any, let me know....and I'll look with some of my past suppliers (Automation).
James L
James L
Partner/Designer
Lil Brother SMT Assembly Services
Are you addicted to technology or Micro-controllers..... then checkout the forums at Savage Circuits. Learn to build your own Gizmos!
Perhaps contact your local white-goods repairer?
Or car automotive (kind of looks like an interior light switch from the doors).
As to where to get one locally to where you are...Sorry can't help there.
Good luck
The future is in our hands.
Which way to the future?
Mike2545
This message sent to you on 100% recycled electrons.
I don't know if this performs the same function, but the attachment below shows a switch I got from RadioShack a few years back. I't N.C., and the threaded portion is part of the circuit. If you can't find one at R.S., and if it fits your needs, email me your address, and I'll just send it to you. (I've got another, and I can't imagine how I'd use one, let alone two.)
_
Amazing how different a search result you get by:
plunger switch nylon ( no luck)
vs.
nylon plunger switch (success on first page)
www.blackwidowsecurity.com/acc-PSA-05.htm
Glad you found them, now you can relax and go back to getting things done.
James L
James L
Partner/Designer
