Have you seen this switch? — Parallax Forums
T ChapT Chap Posts: 4,260
edited 2009-11-18 05:52 in General Discussion
The supplier ran out and I really don't want to redesign. I have looked everywhere with no luck. I am hoping one of you guys may have run across these somewhere.
I heard that it is often referred to as a pin switch, but not sure about that.
  • James LongJames Long Posts: 1,181
    edited 2009-11-18 00:36
    Todd Chapman said...
    Todd,
    That looks like a plunger momentary switch. I figure you should be able to look around and find one. Not sure about the tab connection on the back though. Look for a plunger limit switch. If you don't find any, let me know....and I'll look with some of my past suppliers (Automation).
    James L
    James L
    Partner/Designer
    Lil Brother SMT Assembly Services
    Are you addicted to technology or Micro-controllers..... then checkout the forums at Savage Circuits. Learn to build your own Gizmos!
  • pacmanpacman Posts: 327
    edited 2009-11-18 00:37
    Looks very similar to the switch that was the 'lid closed' sensor on my old washing machine.
    Perhaps contact your local white-goods repairer?
    Or car automotive (kind of looks like an interior light switch from the doors).
    As to where to get one locally to where you are...Sorry can't help there.
    Good luck
    The future is in our hands.
    Which way to the future?
  • Mike2545Mike2545 Posts: 433
    edited 2009-11-18 01:21
    Closest I could find was this cgi.ebay.com/ebaymotors/D889-PLUNGER-SWITCH-71-72-73-74-75-76-77-78-79-P10_W0QQcmdZViewItemQQhashZitem27a995f0a0QQitemZ170348900512QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
    Mike2545
    This message sent to you on 100% recycled electrons.
  • mikedivmikediv Posts: 825
    edited 2009-11-18 01:46
    pacman hit the nail on the head ,, Todd did you find them?? if not try Lowes or home depo in the appliance electric row, I would also try a local hardware store , I have that exact same switch in my Sears dryer for when the door closes its an older machine but I bet I could get them from Sears if you are really stuck let me know and I will see if I can get one, I was in Lowes last summer and remember seeing them as well maybe a little smaller not sure but exact same thing.
  • T ChapT Chap Posts: 4,260
    edited 2009-11-18 02:40
    OK that sounds good, thanks for those ideas. I will go down that path and see what happens. They were in abundance at allelectronics and I built them into a design, then somebody bought the lot. This switch will take a beating and is convenient for adjusting.
    288 x 194 - 10K
    edited 2009-11-18 03:24
    Todd,
    I don't know if this performs the same function, but the attachment below shows a switch I got from RadioShack a few years back. I't N.C., and the threaded portion is part of the circuit. If you can't find one at R.S., and if it fits your needs, email me your address, and I'll just send it to you. (I've got another, and I can't imagine how I'd use one, let alone two.)
    _
    1007 x 731 - 63K
    edited 2009-11-18 03:48
    Thanks Phil, for this I think I have to stay with the same part, plus I need a batch of them. Thanks for the offer.
    edited 2009-11-18 03:59
    Success!
    Amazing how different a search result you get by:
    plunger switch nylon ( no luck)
    vs.
    nylon plunger switch (success on first page)
    www.blackwidowsecurity.com/acc-PSA-05.htm
    Success!
    vs.
    Glad you found them, now you can relax and go back to getting things done.
    James L
    James L
    Partner/Designer
